Question about Coleman Roadtrip Grill LXE 9949-750
Changed gas tank - will not light - does not seem to be getting gas.
  • 57 Answers
Bad regulator go to home depot or lowes to get one
Posted on Aug 27, 2009
I changed the gas tank, with two different ones to be sure it wasn't the tank. The ignitor parts but there does not seem to be gas getting to the burners.
It is possible you are just turning the gas valve on the tank too fast, causing the excess flow valve in the line to "check" or close. Disconnect the hose from the tank and then reconnect it. Then slowly open the tank valve and see if that solves your problem.
Jun 09, 2015 | Ducane 30400040 Stainless Steel Grill
2000 toyota 4 runner. Has no power. Sounds like it isn'tt getting the gas. changed fuel filter,plugs
Bad gas or diesel in tank???
getting misfiring on all cylinders and coils won't ever fail at same time. Usually only 1 at a time.
don't ever replace the fuel filter. only if it has lack of power on highway speeds.
Apr 04, 2014 | 2000 Toyota 4Runner
Car engine vibrates at 45 mph after letting of gas going up hills
A bad cat will glow when vehicle is at normal operating temperature.
vaccum leak, tune-up?
Oct 28, 2017 | Cars & Trucks
Dash gas gauge stops showing proper gas level once it hits half a tank. Then gauge will fluctuate between empty (light will come on), full and anywhere in between but seems fine from full tank to half
If the trouble with the gauge started after you worked on it then you likely damaged or created a restriction to the movement of the sending unit. You will have to remove the tank and double-check your work.
Mar 01, 2013 | 2000 Buick LeSabre
I can't get any burners to light. I have changed tank,regulator,and cleaned burners. When I open regulator all the way and I use match. A small puff then out. It seems simple but can get it to work....
The problem you're experiencing is cause by one of two things. Low gas in the tank or a locked up regulator. To solve the problem, do the following:
To solve this problem, first be sure you have adequate gas in the tank. If that checks out OK, do the following:
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling!! Thanks for choosing FixYa.
Sep 20, 2011 | Char-Broil Designer 463261106 Grill
When I changed my gas tank, the gas flow would not
Make sure you didn't turn the gas tank valve on too fast. Some gas hoses have a built-in excess flow valve that stops the flow of gas to a trickle if opened too fast. Close the tank valve, disconnect it and reconnect it. Turn the tank valve very slowly and then try lighting it again.
May 15, 2010 | Grilling
Truck runs great and drive on freeway wants to cut out then miss and runs great again. changed plugs wires cap and rotor prior to problem 1996 nissan pickup 4 cylinder
seems that you might have some water in the gas tank. get some gas dryer and pour in the tank. 2 half pint bottles should do to a half tank of gas. good luck.
Nov 08, 2009 | 1996 Nissan Pickup
88Ford E150 fuel injected 5.0 L
maybe you got water in your tank
Jul 07, 2008 | Ford E-150 Cars & Trucks
Coleman Roadtrip Grill LXE 9949-750 Logo
227 people viewed this question
Top Coleman Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
