Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Unit compressor keep short cycling not feezing or
Unit compressor keep short cycling for approx. 10 seconds and shut down not freezing or cooling
  • 39 Answers
Replace your compressor relay. that's what goes wrong 99% of the time
Posted on Jul 15, 2009
Ice machine harvest two times and shut off
These unit time freeze time and harvest times and keeps track of them. If your freeze time exceeds 35 minutes or harvest time exceeds 3 minutes, it will place unit in lockout. The biggest cause for excessive time to harvest is the harvest valve not functioning properly, and undercharged unit or a dirty condenser. The most probable cause is a dirty condenser. Under charged units can be determined by checking compressor outlet temperature while running, it should be 150 to 190 degrees depending on atmospheric conditions present. If it is harvest valve, the downstream temperature will stay at or near compressor discharge temperature. It should cool down to ambient temperature in a few minutes after freeze cycle begins.
Nov 25, 2013 | Scotsman Ice Maker 600LB CM3 30inW...
Duo Therm A/C (2009 Sabre RV) won't shut off
bad compressor relay on control board. The relay is not opening the circuit, allowing the compressor to stay running when unit is turned off. This overheats the compressor and opens a thermal disk shutting the compressor off. When thermal disk cools down, the compressor restarts under load and trips breaker.
Jun 06, 2013 | Dometic Rooftop RV Air Conditioner
Emerson quiet cool cycles every 6 mins
YOU ARE HAVEING A SHORT CLCLE PROBLEM COMPRESSOR SHOULD NOT SHUT OFF UNLESS THEMOSTAT SAY OK AT TEMP OR UNIT FREEZES UP AND FREEZE STAT SHUT COMPESSOR OFF USUALLY REALLY SHORT CYCLING LIKE YOU ARE EXPERANCING IS CAUSE BY COMPRESSOR OVERHEATING OR FAULTY THEMO SHUT OFF ON CMPRESSOR REPAIR SHOULD BE DONE BY LICENCED TECH
Jul 29, 2009 | Dometic Rooftop RV Air Conditioner
My dometic 15k brisk-air cont. cycles on-off
Actually, the dealer is somewhat correct. In the hotter months of the summer, the rooftop units have a tendency to freeze up if not run on high cool due to the lack of air movement across the evaporator. If the unit fines on High/Cool, then run it in that mode but adjust the thermostat.
It should not however, cycle on and off that fast unless you have a bad freeze switch or the incoming AC is too low. If during that 8-10 seconds, the air begins to get cold and then it shuts off, then I would say you have a bad freeze switch. If it runs fine on high, but shuts off in low, I would say it is a lack of air movement.
Hope this helps,
Jeff
Rate me please!!
Jul 06, 2009 | Dometic Rooftop RV Air Conditioner
F/Freezer ARC7470: Compressor shuts down when set
Issue sems with the relay switch need to change/repair.
Jul 06, 2009 | Whirlpool Refrigerators
Fridge is not cooling freezer is not freezing
Your compressor is seized and is cycling on intenal overload, you will have to get someone out to get a price at replacing the compressor for your fridge.
Apr 04, 2009 | Kenmore 57029 Side by Side Refrigerator
Refrigerator won't cool
Hi!!! you have a problem with your current relay change it.Its shown here If it still dont work the your compressor windings are shorted.good luck.. 78e052d.jpg
Jan 21, 2009 | Kenmore Refrigerators
Magic chef not cooling
The compressor is shutting down because it is drawing too much power and overheating. The clixon detects this and shuts off all power till it cools - then it resets and supplies power back to compressor until it overheats and problem repeats itself.
So what is responsible for overheating? Well, if there is an obstruction in the cooling system (high pressure side), the compression goes up past spec and the motor labors and slows down, creating less back emf, and increasing current consumption > then overheats and turns off. OR, if some of the the motor windings have had the insulation melt off, then the motor has less resistance than designed, more current goes through and again it overheats and shuts down. In this case your motor is fubar and needs to be replaced.
Apr 24, 2017 | Magic Chef CTB1922 Top Freezer...
Hoshizaki KM-450MAB Ice Machine
maybe not. it could be that the heating cycle is taking a lot of time to remove the ice from the evaporator that is why the electronics is shutting off the compressor as a protection. check the heating cycle if it is working fine. check the evaporator for dirt that would hold the ice slab from falling down quickly. check the level of the unit. it may have move and now its out of level. the unit must be leveled with the ground.
Feb 21, 2008 | Hoshizaki Cubelet Ice MakerDispenser Water...
Cooling
Check if the condensar ( outside fan unit) is getting enough free ventilation. IF there is no free air flow you will mostlikely be triping the unit due to short cycling. Ie the unit is pulling its own discherge air causing the compressor to trip due to high back pressure
Sep 04, 2007 | Haier HPAC9M Air Conditioner
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
360 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
