Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
Power light is flashing and it isn't working - Mitsubishi Mr. Slim MXZ30TN Air Conditioner
  • 3 Answers
Mine did the same when the freon went low
Posted on Aug 01, 2009
Hotpoint fdw60 4th & 6th lights flashing
These two lights indicate a fault in the heating circuit.
You would require to have access to and be able to use a multimeter to test the heater if the machine isn't actually heating the water.
If it is heating the water then obviously we know the fault isn't with the heater.
Check the heater first.
Take the door apart and check the wiring in the door isn't broken.
If everything checks ok, take the pcb out, look for burned or dry joints around the relays.
Nov 05, 2012 | Washing Machines
My nokia x6 camera flash isn't working anymore, i restore factory settings then the flash of the camera isn't working... plz help
This can be a hardware issue, failure of the circuit, the flash unit or the LED. In this case it is best to take opinion and support from Nokia care unless you are fully equipped to open and check and evenso the spare could be another issue.get estimate and proceed
Jun 28, 2012 | Nokia X6 16GB Cell Phone
Sometimes my tail lights stay on when the lights are not on and the engine is off. Sometimes one and sometimes both and it isn't the brake lights. In addition, sometimes one of signal lights will be...
Wow - electrical issues with Any motor Vehicle are frustrating. I would only suggest not one but two or three calls to dealerships that focus on your car manufacturer and after chats, select one that will trouble shoot the issue with out charge?
Jul 09, 2017 | 1999 Ford Windstar
I replaced the lamp now the lamp light on the frount of tv flashes yelow and tv does not turn on
The flashing yellow lamp light is indicating that the lamp door cover isn't installed properly or isn't contacting the door switch .
Aug 12, 2011 | Mitsubishi Televison & Video
My dell vostro 2510 won't power on, when i press power button to turn on the pc , the power light turn on for about 5 sec then it turn off itself,
Try this to see if can give us some codes with it's on board diagnostics. Hold down the function button of your laptop and then the power button while still holding down the Fn/Function button on the left side of the keyboard. See if this gives you either an error message on your screen or, flashing lights above your keyboard. Pay attention, write down what lights where lit up what ones flashed, etc. This is to diagnose if the LCD isn't working. Comment back if you get either the light code or the error code on the screen. IF nothing happens try holding the Fn/Function button on the left side of keyboard and holding the F4 button, see if that makes any lights flash above your keyboard.
Jun 18, 2011 | Dell Vostro 2510 Laptop
I have a Belkin F6D4230-4 and the wireless light was once flashing orange but now isn't working at all, why is this and what do i do to fix it?
Do a hard reset on your router by holding in the reset button (while it is powered on) for at least 30 seconds. Release the reset button and power off the router. Hold the reset button again for 30 seconds. Then power on the router.
May 22, 2011 | Computers & Internet
Screen black. Power light on unit flashes red slowly. Power light on switching adaptor power supply flashed green slowly.
Sounds like the battery might be low which would cause the red flashing light and dark screen. Let it charge for a little bit then try turning it on again. If it still does it with the power supply plugged in, make sure there isn't a lens cover on it, and switch modes or try getting into the menu to see if you can get anything to come up. If that still doesn't work then it sounds like there might be a problem with the camera.
May 03, 2011 | Cameras
Sony Grand Wega KDF-E50A10 Shuts off every minute and restarts. The Power/Standby light flashes. The bulb light does not flash. One Tech on here said it is a power problem and to replace the regulator on...
It is the lamp. The filament isn;t blown yet but separating when hot and reconnecting as it cools. Lamp light only flashes when lamp is actually blown
Sep 07, 2009 | Televison & Video
Power button failure
  • Power Light Shuts Off
    If the power shuts off during game play (even as much as 30 minutes after the system is turned on), then turns off and won't turn back on or the fan isn't working, the system needs repair.
  • Power Light Flashes
    If the power light flashes once when power button is pressed, then turns off and won't turn back on, the system needs repair
  • Sep 11, 2008 | Nintendo GameCube Console
    Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
    195 people viewed this question
    Top Mitsubishi Heating & Cooling Experts
    D. E. Hev
    MightyMikeJr
    Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
