Question about Infinity BASSLINK Car Subwoofer
What cause subwoofer to make constant noise(loud)
What causes subwoofer to make constant noise(loud) when car is off
  • Brandon Griswold May 11, 2010
    Do you mean when the key is in the run possition and engine is not running? Id guess the amp is still powered all the time, run remote wire to ignition source if needed...
  • 24 Answers
Usely it turn out to be a ground issue make shure there are grounded with the PROPER guage of wire or heaver the required
Posted on Jul 27, 2009
What can cause a whining noise coming from 2003 mazda 6 engine?
That is commonly caused by a power steering pump issue, it is either low on fluid due to a leak in a hose or the pump is defective.
Oct 06, 2016 | Mazda Cars & Trucks
My 2001 xterra started making a weird sound between 20 and 35 mph. It sounds like there is a leak in some pressure system.
Common Car Noises and Their Likely Causes Noise More Details Likely Cause Fixing It Clicking noise while turning Starts faint, gradually becomes more noticeable until very loud Failed outer CV joint (constant velocity joint) due to torn boot (most likely) or old age Replace either the whole axle assembly (recommended) or the outer CV joint Water pump noises Difficult to diagnose because of water pump's location Noise usually caused by damage to the bearings in failed water pump Only cure is replacing it. If possible do it at the same time as a timing belt replacement to cut down on labor costs Squeak or squeal from an engine belt Loud, high-pitched squeak or squeal Belts either need adjustment or replacing If belts only squeak when damp, they probably just need adjustment. If they squeak constantly, they probably need to be replaced Exhaust heat shield noises Rattle that you hear when car is idling Damaged heat shield Replace heat shield
Sep 28, 2016 | 2001 Nissan Xterra
Why my 2010 Venza drive on sometimes while driving it sound like the transmission is in neutral
Sep 28, 2016 | Cars & Trucks
Why doesn't it make loud noise?
Dropping a speaker box/speakers may disconnect the internal workings/wiring of the speakers causing it to malfunction.
Mar 08, 2016 | Bose Audio Players & Recorders
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
Constant noise from Mirage NanoSat 5.1 System Subwoofer
sounds like an earth fault either with the plug circut or more likely with the power board of the unit.
Jan 06, 2010 | Mirage NANOSAT 5.1 System System
Very loud odd noise coming from radio speaker
There might be 2 probs
  1. The wires soldered to the the CD/FM input/output wires might have come loose leading to short/sparks causing the loud sound(constant).
  2. If there are any sockets requiring plug-in they may require cleaning with pure alcohol or rectified spirit(unlikely).
  3. The wire leads going to the speakers may be partially loose........................sodeep
May 11, 2009 | Car Audio & Video
JBL PB10 subwoofer, it makes a loud burp noise when it comes on.
In the industry - It is called "Turn-On Thump".
There are some manufacturers that eliminate components like noise filters on enry level lines to save money.
There is no way to lessen this noise without ripping the amplifier apart and having a technical knowledge of the way amplifiers work. It would involve hard-wiring a slow charge capacitor in the turn on line so it gradually builds power instead of getting it all at once.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 10, 2009 | JBL PB10 Subwoofer
Noise comming from centre speaker of panasonic scpt560 home theatre system
check the cable 1st. If this speaker is powered, you could have a bad shield, or the power is causing a ground loop.
If the speaker is coming from an amp using speaker wire ie: 2 lead + - check the connection and make sure no fraid strands are touching each other on the rear connection.
In addition check your TV, Ap, And speaker system (if sub is powered independently) are all on the same curcuit.
a certain cause for ground looping resulting in hum.
Jun 24, 2008 | Audio Players & Recorders
Open Questions:
See all Infinity BASSLINK Car Subwoofer Questions
Infinity BASSLINK Car Subwoofer Logo
816 people viewed this question
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
