Question about Epson Stylus cx7450 All-In-One InkJet Printer
Hi...finally got my epson cx7450 cleaned and installed all cartridges...I was just doing a final check and now i get all lights on...I did add some cleaning fluid to the pad and pushed it down to clean out the ink...I wonder if i moved something or hopefully didn't break something..It seems that the ink carrage does not stay all the way to the right and the white plastic 'stop' does not pop up to the left of the carrage, and i get a little rubbing sound when it seems like it is trying to set up...makes me wonder...if you can help great..also is there somewhere i can view the internal parts and see how they should be set up..any help appreciated as this pringer has been a pain in the behind, all started with needing to replace ink and clean heads...wonder what you would recommend for inexpensive printer (brand? epson, hp, cannon or something else and model) thanks for any help or advice
  • 5 Answers
SOURCE: Epson Service warning
hi, try downloading the ssc utility (just google it). it lets you reset the ink counters, individual ink cleaning etc. once you've opened the main screen you need to right click to get all the other bits. hope this helps
Posted on Nov 30, 2006
  • 4102 Answers
SOURCE: epson stylus color 760 failing to print.
you can take it to repair shop and they will clean the head for you with some cleaning fluid if it has been without ink for a while sometimes these get blocked but it is not worth replacing cus would cost more than the printer as the ink cartridge you brought was originall then this isnt the problem check all cables if not better off buying new printer as these are not made to last long sorry couldnt be any,more help...........................
Posted on Nov 05, 2007
SOURCE: Epson Stylus Color 660 won't print in black
hi i want driver epson 660 in windows xp pls help me
Posted on Jun 08, 2008
SOURCE: Epson R230 ink & Paper Lamp Blinking
I have an EPSON STYLUS PHOTO R230 series.. INK and WASTE led were both blinking..i restted it already... but the last one.. i can't reset it anymore.. the printer is indicating and saying "Remove foreign Object in the printer" .. what posible damage it has.?. thank you
Posted on Oct 08, 2008
SOURCE: Epson Stylus Photo R800 Print Head Nozzles ??
Don't use nozzles clean function, besides ink consuming it can cause damages that cannot be fixed: black lines on the back side of the page that will be permanent. Instead put two photo paper together (2x260 gr) and push the two papers together into the printer while printing a motive including many colors. Do so a couple of times and the clogg usually disappears. Good luck! jonk
Posted on Mar 12, 2009
Hi there, Just changed all 4 ink cartriages on cx7450 and the ink light is still on, with the on light blinking thanks, rob
First push all the ink cartridges tide to the fram to assure that they are in the rigth position, then you have to alline them and it maby nessasary to clean the heads before printing.
Apr 10, 2011 | Epson Stylus cx7450 All-In-One InkJet...
How do i install ink cartridges on my epson cx7450
Follow this link to Epson's manual for your printer.
On the left, choose Remove and Install Catridges. It will guide you through it.
http://files.support.epson.com/htmldocs/cx74__/cx74__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Oct 30, 2009 | Epson Stylus Multifunction Inkjet Printer/...
My Epson cx7450 ran out of ink a while ago. I
Did you remove the cartridges when it went out of ink? If so, the printer head is clogged. Anyway, If you didn't remove the cartridges and the "a while ago" means "Long time ago", is more likely the printer head is clogged. You may need to run the "cleaning printer head" feature from the printer or replace the printer head.
Inkjet printers should be used frequently to avoid this issue.
Sep 06, 2009 | Epson Stylus cx7450 All-In-One InkJet...
Red light stays on after i changed ink? will not print
the red light shows an error/alert
make sure when you installed the cartridges
they are properly snapped inside
also check if the printer printed a test page
as it is must once you put the new cartridges
youmay also try uninstalling the cartridgesand turn of the printer,perform a power flee
turn it back on and install it one by one .
Jul 09, 2009 | Epson Stylus cx7450 All-In-One InkJet...
How to change cartrage for printer cx7450
The printer's control panel & menu where you should toggle thru until you find the setting to change the printer's cartridge.
It should tell you to now open up the top potion of the printer, This is because the heads must move into the correct position in which you can then remove the old cartridge and install the new one.
Best of luck and I hope this helps.
Jul 08, 2009 | Epson Stylus cx7450 All-In-One InkJet...
How to use only black cartridge on cx7450 epson !
Hi, this is not a solution because I don't think there is one apart from buying new inks. You need to consider 2 things, firstly the official line: Epson (and all other inkjet manufacturers) do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing. It is also why the "print in Black only" option (available on some printers) only works when the coloured inks are OK.
The 2nd unofficial line is that it is a win-win situation for manufacturers. Firstly they get to cut down on costly warranty call outs for blocked heads (replacement printers, technician manhours, etc) and secondly they get to sell lots more inks (Ka-ching!). If you really want to print black text only (and save cash on price per-print) then a mono-laser printer is the best way as they can now be bought at inkjet prices.
Apr 06, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson CX7450 paper jammed
In some cases, this is cause by a nozzle that got clogged during the jam. You can run head cleaning utility either from the printer or from the computer.
1. Make sure that there are no error lights (red lights), just a solid green light.
2. Take out all cartridges from the printer and put them back in.
3. Once the printer is done charging the inks and you have a solid green light again. Hold down the Ink Button for 3 seconds, after this you'll hear movements within the printer, this is the head cleaning process.
4. Once the printer stops making noises, and you have a solid green light again. Power Off the printer
5. Once the unit is OFF, hold down the paper button while turning the printer ON. Once you see the blinking green light release BOTH buttons. The printer will then print the nozzle check pattern.
* Note: The nozzle check pattern should display all colors in the printer and there should be no gap or break between the lines itself.
6. Do this step 3-4 consecutive times. and that should resolve you concern
Feb 21, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Printer epson CX7450
Hi altashll,
Printers can be such a headache. Your problem could be one of two things.
Change the Ink
First, your printer may just be low on ink and the cartridge needs replaced.
Clean the Print Head
If you are having the same problems after replacing the cartridge, you may need to clean the Print Head. This is easier than it sounds. All you have to do is press and hold the Stop button for at least 3 seconds until the On light starts flashing. Then release. You will hear the printer making quite a racket, but the cleaning should only last 1 minute (do not turn off your printer during this process or you may damage it permanently)
Good luck.
-SHG
Jan 13, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus cx7450 All-In-One InkJet Printer Logo
102 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
