Question about Nelson Sprinkler: Traveling Tractor
My tractor runs backward - Nelson Sprinkler: Traveling Tractor
You have to turn the sprinkler arms in the opposite direction to what they are. There is a diagram on top of the sprinkler.
Posted on Jul 16, 2009
My tractor will go forward or backward?
Is it your tractor won't go forward or backward? If so it sounds like the drive belt from the power takeoff pulley which is located in the front of the tractor and runs to the rear wheels is off.
Sep 23, 2014 | Garden
140 international tractor when turn motor off the motor runs backwards
It is called dieseling. Could be carbon on the plugs or in the combustion chamber. Carbon gets hot enough to cause fuel to keep igniting after ignition is turned off.
Apr 18, 2014 | Farmall International Tractor 140 Radiator
JD 110 tractor stalls when put in gear
Sound like a safety switch has gone bad. Either the clutch or seat switch are bad.
Mar 24, 2017 | Garden
KOHLER 25HP. WHEN ENG STOPS IT WILL RUN BACKWARDS THEN STOP
make sure the solenoid on the bottom of the carb is closing
Aug 27, 2012 | Garden
JD SRX75 - when push lever forward or back, tractor does not move..
check the lever on the rear of the tractor used to puch the unit when not running then check the belt
Mar 31, 2012 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
Started craftsman lawn tractor 24 hp kohler engine drove it a few feet engaged blade clutch and mower stopped. disengaged blade clutch tried to restart . engine turns over starts runs few a few seconds and...
You should be able to push it forwards as well as backwards. I had a similar problem (engine stalling) with mine. I found out if I half choke it, it will stay running. Transmission may still have a problem.
Jul 29, 2017 | Craftsman 24 Hp 48" Deck Yard Tractor
The tractor will not go forward or backward it starts right up but will not engage
1) The drive belt between the engine and transmission has broken or jumped off a pulley.
OR
2) Your hydrostatic transmission is dead.
DO NOT STICK YOUR FINGERS UP INSIDE A RUNNING MOWER TO SEE IF THE DRIVE BELT IS MOVING.
Jul 01, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Nelson Sprinkler:  Traveling Tractor Logo
305 people viewed this question
Top Nelson Garden Experts
Dennis
Mike Squire
Phil Walker
Phil Walker
Are you a Nelson Garden Expert? Answer questions, earn points and help others
