How to replace bios battery in A10 s129 toshiba sattelite laptop computer?
  • 601 Answers
Hi bjcermd,
1. Remove the battery (side latch release) and hard drive. The only screw that holds it down is marked F-4 on the cover. (look for the panel with the 2" circle, that is the HD)
Use the white pull tab to move it left then upwards. It should move with little effort. Be careful not to loose the screw from the HD panel.
2.Remove all screws annotated F6 from the bottom bezel with a Pt. 2 screwdriver. (from my count there was less that a 15 )
Depending on the screwdriver, there are times where you might have to push the screwdriver down a bit to get in contact with the thread. Just be careful not to strip the threading.
3.Remove the "B25" screw located near the heat sink-fan vent. Somewhat carefully take your hand, and lift the bottom bezel up enought to disconnect (about 1-2 inches from surface) the battery with your index and midde finger. Look at they way the battery is run, and seated in the plasic clips.
With the bottom semi-open, plug in the replacement battery, and re-seat it in underneath the white ribbon cable, and clips on the housing per the original.
4. Replace all screws (less than a ton).
Thanks
Smith
Posted on Jul 15, 2009
Ho to remove toshiba sattelite A10-s167 bios password keeps giving a password prompt but i forgot it now
just open cpu cover & remove cmos bettery from mother board then start the system then again put it just restart
Apr 16, 2014 | Toshiba Satellite A15-S127 Notebook
I want to update the bios on toshiba satellite a10
Go to Toshiba support website and enter your computer model no. to get new driver, there may be a Re flash of Bios available.
Oct 10, 2012 | Toshiba Satellite A10-S100...
Have a Toshiba Satellite A10-S129 and a forgotten BIOS password. What's the best way to reset password?
Buy or make your own parallel port password removal key. eBay's the best place to buy one, and wiring diagram is free on the internet, and it's pretty easy to make one if you have a meter and a soldering iron handy. This is the ONLY way to reset the BIOS to its factory default state (and password free).
Apr 22, 2011 | Toshiba Satellite A10-S129 Notebook
I cant get into cmos
dont wory.. it easy... turn on laptop dont dealy press the escape button Continuously .. u will see screen press F1 for enter bios setup.. for more information
Sep 18, 2010 | Toshiba Satellite A10-S129 Notebook
Where is the cmos battery on a Toshiba laptop model a10-s129
Please refer to the below URL to download the Service Manaul of your notebook where you can find the requested info:
http://www.retrevo.com/support/Toshiba-A10-S129-Laptops-manual/id/614ag314/t/2/
May 25, 2010 | Toshiba Satellite A10-S129 Notebook
I replaced motherboard on my Toshiba A15 - S129 and now y model is A10. Is it possible to change that to A15. I can't use restore CD because of that. Please help.
You need to run the dmi utility. if you go on toshiba's support site it should be there. if not email me and i will send it to you.
Nov 04, 2009 | Toshiba Satellite A15-S129 Notebook
Have a Emachine Laptop M6809 , the screen is all pixelated and distorted from bios boot through WinXP loading , same with external monitor .
Theres a problem with the video card of your laptop. If you just formatted your laptop, check if you have installed the driver of your video card. Or bring it to the service center if you still have a warranty for it.
Jul 03, 2009 | Toshiba Satellite A10-S129 Notebook
Display is distorted with weird vertical lines on toshiba satellite A10-S129
This sounds like the LCD has been damaged. It will need to be repaired.
May 06, 2009 | Toshiba Satellite A10-S129 Notebook
Broken sound card how can i replace it i have toshiba a10 s129 (
no, sound card is a procesor on your mainboard.
but i think you should focus on jack connection inside.
i'ts alot more possible..
Mar 22, 2009 | Toshiba Satellite A10 Notebook
Want to replace cmos battery in Toshiba Satellite A10
On Toshiba laptops you hit the ESC key as soon as you turn it on & then you
are given the option to hit the F1 key to enter bios.
As to the cmos battery, they couldn't have hidden it better if it was the Queen's diamond!
It is near the bottom of the laptop on the right side, almost directly beneath the pause/break key.
Problem is, you have to disassemble the entire laptop to get at it!
Disassembly instructions for the Satellite A10 are here
http://www.irisvista.com/tech/laptops/ToshibaA15/SatelliteA15_laptop_disassembly_1.htm
Best of luck
Barb
Jan 25, 2009 | Toshiba Satellite A10-S100 Notebook
Computers & Internet Logo
782 people viewed this question
David Payne
David Payne
