Televison & Video Logo
A
Anonymous Posted on Jan 05, 2016
UMCTV DV3-T. How do I stop the display of subtitles?
I have connected Ferguson dv3 monitor (set) to a dell optiplex 745 system unit using a vga cable but it is displaying no signal. What could be the solution to that/
old post.
Fergusion Dv3?
well does the FERG run on other known working PC?
test the FERG first.
or try a known good PC monitor to the 745,
these simple tests prove what end is bad.
easy no? just do it.
"it is displaying no signal."
does those words show on the screen
or are thinking this, I see no signals.
my guess is the FERG texted to the screen live no SIGNAL
that means the PC is dead, in all cases.
(or cable bad sure)
so the post her changes to DEAD PC>
1: does the PSU fan in the PC spin? PC silent is it?
ill stop here, as that is 1 step. if i show 5 steps folks get scared.
1helpful
Hi... how can i turn on the double click on touchpad ... my laptop is hp pavilion dv3
access control panel - select the mouse - select device settings - then the setting button - the rest is straight for for all the settings are displayed or hit default
I cannot wake up my HP Pavilion dv3. blue power led flashes on and off and orange connection led too.
The display driver could have crashed, try holding the power button until the lights go off, and the hard drive powers down (you can hear the spinning stop) then try to power it back on. If that doesn't work, do a hard reset, which would be unplugging it from any AC power, and removing the battery and then reconnecting the battery before powering it on. Should this not work, i would say it's safe to assume the backlight is non functioning and a replacement would have to be ordered.
1helpful
2answers
2answers
How do i change the language on my pioneer avic-d3 player
here is the link to your manual:
http://www.pioneer.co.uk/uk/support/manuals/AVIC-D3/index.html
Setting the language
You can set a desired subtitle, audio and menu
language. If the selected language is recorded on
the Disc, subtitles, audio and menu are displayed
in that language.
1 Touch “Language” and then touch
“Subtitle Language”, “Audio Language”
or “Menu Language”.
Each language menu is displayed and the currently
set language is selected.
2 Touch the desired language.
When you select “Others”, a language code
input display is shown. Input the four digit
code of the desired language then touch
Enter”.
➲ “Language Code Chart for DVD” ➞
Page 114
from the manual:
English (en), 0514
❒ If the selected language is not recorded on
the disc, the default language specified on
the disc is output and displayed.
❒ You can also switch the subtitle and audio
language by touching “S.Title” or “Audio
during playback.
➲ “Changing the subtitle language during
playback (Multi-subtitle)” ➞ Page 75
➲ Changing audio language during playback
(Multi-audio) ➞ Page 75
❒ Even if you use “S.Title” or “Audio” to
switch the subtitle or audio language, this
does not affect the settings here.
Setting assist subtitles on or off
Assist subtitles offer explanations for the aurally
impaired. However, they are only displayed if they
are recorded on the DVD.
You can turn assist subtitles on or off as desired.
1 Touch “Assist Subtitle”.
Touching “Assist Subtitle” switches
between “On” and “Off”.
Cheers!
2answers
Cyrilic Subtitles Do Not Display
Try to use VLC player. open movie file with vlc player , after wards just drag and drop subtitle file to movie screen.
2answers
Subtitle Problem: Onkyo TX-sr605
The only remote that will definitely turn the sat subtitles on/off is the sat remote. The other subtitle buttons on the other remotes refer to the DVD subtitles and the subtitles generated by the tuner in the tv. The subtitle option is greyed out on the tv because you are not on the tv tuner.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
