Question about Pegasus Technologies Pegasus F1225100BN Series 1000 Shower Only Faucet, Brushed Nickel
Problem is it's low flow fixture. has low flow resriturer inside
Call manuf. for help possible web site.
  • 297 Answers
This could a filter in the head that is doiog this just take it out,if this does not fix the problem check the cartridge it may have trach in it or the shower body itself.
Posted on Jul 15, 2009
I just installed a new shower with no tub. I have water to my delta fixture but no water out the head. I used shark bite connectors and did not solder the fittings
Are your walls still open? I assume they are as you'd be unlikely to close them up without having had tested your water flow. Here is what I would do.
1.) use the orange plastic C shaped release tool to depress the white plastic ring on the shark bite fitting that you have on the delta side of the Delta-ShowerHead connection.
2.) Carefully and slowly turn water on and see if water is exiting the fixture where you expect it to.
IF yes, water is coming out of the delta fixture then you know the flow problem is somewhere between the delta fixture and your shower head.
IF no, water is not coming out the delta fixture then you need to re-access how you connected the supply lines to the delta fixture.
Oct 24, 2014 | Delta & Single Handle Shower Faucet
What is the spark plug gap for Troy-Bilt Model TB230 lawnmower with Briggs & Strattan engine
Listen up. Whenever you ask an outdoor power equipment question, provide the engine manuf., Model no from engine and serial. (Series sometimes for B&S). If you have all of those B&S will tell you at their web site.
Sep 24, 2014 | Spark Plugs BR4HS Plug 10/BX #3322
What are the switch settings on an old ISA (8-bit) multifunction 1200 Practical Peripherals card?
on the modem has a set of number with manuf. with it go theen to web site of card support download them there
May 01, 2014 | Computers & Internet
Need to restore default settings
Want to reset an adapter or a router ? Network adapters don't usually save their configuration so there is no reset button. They are given their settings by the operating system. If they are configured to take the config from the network they broadcast a special message. A process in the router (or elsewhere in corporate networks) called DHCP sends them back the info they need.
The driver should be on the manufacturers web site. If it is a card, the manuf of the card. If it is on a motherboard, check the mainboard manuf or if a brand name Dell, Lenovo, IBM, etc.
check that site.
Normally the 'auto' setting will work.
Sep 17, 2012 | Computers & Internet
Gigabytega-ep35c-ds3r loud beep
The beeping sound is a sign of malfunctioning MEMORY CARD.
Just replace the mem card......
Hope that helps and tell me if there are more probs!
Nov 09, 2011 | Computers & Internet
I have a Hansgrohe Axor shower fixture and experiencing low water pressure now. I checked head by removing and cleaning. Pressure is low coming out of the pipe. Any help to diagnose and repair is...
John, look at the shut off valve. often those washers deteriorate and small pieces break off and plug things, and the washers sometimes stick and restrict flow.
Dec 13, 2010 | Home
Looking for tank psi trying to get better water psi out of the shower and taps
Every faucet and shower have a water saving restricter in them. Remove them from the shower head and end of the faucets.
They are about the size of a dime and with about 1/8" hole in them in which water flows out. So the flow is getting restricted from 1/2' flow to this giving you a water saving about a 1.5 gpm.
Below is some more information for the web site please check it out for further help.
http://www.inspectapedia.com/water/Poor-Water-Pressure-Diagnosis.htm
Poor water pressure just at certain plumbing fixtures? poor cold water pressure, hot water pressure, or both hot and cold water pressure or flow that is observed just at some plumbing fixtures in a building while flow and quantity are good at others suggests that the water flow or pressure problems are local to certain runs of supply piping or to the specific fixtures. Check the following first:
  1. Clogged aerator or strainer on sink faucets - clogging by dirt, debris, corrosion, can significantly reduce both hot and cold water flow at a sink where the strainer needs cleaning or replacement. Unscrew the strainer from the faucet and turn on the water - if the fixture pressure or flow is much better you've probably found the problem.
    Look at the aerator/strainer: inspect it, clean it, perhaps soaking it overnight in vinegar to remove corrosion and mineral build-up, or just install a new aerator/strainer.
Jun 04, 2010 | Plumbing
Multimedia audio controller is required. as the sound is not working.... and need for modem audio device as well.
if they are usb then look for a driver on the manufactures web site, if they are not find sound cards or the computers manuf. site for soud drivers
May 12, 2010 | Audio Players & Recorders
Control of water temp is finicky, and requires higher water flow to trigger the heater than in the past
Some tankless heaters have filters built into the machine. You might want to consult your owner's manual regarding the filter.
The minimum flow rate is hard programmed into a tankless heater; it won't be changing over time. You might want to check the aerators of your fixtures for buildup of sediment and scale.
The temperature control of Bosch units is always going to be crumby because they are cheap products. The only thing you can do to improve temperature stability is to increase water flow (de-scale fixtures and possibly remote flow restrictors)
Aug 15, 2009 | Bosch AquaStar Indoor Natural Gas Tankless...
Pegasus Technologies Pegasus F1225100BN Series 1000 Shower Only Faucet, Brushed Nickel Logo
310 people viewed this question
Top Pegasus Technologies Home Experts
john h
Jim Goldsmith
Jim Goldsmith
Paul Carew
Are you a Pegasus Technologies Home Expert? Answer questions, earn points and help others
