Question about IBM ThinkPad R51 Notebook
My ibm thinkpad r51 is not starting up just keeping giving me error message and it doesn't recognize the hard drive in boot. I have to take the battery to stop the system trying restart the window again and again.
  • abelcheung88 Jul 15, 2009
    Thanks, I will give it a try and to see whether it is the problem with the HD.
    Before my laptop crashed, I have got several messages such as virtual memory is low. Does that mean the motherboard is faulty?
  • IBM Master
  • 32,281 Answers
It appears the hard drive is faulty.
Does the hard disk LED flash when the laptop boots up?
Go into the BIOS configuration and see it the hard drive is detected, (then Startup - Boot - and look at IDE HDD0 it should list the make and model of the hard drive).
If the hard disk is detected it still could be faulty. To test the hard drive, remove the hard drive and connect it to an USB hard drive adapter and connect it to a working computer's USB port.
If the computer sees this as an external hard drive and you can open the various folders and files then the hard drive is OK and the fault could be the disk controller on the laptop's motherboard.
If the hard disk is not detected the it is faulty and you need to replace the hard drive in the laptop and install Windows etc. to get it working again.
Posted on Jul 15, 2009
  • Chris Hingee
    Chris Hingee Jul 15, 2009
    No, Virtual memory is not a motherboard problem. When there is insufficient RAM available the computer uses part of the hard disk as RAM and if your hard disk is nearly full then you get this error message. The problem could be a failing hard drive or the hard drive is clogged with junk and temproary files.
    This is why the hard disk should be defrag and disk cleanup performed approx. once a month.
Thinkpad R51 will not boot
Try remove ALL media DVD.CD,USB,etc. Shut down, unplug, remove battery, plug in, reboot. Do you get anything on the monitor? Can you access the restore/recovery software? Open the Memory bay and reseat the Memory, open the HDD bay reseat the HDD, Reboot. If no change remove HDD, test, replace if necessary. Have you changed the CMOS battery?,
Jan 18, 2013 | IBM ThinkPad R51 Notebook
I have a ibm thinkpad r51 but when i turn it on it will load to somewords and il say media test failure check cable exiting intel boot agent then it will jut stay there
It's trying to boot from a LAN or Network. You want it to boot from your hard drive.
Temporary Fix that you will have to change each time you turn on the laptop:
Notice the screen when you press the power button, at some point it will tell you the keys to hit to get into the Bios or System Setup and the key to hit to Change the Boot Order. Hit the key to Change the Boot Order and select the Hard Drive
Permanent Fix
Notice the screen when it boots up and press the key that allows you to get into the BIOS or System Setup. Tab over to the area that allows you to set the Boot Sequence. Set your Hard Drive as the 1st Boot.
The best boot sequence is:
1. CD/DvD Drive First (Just make sure nothing is in the drive when you boot)
2. Hard Drive 2nd
Apr 21, 2012 | IBM ThinkPad R51 Notebook
IBM thinkpad R51 won't boot and the blue screen with unmountable-boot-volume comes up and i cannot bypass it.
Sounds like at least a corrupted OS, but most likely a bad hard drive. I'd try reloading Windows (if that's your OS) first, which should take well under an hour; if reloading takes excessively long, then the system is probably having a hard time formatting the hard drive due to physical bad sectors and the easiest thing would be to replace it. The R51 uses good old ATA/IDE 2.5" 9mm height hard drives, which are not available in most stores any longer, but you can probably get the same size or larger ones on eBay for pretty cheap and replace it yourself. Expect to pay about 50 cents to 75 cents per gigabyte - anything more would be considered tourist prices...
Sep 01, 2011 | IBM ThinkPad R51 Notebook
How to format r51
You can use your Windows installation CD to format the hard drive and install Windows again.
Boot up the ThinkPad with the Windows installation, follow the instructions to delete the existing partition, then create a new partition, then format the hard drive - do a full format, NOT a quick format.
You can then continue to complete the Windows installation.
Aug 06, 2011 | IBM ThinkPad R51 Notebook
I am getting a blue scree error on my IBM Thinkpad R51 that says unmountable_Boot_Volume. It will not let me run on save mode...it brings me back to the blue scree error message. I have windows xp
Unmountable boot volume = The file system is damaged and cannot be mounted.
To fix that do the following:
1.Put the CD first in the boot order and boot from the XP install disk.
2.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3.Select your partition - it should be C
4.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5.At the command prompt, type chkdsk /r , and then press ENTER.
6.At the command prompt, type exit , and then press ENTER to restart your computer.
This takes a bit longer, but the system should boot back into Windows.
Jun 14, 2010 | IBM ThinkPad R51 Notebook
IBM R51 Laptop cannot be turned on anymore
does your hard drive have a "caddy" or "drive sled" installed? Mine did the same until I bought one.
Dec 19, 2008 | IBM ThinkPad R51 Notebook
Unable to restore OS in IBM-R51
after the booting oftions boot to c: hard drive.. press F8..
Mar 24, 2008 | IBM ThinkPad R51 Notebook
174 error message on thinkpad 380
Try this:
Start with the machine OFF, hold down and CONTINUE TO HOLD the "F1" key and turn on the power WHILE STILL HOLDING DOWN "F1"
This should get you into the bios/setup, which on most thinkpads is pretty simple and self explanatory. You can reset the date, and something called "initialize" as I remember.
POST YOUR MODEL NUMBER!!!!
Ibm.com's support is famous for having very good, extensive support for thinkpads. I searched for this error no. but we really need the model number
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-4YLR6R
Mar 18, 2008 | IBM ThinkPad 380ED
00174 usually means a bad drive/hard drive/or controller for the drives Try replacing the hard drive.
Dec 09, 2007 | IBM ThinkPad 380ED
IBM ThinkPad R51 Notebook Logo
914 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
