Question about Infinity BASSLINK Car Subwoofer
Is the light on the infinity basslink suppose to be red or green
  • 655 Answers
Hello jmw3031,
The Basslink should have both a red power LED and a green servo LED. The red LED should be on when power is applied. The green servo LED should only come on during high-level bass transients. Turn the gain down slightly if it stays on for extended periods.
Hope this helps.
Posted on Jul 15, 2009
Power light
Hi Bill, I believe the power problem is related to the Remote wire which should be blue or yellow. The remote wire is suppose the turn the Basslink on and off when the radio is turned on and off. The yellow wire is normally used for power antenna. Traditionally the remote wire is blue. You can use a Speaker level adapter and splice in with the L/R rear speaker wires, and the adapter will convert the speaker level to line level. The output of the adapter will go to the Rear speaker input on the basslink., Write back if you need more detail on the adapter.
Oct 07, 2007 | Infinity BASSLINK Car Subwoofer
Infinity Basslink not producing any sound. Green light on.
check that fusse under the hood if its blown pull it out and replace it wont hurt anything if u pull it out an put it back in if the cars off.but if ur getting power lights on the amps then more then likely ur fuse isnt blown.id start by checking the audio cables are produceing sound.if u need more help let me know bertman285@hotmail.com
Sep 29, 2009 | Infinity BASSLINK Car Subwoofer
Basslink red light on but no sound
check the all power lines and regulator .is any of them overheating?
then check the power amp ic or transistors.
nuwan.
Jan 12, 2009 | Infinity BASSLINK Car Subwoofer
Red light comes on and then slowly goes out. No output
For some reason you are not getting constant power to the system. What gauge power/ground are you running? Describe your system to me and we'll see what I can do to help.
Jul 16, 2008 | Infinity BASSLINK Car Subwoofer
2nd Basslink, still no power-on. Please help
this is in response to the post below:
I just bot a basslink t and i wired it up and nothing it just keeps blowing the fues in the unit i got mine on ebay2.gif so i dont know if i can use the warranty dose anybody have an ida for me- britter623
I got a used basslink about a month ago and had the exact same prob kept blowing fuses...found out that the voice coil had blown on the infinity...so I had a brand new dvc polk 10 sittin in the closet, I swapped them out, put the polk in the place of the infinity sub, however, the magnet is much larger, hence, dual voice coil, it would rattle sooo much from the passive radiator against the magnet, also could not turn the gain up at all due to the rattle. I got the bright idea to build a "custom fiberglas enclosure for the polk and incorporate the infinity's parts(amp/control) I finished the box finally last night and hooked it up this morning, no power, no lights, no nothing! s@#%, F&@%! ANyone had a prob w/the amp not having the lights turn on, no power??? Hope that helps about your fuse blowing issue.
Jul 15, 2008 | Infinity BASSLINK Car Subwoofer
Infinity Basslink killing battery
Both issues sound like they are related to a non-connected or loosely connected remote wire on the Basslink.
If you're using RCA preamp wires to connect your stereo to the Basslink, make sure the remote wire input on the Basslink is solidly connected to the stereo's remote output.
If you're using the speaker level inputs on the Basslink and not the RCA preamps, make sure the remote input is not connected, as the Basslink will automatically turn on when it senses the speaker level inputs are active.
Mar 19, 2008 | Infinity BASSLINK Car Subwoofer
Basslink Stoped working after a month ** sound ** red LED
check all your power fuses and insure you havec power where it is supose to be. maybe you have blown a fuse.
Mar 09, 2008 | Infinity BASSLINK Car Subwoofer
No Sound from Basslink
Do you have speaker wiring or RCA's hooked up from AMP to Basslink? Also check the settings, make sure you are have bridged the channels on amp.
Feb 02, 2008 | Infinity BASSLINK Car Subwoofer
Light is always on!
yes the problem is in the installation.the power supply usually has 2 to 3 positives one positive which is usually red go directly to battery. the other,either yellow,orange,or blue go to car stereo(not to battery or ignition) this supply,turn off the amp when u turn of the stereo. hope this help u....
May 09, 2007 | Infinity BassLink II Car Subwoofer
Open Questions:
See all Infinity BASSLINK Car Subwoofer Questions
Infinity BASSLINK Car Subwoofer Logo
594 people viewed this question
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
