Question about Zebra 110Xi III Plus Thermal Printer
Main logic board problem
Parallel port does not receive data
Sir,
Our printer 1410 is not working properly last 2 months because the when printer cable connect the all printers buttions lights are working, but not functioning. my friend said to me our printers logic board are not functioning because the moustiure creat to our logic board, so give me suggestion to next.
Posted on Sep 29, 2010
HDMI PORTS DONT WORK
You will need to replace the main video logic board, its part number is either EBU60852909 or EBU60852911. These two board are direct replacement parts. There are several boards available on Ebay such as this one: http://www.ebay.com/itm/LG-46LD550-UB-Main-BPR-Total-Assembly-EBU60852909-subs-to-EBU60852911-/150895037335?pt=US_TV_Boards_Parts_Components&hash=item23220b8b97
Sep 11, 2012 | LG 46LD550 46 in. LCD TV
Sir, i am learning embedded programming, i want to dump the program in the micro-controller through parallel port but there is no parallel port in my system. 1) if i buy usb to parallel port is it work as...
It would be better to use the USB to do this since Parallel ports are almost obsolete in today's computers. If you have an open expansion port you could put a parallel port card in the computer no problem but why would you want to? I would have to have a much better understanding of what you where trying to do to give you any other advice about Parallel vs USB vs FireWire. I have seen app's that use the serial port and parallel port as you are mentioning but these are tools for doing dead PC diagnostics and even most of those use the serial port because of the improves Bidirectional abilities for data flow.
Feb 20, 2011 | Intel DG31PR Motherboard
Tomtomxl340s won't start when plugged into car
Sounds like you have a broken charger, USB port or logic board. Try a different charger, inspect the usb port if it is loose. If both is not the issue, it's your logic board. There is a third party tomtom Repair service that will replace the logic board and a tomtom repair guide if you want to replace it yourself, the screen is available on ebay.
Jun 17, 2010 | Tomtom XL 340.S GPS Receiver
Tomtom will not switch on
This could be cause by a broken USB port, battery or logic board. If the port is loose, it need to be resoldered. If the port is firm and you don't get any reaction you it Looks like the logic board may need replacement. There is a third party tomtom Repair service that will replace the part. If you want to do it yourse, there is a tomtom repair guide , the screen is available on ebay.
May 16, 2010 | Tomtom ONE GPS Receiver
Sometimes when I'm printing, it will stop printing and show DATA PCL on the screen. I shut it off and back on and it prints garbage.....how can I fix this?? thank you
Try this if connected parallel:
This error may occur if you have a computer with an ECP port in Windows;
INCOMPATIBLE PARALLEL PORT PROTOCOL: During the PLUG n PLAY setup, Windows usually sets the parallel port driver for ECP mode if the computer's hardware port is set for ECP or, in some cases, ECP+EPP. Windows 95 will utilize data compression during ECP data transmission which can cause "garbled information" if the receiving device, such as a printer, is not ECP compatible.
SOLUTION:
Change the Windows Operating System's printer port driver (LPT.VXD) to the standard mode (non-ECP).
Windows XP:
1. Click on "Start", then "Control Panel.
2. Double click on "System:, and click on "Hardware", then click on "Device Manager"
3. Click on "Ports (COM & LPT)" section, and click on "ECP Port".
4. Click on "Driver", then "Update Driver"
5. Click "Install from List or Specific Location (Advanced)", click on "Next"
6. Select "Don't search - I will Choose Driver to Install", click "Next"
7. Select "Show Compatible Hardware"
8. Select "Standard Port" on the left window and "Printer Port" on the right window
9. Click on "Next" and Click on "Finish" and close all windows
10. Reboot/Restart your computer to ensure the changes are activated.
Mar 26, 2010 | OKIPAGE 14ex Led Printer
I want to know how the parallell port is configureg. baudrate. bitrate etc
The parallel port does not use bit or baud rate. These terms apply to not serial ports.
A complete description of the Parallel port operation is not possible in this forum, so I'll just highlight the differences.
First, serial transmits one bit at a time. Parallel means that all 8 bits in a byte are passed at one time. A parallel port can pass data at about 10K bytes (Standard) to greater than 1M characters per second depending on the configuration of the Port.
There are two types of parallel port connections. The Centronics or Standard Parallel Port (This is signal line activated and then is run by timing.)
For example, when the PC has data to send to the printer, it first checks that the parallel port is not busy, by testing the signal on the nBUSY pin.
If the printer is not busy, then the PC lowers the signal on the nSTROBE signal line. The printer sees the signal drop and waits about 500ns and then sets nBUSY to low and transfers the data to the printer. 500ns later, the printer will raise the ACK line and lower the nBusy line.
The high speed version of the port works off of the edges of the signals and does not use the timing delays.
For example, the PC will check the nBUSY line and if it is not busy, then it will lower the nSTROBE line. When the printer sees the nSTROBE line go low, it latches the data off of the parallel port and then raises ACK and lowers nBUSY.
So the difference between the High Speed IEEE1284 and the Standard or Centronics is the timing. Standard uses timing delays and IEEE1284 does not. Also, the IEE1284 protocol allows for communication back from the printer via the parallel data pins. You cannot do this with the Centronics port.
There are several forms of IEE1284 so yo8u have to know which forms are used by your PC. For example, I believe that HP PCs use EPP form and Lexmark uses another form of IEE1284.
Don
Dec 02, 2009 | Brother HL-2040 Laser Printer
Com1 port on a Zebra 105Sl not working, deleted & reloaded drivers still no go
Sounds like you have a bad main logic board. Unfortunately, the interface is built into the logic bd thus having to replace the main logic board assembly.
Please contact me if you have any question or if a board is needed. I have them in stock right now and can offer to do it on exchange for you bad one.
Please let me know.
Thanks
Rory Cardenas
Midrange Repair and Parts
Alsip IL 60803
708-597-4222 E240
rcardenas@mrp.to
AOL IM: RORYMRP
Jul 08, 2009 | Zebra 105SL Thermal Label Printer
Canon ImageRunner 2200 printing
the parrellel port is used also to updated machine soft ware.... if you do not have the print bootrom installed it will not print sorry
Dec 22, 2008 | Canon imageRUNNER 2200
No response from 105Se
if the data light comes on and nothing prints chances are that the serial settings are set improperly. all of my printers are 25 pin serial, not parallel. i don't have one in front of me but i believe the settings are 19200, 8, 1, none. hope this helps.
Mar 19, 2008 | Zebra 105Se Thermal Printer
Zebra 110Xi III Plus Thermal Printer Logo
109 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
