Question about Whirlpool GH6177XP Microwave Oven
Kenmore 401.8008700 ran 10 minutes thought I'd set on timer
After ten minutes, realized minstake and opened door to turn off. No panel power or control response now but outlet working.
  • 999 Answers
It could be the fuse. You will also need to check the condition and alignment of the door switches.
Eric
Posted on Jul 16, 2009
How do you use the kitchen timer and cook at the same time?
If you have the kitchen timer set for instance for 10 minutes and it is counting down, and then you want to reheat you coffee for 2 minutes. You would hit either time cook or reheat button and enter 2 minutes ten hit start. The microwave will heat your coffee and show the 2 minute countdown for that. When done it will revert back to what is left on the 10 minute kitchen timer without missing a beat on most microwaves.
Feb 26, 2015 | Microwave Ovens
I accidentally ran my Kenmore microwave Model No 401.80083700 with nothing in it, for 20 minutes (thought I'd put the timer on)now it has just stopped working. No power coming on at all. Can this be...
Depends could be thermal cut out gone more likely magnatron....Perhaps you could claim home insurance...Accidental damage...please leave feedback.
Apr 07, 2010 | Microwave Ovens
Ran on power for 10 minutes, thought it was on timer.
First, check the fuse usually located above the display, inside the top lid.  You can't see if it's blown, so you must test it for continuity with a meter or self powered test light.  Usually fifteen amp, and of the ceramic variety.  (available at radio shack type places) If the new one blows instantly, it's likely a door switch shorted out.  If it blows after a few seconds, it could be the magnetron gone bad, or internal arcing.  The main transformer will sometimes short out, but that's rare.   Be absolutely careful, should your fingers venture around the magnatron connections down below, as there is high voltage and current that can kill you.  This warning applies even when it's unplugged!
The door switches operate together, so if one slams the door shut it will often blow the fuse with no other damage.  Sometimes the crow-bar switch will sustain damage in the process.  Usually, if the switches click individually, they're good.  If one doesn't click, it'll almost always be shorted.  They're located behind the door catch, inside the unit beside the display board, and a bit hard to access.  You will need to reach past the magnatron for this, so be careful.
Jul 15, 2009 | Whirlpool GH6177XP Microwave Oven
Kenmore microwave not running
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
Mar 13, 2009 | Kenmore Microwave Ovens
Operated Microwave with no food in it
Sounds like she blew the cavity thermal overload. you would have to take the cover off of it to find it. let me know if you need more assistance
Dec 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Goldstar
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Nov 27, 2008 | Microwave Ovens
Microwave
I looked at the previous "solution" to your first inquiry. Let's set that aside, shall we...
Generally, faulty door switches will cause it to either run but not heat, not start, or blow the fuse as the door is opened or closed.
You ran this in timer mode for a few minutes, then it died?
This is often a case that the oven was actually running (cooking) empty.
This will cause the magnetron to overheat, and its attached thermal cutout (or thermostat, depending on the model) to open.
If it's a good thermostat, it will cool down and come back on.
If it's a thermal cutout or bad thermostat, it will not come back on.
At our site, we now have a video available showing how to remove a typical control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
The mini manual will show the location of the thermal cutouts / thermostats.
If this does not get you a FixYa, please reply back and update us with your situation.
Aug 15, 2008 | Microwave Ovens
Everything works... except the heat!
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can probably find an exploded view by entering your FULL model number here: http://www.searspartsdirect.com
A full Sears/Kenmore model number usually has 3 digits, a dot, then 8 more digits, such as ###.########
If you think the problem is on the control panel, which we repair these nationwide for $39.95 postpaid.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 12, 2008 | Microwave Ovens
Microwave Power Blew Out - Kenmore Elite Model 721.63763300
There should also be a very helpful "mini-manual" hidden inside the unit behind the control panel. It's very helpful when troubleshooting.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Mar 09, 2008 | Microwave Ovens
Whirlpool GH6177XP Microwave Oven Logo
81 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
