Quiet front R channel on Sony
My sony str-de875 has a very quiet front right channel. The left channel works fine but the right one outputting at 75% lower volume. Is there anything I can do, maybe tighten a loose connection? Or is the problem deeper than that?
  • numberedfilm Jul 15, 2009
    Yep. Even replaced the speaker wire. It's definitely the receiver itself.
  • 93 Answers
Does problem persist when you connect other speaker to front right channel? (i.e. when you connect your FL speaker to FR and vice versa)?
Posted on Jul 15, 2009
Str-gx800es sony receiver problem- right channel speaker sound is 'static', low and distorted. I have checked checked all speaker and output/input source cable connections with no luck. All left channel...
If you have checked the speakers and wiring, the right channel has a audio driver or output problem, which explains the low volume, static, and distortion. A service technician will be required to fix the receiver so it will balance the left side.
Jan 10, 2011 | Sony STR-GX800ES Receiver
Sony STR-DE875 receiver has no sound from right channel front or back. Checked for loose connections & blew out dust, no change
Hy all. I bought a receiver at last week. But the front speakers not working. The rele is jumping just.
i repaired them ! the rele colour is blue. Three percent . left first -Center, between -Surround, between(right Hand)-Front.
I moved the front channel's rele(right hand) .Katt -it sad. Working, volume is back. Rele specification is (colour Blue) Deg Greatings-Ranger of Hungary.10_26_2012_6_50_16_am.jpg
Aug 23, 2010 | Sony STR-DE875 Receiver
Right front channel not working
try to check balance adjustment if working.
Apr 16, 2010 | Sony STR-DE475 Receiver
Only one speaker working on my str-de675 receiver
If the speakers themselves work fine, then the problem lies within the amplifier output. The channels can go bad after hard use, they can be repaired but it may well exceed the cost of the amp if it is not just one channel. Also be sure that you are hooking up speakers that are rated for your amplifier by matching the OHM resistance of the amplifier to compatible speakers.
May 03, 2009 | Sony STR-DE675 Receiver
How do I hook up my philips 42ta648bx tv to a Sony receiver
SPDIF out is the Digital Audio output connection on the TV, take this and go into a Digital IN on your sony, select that input on the receiver and it shall pass Audio
Feb 01, 2009 | Sony STR-DE875 Receiver
One channel got quiet in the A speakers
try using the ground from speaker A TO SPEAKER B..which meaning ground your speakers on B jacks only.
Apr 11, 2008 | Sony STR-DE310
Sony str-de875 amp. one speaker louder than the rest
hi. i have a sony amplifier. i plug the speakers in like normal. i turn it on and the right side speeker works fine. but you half to crank it up all the way just to barely hear the left speeker. we switched speakers and its still the same effect. we think its the amp itself. we tried our balance settings. it was fine. but right now its just playing one speaker louder then the left one. can anyone help me?
Apr 03, 2008 | Sony STR-DE875 Receiver
The Output Volume Is Extremely Low!
Sometimes the rear channels can be used as a 2nd zone. Does the unit have A&B speaker selection on front panel? Usually if it has a 2nd zone it will say in owerns manual or on back of unit or on front panel as well. That is when you have the option to adjust the volume in the menu on the 2nd zone. GURU JAY
Feb 07, 2008 | Sony STR-DE545 Receiver
Sound turns off for Sony STR-DE875 amp
If you do not here a click as soon as the power is turned on, (note you must be in a very quite environment no noise absolutely to hear this) then the amplifier has blown output transistors which are pushing DC current to the speakers.
Aug 31, 2007 | Sony STR-DE875 Receiver
Sony Receiver has little sound on radio stations
have you adjusted your sound settings while in listening to the radio mode?
Jul 30, 2007 | Sony STR-DE875 Receiver
298 people viewed this question
 Grubhead
Grubhead
