Question about Hamilton Beach 67800 HealthSmart Juice Extractor 350 Watts
I can not disasemble the strainer from my hamilton juicer 395w
I can not remove the strainer from the juicer (hamilton 395 w) , it is attached to the juicer.
Can I get help?
thanks
omar
3 Suggested Answers
MomsyKat
  • 52 Answers
SOURCE: Looking for Manual
Try http://www.hamiltonbeach.com/use-and-care/use-and-care.php
Posted on Aug 25, 2008
SOURCE: how to remove strainer/grater from vitamin bar juicer
I am assuming your juicer is the same as mine. The JC-6 White with "Vitamin Bar" and a carrot on the front.
There is most likely a tool that you insert in the back slot, but since I don't know of one, I had to get creative.
First unplug the juicer and undo the side locks, remove the clear cap. Look in the back, there is a 2-inch wide slot where you can see the motor and locking mechanism.
Take a butter knife and hold the mechanism in place. Use your other hand or have a partner spin the mesh/bladed bowl counter-clockwise.
With just some effort and a small "pop" noise, the piece should be free.
I searched forever for a solution, I hope someone with a similar plight finds this helpful.
Posted on Aug 07, 2011
I purchased a Hamilton Beach juice extractor, Type CJ01, Model 395W from a thrift shop. No manual available. How do I remove the circular blade cup to clean?
The solution i have found is relatively simple, but going to take a bit of handy work.
first, it would greatly help to remove the bottom from the unit. You will need to remove the 4 rubber pads, and then the 4 screws. 2 of the screws are way up there and need a thin philips.
Regardless if you removed the bottom, you will need to drill a hole right in the center of that circular grill on the bottom piece.
If you did NOT remove the bottom piece, I would take a nail, clamp it with vice grips, get it red red hot off the burner, and burn away that center plaster to create a hole. So whether you drilled the hole (with the bottom removed) or burned the hole (with the bottom intact), you will see the bottom of the motor has a slot head.
Now, all you need to do is take a thin blade screwdriver, or thin butter knife into that slot, holds the motor, then twist the blade right off...or on...whichever the case may be.
Hope this helps...sure helped me!
Oct 30, 2010 | Hamilton Beach 67800 HealthSmart Juice...
Juice extractor 67800 350 Watts, The problem is the cutter strainer gets stuck and I can only get it off after much effort and struggle, is there a simpler way ,Margaret
As soon as I had described the problem I found the solution. A smear of olive oil around the inside of the base of the cutter, and around the seating of it, on the unit. And it worked. No problem.
Nov 04, 2009 | Hamilton Beach 67800 HealthSmart Juice...
Strainer for Juicer 7001
CALL WARING AT 800 492 7464 OR COST
PLUS JUICERS AT 800 578 5939.
Mar 31, 2009 | Acme 6001 Juice Extractor
Looking for Manual
Aug 25, 2008 | Hamilton Beach 67700 Fountain Juicer
How do u wash this?
if you have a jack lalanne it comes with an orange handle that fits into the sharp cutter and you twist it to tighten/loosen the blade. hope this helps
Dec 04, 2007 | Juicers
Hamilton Beach 67800 HealthSmart Juice Extractor 350 Watts Logo
102 people viewed this question
Top Hamilton Beach Juicers Experts
David Payne
David Payne
eyecam
Are you a Hamilton Beach Juicer Expert? Answer questions, earn points and help others
