Question about Whirlpool GH6177XP Microwave Oven
Ran on power for 10 minutes, thought it was on timer.
At some point after I opened the door, I lost all power to unit. There is power to the outlet.
  • 25 Answers
First, check the fuse usually located above the display, inside the top lid.  You can't see if it's blown, so you must test it for continuity with a meter or self powered test light.  Usually fifteen amp, and of the ceramic variety.  (available at radio shack type places) If the new one blows instantly, it's likely a door switch shorted out.  If it blows after a few seconds, it could be the magnetron gone bad, or internal arcing.  The main transformer will sometimes short out, but that's rare.   Be absolutely careful, should your fingers venture around the magnatron connections down below, as there is high voltage and current that can kill you.  This warning applies even when it's unplugged!
The door switches operate together, so if one slams the door shut it will often blow the fuse with no other damage.  Sometimes the crow-bar switch will sustain damage in the process.  Usually, if the switches click individually, they're good.  If one doesn't click, it'll almost always be shorted.  They're located behind the door catch, inside the unit beside the display board, and a bit hard to access.  You will need to reach past the magnatron for this, so be careful.
Posted on Jul 15, 2009
I have a Ge above oven microwave and apperently there was a small fire occured due to arcing. Now my Microwave doesn't turn on. Is my microwave fixable or do i need to buy another one?
Posted on Aug 09, 2009
My microwave shuts off, black no power when ever I cook tv dinners, potatoes etc. after 2.5 or 3 minutes. After 10 minutes or so, power comes back on and it displays PF. lots of steam inside after.
Hi Kerry,
"PF" is power falure if you didn't aready know this. It sounds to me like the coolig fan might be running slow or there is blocked or restricted air flow through the unit. This cooling fan is only for the HV transformer and magnetron. Sometimes you may get air flow around the door but this is incidental. The PF tells me that the power is being interrupted either at the power source (wall outlet or circuit breaker) or the magnetron TCO is cutting out. It also could be a bad magnetron running too hot. As far as the steam goes, I usually just leave the door open on my microwave for 10 or 15 minutes to let the condensation evaporate.
Jun 25, 2015 | Hotpoint RVM1435 Microwave Oven
My nn-s963bf starts operating when door is opened
The electronics have lost their marbles. When a nuker door is opened the safety switch connected to the door is designed to turn the unit off and not on. You just better work fast when you put stuff in or take it out!!!!!!!
Nov 24, 2013 | Panasonic NN-S963BF Microwave Oven
How do I know wattage for 1974 recipes and convert cooking time to todays microwave (1200)
A 1974 Microwave Oven is probably not putting out more than 600 watts. You need to do a power test to determine it's actual power output. Place a 2 cup glass measuring cup with exactly 500 mL of cold water. Record the starting temperature of the water. Run the microwave on 100% power for 18 seconds, using a watch or timer, not the timer on the unit. Take the water out and stir it to make sure that there are no hot or cold spots in the measuring cup. Record the new temperature. Example: 78.4-64.1= 14.3.
Multiply 14.3 X 38.75= 554.125. The power output is 554 watts IEC. If the recipe is set for a 1200 watt unit, and your is almost 600 watts, obviously, you would double the cook time. Since this is rough, you need to experiment a bit. If the cook time is 10 minutes, check your product at 8 minutes. Be sure to push the stop button before you open the door when it is in cook mode. This will save wear and tear on door switches and leave the remaining cook time on the timer. Let me know how this works out for you..
Oct 11, 2013 | Panasonic 1974 Microwave Oven Cookbook &...
Plmvz169gcc lost power
The service manual is here.
It may be a defective 20A fuse, a blown magnetron temperature fuse, or a problem on the control circuit board, which can be economically repaired.
There is a YouTube video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
Once the controller is off, you should be able to access the magnetron's temperature fuse for testing and possible replacement.
You can order parts from the Pros here.
Jan 10, 2013 | Frigidaire PLMV169DC Microwave Oven
The oven has no power. The outlet is hot. The unit will power up intermittently, but as soon as you try to turn it on it loses all power.
This is a safety feature of the microwave. Unplug it and leave the door open for about 10 minutes and it should work again with no problems.
P.S. My kids overheat mine all the time making pop corn.
Mar 27, 2011 | Samsung SMH9187 Microwave Oven
Whirlpool gold accuwave microwave oven lost power afer running em
Hello Davisaroundt, we are sorry to hear about your Microwave not powering on. If you would like for us to schedule service for you, then can you please email your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com?
Jun 13, 2017 | Whirlpool Accuwave Microwave Oven
Servicer with a PLMV169DCD Fuse blowing Problem
For future reference, we regularly repair such control boards and displays for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
Here's the main service manual. Other versions are here and here.
It may be grease inside one of the switches or arcing conductors (usually due to opening the door while it's cooking) making it sticky.
This was made by Sharp, so the side panel should come off each interlock switch for inspection.
But looking at the schematic, the monitor switch cannot come into play under normal circumstances unless the door is shut and the secondary interlock (relay RY2 on the control board) is closed and (oddly, if the published schematic is to be believed) if the oven lamp relay RY1 is closed .
Everything seems to point to a bizarre problem like maybe an intermittent short of a wire to the chassis, perhaps where a wire passes through a hole or guide in the sheet metal.
Also, you might consider unplugging the hood vent motor and trying it.
Did you try it with the oven powered from another outlet?
Also be sure the neutral and hot are not reversed at the outlet and that the line voltage is correct.
Sometimes a loose neutral can be a factor. Test outlets in several area of the house to see if some are high and some are low. This can be dangerous, and the power company must be called.
If there is anything else on the same breaker, that can be a factor.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Nov 28, 2009 | Frigidaire PLMV169DC Microwave Oven
Kenmore 401.8008700 ran 10 minutes thought I'd set on timer
It could be the fuse. You will also need to check the condition and alignment of the door switches.
Eric
Jul 15, 2009 | Whirlpool GH6177XP Microwave Oven
Operated Microwave with no food in it
Sounds like she blew the cavity thermal overload. you would have to take the cover off of it to find it. let me know if you need more assistance
Dec 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Goldstar
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
Nov 27, 2008 | Microwave Ovens
Whirlpool GH6177XP Microwave Oven Logo
102 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
