Question about Uniden GMR-325/2 2-Way Radio Walkie Talkie Dual Pack
Can't turn on even when put new batteries i left it in the rain once though
    Problem Solver:
  • 6 Answers
You might of short circuited the battery terminals you may need to buy a new talkie
Posted on Jul 15, 2009
Phone in water
Hello;
This has worked for me before. I once mistakenly left my portable on the deck face up over night and it rained ( a lot)
DO NOT TURN ON TO SEE IF IT WORKS
Do NOT use hair dryer or warm air to dry it.
Remove battery and dry
Shake phone gently to get most of water out..
Dry phone as much as you can with absorbent material.
Even use a QTip in the battery compartment.
If you have any of those silica packages around from new shoes or electronics (those sandy white packages that say do not eat) wrap them around phone with elastics. These are desiccants and will absorb moisture.
Wrap phone in single layer dry absorbent material to keep dust out , secure with elastics
Put layer of rice in plastic container that is say at least 6 times bigger than phone - (doesn't have to seal perfectly) and put phone on top of rice.
Cover phone ie bury it in rice. An inch or two of rice around phone.
Put lid on
Put container with phone and rice in refrigerator. Cold air is much less humid than warm. If you have humidity control on frig turn to minimum humidity.
Leave for 2 days - longer is better.
Charge battery.
After taking out of frig let it warm up for a while so it doesn't feel cold.
Insert battery.
(Optional) Say prayer to whatever deity you choose
Hold breath
Turn on phone
Hopefully celebrate
Feb 05, 2014 | Samsung Galaxy SII Unlocked Android Cell...
Sunroof retracts fully and lifts but will not close tight on left side
you might be lucky and it just needs the cable greasing. in the mecanisme you will find a cable that is twisted and has brushes on it, use spray grease on this from one end to the other best to do both sides as the cable goes round. also grease the catches , then close the window and put to raised position and from inside spray grease into the arms on either side, run the window back and though though the settings a few times an repeat the greasing as you go.
Jun 18, 2017 | 2008 Ford Escape
The starter won't completely turn over even though
Sometimes on the Briggs and Kohler engines, the compression release fails to operate at the proper time or is malfunctioning. A remedy for this is to remove the valve cover(s) and adjust the OH valves per the manufacturers specifications. This enables much easier starting, produces less wear and tear on the starter and may allow your new battery to completely turn that engine over. Out of adjustment valves mimic a weak or failing battery quite well and the engine hangs up on the compression stroke because the compression release system is not working properly. Adjust those darn valves.
May 15, 2011 | Toro Titan ZX5450 (54") 25HP Zero Turning...
8391D left out in the rain!
If the battery was connected you probably shorted out the battery. Shake all water out of drill and let dry. get a battery that was not in water, try this. If still won't work you will have to bring to repair shop. If you try and take it apart it may be hard to put back together.
May 02, 2010 | Drills
I left my Sony DSLR our in then .. it didnt rain for a long time. When I finally remembered and went to pick it up it was completely dry .. we didnt turn it on and we took the battery out immediately .....
Hi!
You may keep it turned off until all the external parts and the battery compartments get dry. Furthermore, since the Camera has got wet in rain so there is possibility that rain water may have imbibed inside the Camera thus causing mechanical failure.
So, if the Camera doesn't turn ON even after drying it completely and charging the Battery fully. In that case, service will be required.
Aug 24, 2009 | Sony Cameras
Camera Left in Rain
First remove the battery immediately ..... second it depends to what extent the water has damaged the camera ..... take it to the repairman to check .... u r in for a huge estimate
Oct 17, 2008 | Olympus FE-230 Digital Camera
Rain drops falling on my phone
My God, you should have gotten a blow dryer immediately and dried the circuits. Not a hot heat, but a steady heat clean clear through. it has worked every time I dropped the phone in the toilet or the dishwater.
Jul 09, 2008 | Uniden Cordless Phone
SPS1 charging system
Borrow a multimeter and check the voltage (and current if you can) going to the battery while the unit is turned off. It should still be charging the battery if it's still plugged into the wall socket. If it is not getting about 13 volts, it's not going to charge the battery. If that's the case, then there's something wrong with the transformer, or another part of the charging circuit. The downside is you can't use the unit without the battery being connected. If the unit still works and sounds good even though it's not charging the battery, then just put the battery on a separate charger every week or so.(I use the SPS1 for my computer and love it!) Good luck with it. H.
Jul 30, 2007 | Scott SPS1 System
Batteries drains quickly
I had something similar, it kept saying "battery low" after putting in new batteries. Try the Clear method; Take out one battery, hold the Clear button, while holding it insert the battery again and press on, and release. Now press clear again, turn it off and turn it back on again. If that doesn't help... well it must be something else... sorry :S
May 30, 2007 | Texas Instruments TI-83 Plus Calculator
Uniden GMR-325/2 2-Way Radio Walkie Talkie Dual Pack Logo
127 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
