Question about NetGear RangeMax Premium Wireless-N Gigabit Router
When I try to finish setting up my USB2.0 adapter (WN121T) I receive a display of the following. The procedure entry point, DnsDhepRegisterInit could not be located in dynamic link library DNSAPI.dll.
  • donlaurie1 Jul 17, 2009
    Thanks for the advice, but I trying to install on another desk top, so I was unable to reinstall any adapters from on-line. I purchased a new wireless router and adapter and I'm all set.
    Thanks
    Don
    Sorry I did not realize that stating that the suggestion had a negative effect on your ratings, if I was trying to install the adapter for a lap top your advice would have been excellent.
    Don
  • 1,272 Answers
Reinstall the adapter using the latest adapter drivers from the link below:
http://kb.netgear.com/app/answers/detail/a_id/825
install the adapter using these drivers.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Jul 15, 2009
  • Anand Gupta
    Anand Gupta Jul 17, 2009
    Gud to knw tht the issue was resolved. And thx 4 those low rating.
  • Anand Gupta
    Well, U have selected the not helpful rating and that overall effected my rating Anyways, nothing can be done know. Happy to know that your issue was resolved.
Receiving error message: WlanMon.exe - Entry
Try a reinstall of the software sounds like that wlanapi.dll isn't being "Registered" If installing on Vista or Win 7 use Admin mode and try Compatabilty Mode for XP SP2.
Feb 03, 2010 | Blitzz Technology (BWA611) Router
Procedure entry point apsSearchInterface error message
Are you getting any led light activity or any kind of indication from Windows (sounds, beeps, chimes) that indicate that it is powering on / being detected?
Nov 24, 2009 | D-Link AirPlus G DWL-G122 802.11g/b...
WN121T Adapter constantly loses connection. Othe wireless adapters work fine without drops. I'm using Vista, driver version is 1.0.4.3 10/26/2007. Router is TP LINK (N)
Try swapping adapters from another of your machines, this one may be faulty. Location may also be a factor, try to locate so that antenna unobstructed from router.
Hope this helps
Feb 01, 2009 | NetGear WN121T (WN121T100NAS) Wireless...
Lexmark 4800 series reset printer to factory wireless settings
i have a lexmark printer its plugged in but dont have a icon to make it print
Oct 07, 2008 | Office Equipment & Supplies
Wn121t won't connect to the router
No Wireless Connection Found in Range
Note: You need to use a computer hardwired to the router to check the wireless settings.
1. Please open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. Click the Wireless Settings under Advanced tab.
5. Check the box under Enable Wireless Router Radio and Enable Wireless SSID Broadcast.
6. Click the Wireless Settings under Setup.
7. Change Channel (recommended are 1, 6 and 11).
8. Change the SSID to uniquely identify your network. You might have a similar SSID with your neighbor.
Note: Do not change the SSID if there are already other wireless computers that can connect to the network.
Other factors that you may consider when you are not able to view any available wireless network:
a. Switch for the wireless adapter is turned off
b. Distance between the wireless router and computer
c. Possible wireless interferences
Aug 18, 2008 | NetGear WN121T (WN121T100NAS) Wireless...
Sportrak color pc connection problems
It could be the setting on your gps or the cable could go bad. (Mine did) To test the cable - Instructions from Magellan FAQS - With PC data cable still connected to the unit power ON the unit and press both the ?Power? and ?Zoom Out? buttons at the same time and hold them down for two seconds. The following message appears: ?Test Serial Port Press Enter?. Do not press the ?Enter? button yet. Next, use the paper clip or jumper wire and insert the ends to Pin #2and #3. Pin #2 is the NMEA Positive (TX+) Transmitter; #Pin 3 is the DBR Positive (RX+) Receiver. While performing the cable test you will see a series of check points in each individual Baud Rate point. 1200, 4800, 9600, and 19200. Each point should display the message ?OK?at the bottom. If the user sees the initials ?NG? (NO GOOD) perform the test again. If the test continues to display the message ?NG? the problem may be due to a bad cable. When the cable test is finished press the ?Power Key? to power off the unit.
Jul 01, 2008 | Magellan SporTrak Color GPS Receiver
Hi there, I just bought a netgear Rangemax next wireless router WNR834B with RANGEMAX™ NEXT WIRELESS N USB 2.0 ADAPTER – WN121T with no installation CD and i have connected the router to my modem and its...
Get the driver for the WN121T from the NetGear webset and install it before pluging the adapter into the notebook. Use a wired connection on the notebook until you have the drive downloaded.
Jun 19, 2008 | Computers & Internet
Cesar.pratto@gmail.com
Hi , yes it's a known problem and Microsoft/DLink both has confirmed that.
Please download the updated drivers by clicking on the link. below. AS er your information your router's model no. is the 6th entry on the page.DWL-G630_revE. Download and re-install the drivers.
It will fix the problem
http://support.dlink.com/faq/view.asp?prod_id=3002&orig=1
For more information
http://support.microsoft.com/kb/950720
Jun 05, 2008 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
NetGear RangeMax Premium Wireless-N Gigabit Router Logo
73 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
