Question about Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph
Where can I find a replacement for a threaded cover for intex filter pump 635
  • 297 Answers
Right at intex.com
although your exact pump may not show due to intex having so much product they will have it just make the call.
Do realize the earlier you call the better since it is pool season they are quite busy but your reward for waiting will be to get the part you need
Posted on Jul 15, 2009
My intex 637r pump is not pulling the water through to the filter and letting it discharge back into pool could it be that the pump and hoses are sitting to high on the ground and not far enough under the...
Air release valve for air trapped inside filter chamber
Intex 1000 GPH Easy Set Pool Filter Pump Instructional Guide 637R
The link has a set-up video for the 637R pump. Make sure water flows out of the air valve on the top of the filter cover. This will purge air out of the filter and prime the pump. Hope this helps you....
May 13, 2014 | Intex Krystal Clear Model 635 Pool Filter...
Tip
How to fix the Model 635 pump issues
Take that piece of junk and toss it. There are simply no replacement parts available. Replace with a Pentair 3/4HP Dynamo and a 75 sq. ft. filter unit. You can use the existing Intex hoses with 1" couplers and pipe clamps. Buy a length of 1-1/2" flexible spa hose to connect from pump to filter. It'll cost about $400 all told for this setup (if you do the install yourself), but you'll recoup the cost in the 3-4 years you'd spend replacing the 635 annually.
on Jun 09, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Intex 635. Replaced filter, blead air, actually went as far as removing back plate on pump cover. Impellar looks fine. Runs stong for a few minutes and just stops. Removed hoses checked for blockage,...
Thank you for posting your question here on Fixya.com.
Cartridge filters load up over time and no amount of cleaning will restore them to good condition. You can expect to replace the average filter every couple of years...perhaps it is time to replace yours? The baking soda is going to dissolve into the water column so even if it were to cake up in the element it will dissolve quickly; it is not the problem.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Jul 24, 2011 | Intex Krystal Clear Model 635 Pool Filter...
Intex Krystal Clear Filter/Pump Model 635 replacement parts for the pump
my intex 635 pump impeller is broken i need a replacement part. i do not have the money for a new pump.
Jun 30, 2010 | Intex Krystal Clear Model 635 Pool Filter...
Need an impeller for a model 635 intex pump.
You are correct. Intex is in the business of selling new product. If you have the pieces, they may be super glued with about a 70% sucess rate. good luck!
Aug 12, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Intex pump 635 is a P.O.S.! How do I hook up a different pump?
I just left the standard intex connection on the pool and I cut the standard connection off of the filter side and I slid the hose over the top of a 1 1/2 pipe and put 2 stainless steel hose clamps over them and it worked fine
Jul 23, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Intex pool filter 635 wont turn on
Check your connections to make sure that a lack of pressure is not causing your problem. Also, make sure that your impeller is not jammed, which will cause the filter to not work. These filters are not very well made and usually have to be replaced after a few seasons. They are designed for short term use. It might be time to start looking for new pool filters.
Jul 10, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Looking for an intex filter pump
The best solution to this problem not to find a replacement intex pump/filter. I suggest getting a system with a 50 square foot cartridge filter and a 3/4 hp pump such as hayward or pentair offers. You will be amazed at the difference a little quality can make.
Apr 07, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph Logo
169 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
