Question about Gaggia Carezza Espresso Machine
Where are the high and low ports for AC system on a 2002 Hyundai Elantra?
  • 25 Answers
Follow the lines from the compressor.  One will go toward the front of the car, and this will be the high side.  The connector will almost always be on the compressor, or within two feet.  The other line, the low side is usually larger, and goes toward the firewall.  That port will be anywhere from ON the compressor, to  where the line goes through the firewall, although rarely past the drier.   I couldn't find anything specific for your vehicle....
Posted on Jul 15, 2009
Headlight fuseable link and relay for 2002 Hyundai elantra location
No fusiable link , reg. fuse's located in the under hood fuse / relay box.H/LP low 15 amp fuse also Headlamp relay low . Both high an low headlamps not working ? H/LP (high) fuse 15amp plus HEADLAMP RELAY (high) . Should be marked on the inside of the lid !
Feb 26, 2017 | Hyundai Cars & Trucks
Where do i put the engine coolant into in my 2002 hyundai elantra
On the radiator,next to cap,there's a hose,follow it,goes to the over flow tank,has a high low mark on it,just remove cap and add.
Feb 02, 2013 | Hyundai Motor 2003 Elantra
Where is the port to charge the ac on a 2001 hyundai elantra gls
High side should be on the right side of engine, just under the plastic cover, low side is the same side, almost against the fire wall just behind engine.
Aug 01, 2010 | 2001 Hyundai Elantra
Need air cindition recharge, don't have cash to take it someplace, can you help with instructions to do this
YOU NEED A R-134 GAUGE SET TO CHECK LOW PRESSURE SIDE AND HIGH PRESSURE SIDE.YOU ALSO CAN BUY A LITTLE CHEAPER GAUGE TO CHECK YOUR AC LOW BLUE SIDE AND HIGH RED SIDE AT ANY AUTO ZONE OR ADVANCE AUTO PARTS.WHAT YOU DO WHEN YOU GET YOUR GAUGE SET HOOK GAUGE TO LOW PRESSURE SIDE BLUE CAP PORT AND GAUGE TO HIGH SIDE PRESSURE RED CAP PORT.YOU CRANK CAR UP GET IT OPERATING TEMPERATURE.THEN TURN AC ON HIGH COOL LET RUN 3 TO 4 MINUTES.CHECK LOW SIDE GAUGE READING SHOULD BE 28 - 32 PSI. HIGH PRESSURE SIDE GAUGE SHOULD 199 - 228 PSI. THATS NORMAL CHARGE. SEE YOU CANT JUST RECHARGE AC SYSTEM UNTIL YOU CHECK IT FIRST YOU WILL DAMAGE SYSTEM .NOW YOU CAN GO TO AUTO ZONE PARTS BUY A CHARGE CAN WITH GAUGE AND HOSE.ATTACH TO IT.YOU NEED MORE THAN ONE CAN.WARNING MAKE COMPRESSOR IS RUNNING WHEN YOU TURN ON AC .BECAUSE IF COMPRESSOR NOT RUNNING CHECK FUSE AND AC COMPRESSOR RELAY.IF BOTH OKAY.YOU COULD HAVE OPEN CLUTCH COIL A FAULTY LOW PRESSURE SWITCH WILL CAUSE AC NOT TO WORK. IF LOW PRESSURE GAUGE BLUE SIDE PRESSURE IS 28 OR 30 YOU DONT NEED A CHARGE.PROBLEM SOME WHERE ELSE.BE SURE TO WEAR SAFETY GLASSES WHEN WORKING ON AC SYSTEM.
Jun 26, 2010 | 2004 Hyundai Elantra
Where is the A/c low pressure port and A/c clutch in a 2002 hyundai elantra gls? Is it labeled anywhere? I believe I need to add refrigerant but I am not sure where and I can't afford at all to take it to...
YOUR LOW PRESSURE PORT IS USUALLY FOUND ON THE ACUCULATOR AND IT COULD BE THE COLOR BLUE OR LOCATED CLOSE TO IT. THE A/C CLUTCH IS ON THE A/C COMPRESSOR WHICH IS CONTROLLED BY ONE WIRE. CHECK FOR FUSE FIRST BEFORE SAYING THAT THE CLUTCH IS BAD
Oct 23, 2009 | Hyundai Motor 2002 Elantra
Hyundai elantra 2001,A/C sistem:where is the low-side service port located.Thanks!!
ac low side service port is on the large line/hose follow the line/hose from compressor untill u find it it is the large line/hose with the small service port/it may even be right on the compressor
Jun 30, 2009 | 2000 Hyundai Elantra
How do I add coolant to the air conditioning system of my 2001 Hyundai Elantra?
You need to locate the low port on the AC.
You recharge the AC connecting to the low port.
You find the AC low pressure at the top of the compressor. Near the compressor you find two ports, the high port and low port.
You can follow the compressor line to reach the port.
To find out which one is the low port, run the air conditioner for a couple of minutes withthe engine on.
Then turn off the care and touch the lines from compressor to the two ports , often covered with plastic caps. Only one of the pipes will be cold, the line that is cold will lead you to the low port.
Jun 18, 2009 | 2001 Hyundai Elantra
Recharging ac on 2001 hyundai sonata gls
No picture to show you, but it's on the right hand side in the engine bay either near the power steering pump reseviore or near the firewall (or somewere inbetween). Anyway, chargine the AC system is done at the "HIGH" side port (not the low side). I assume when you say 'fill' the unit, you're talking about "Charging the System with Refrigerant'?
May 07, 2009 | 2001 Hyundai Sonata
Adjustment headlights '02 Hyundai Elantra
The adjustment screws/nuts should be located either on the top of the headlamp assembly, behind the headlamp assembly, or near the frame rail by the radiator support.
You will have vertical adjustment screws for each independent beam (separate highs and separate lows, but will be same screw if highs and lows are the same bulb). You may also have additional horizontal adjustment screws as well
Park your car on a level ground 30 feet from a wall and measure the height from the ground to the bulb and mark on a wall (do this for highs beams and low beams if the bulbs are separate, if highs and lows are the same bulb, only do it for the lows)
For Low Beams: If the headlights read VOR, then aim the brightest part or cutoff part just below the mark on the wall. If it says VOL or nothing, aim them 2 inches below the mark on the wall.
For High Beams (if separate from low beams): Aim the headlight directly at the line you marked on the wall.
Jan 23, 2009 | Hyundai Motor 2002 Elantra
my 2002 elantra gls sedan started blowing hot air and overheating and it turned out when i took it to the hyundai dealer it was my thermostat they replaced it and i was good to go.it happened at about 40,000 miles hope it works out for you
Jul 16, 2008 | Hyundai Motor 2002 Elantra
Gaggia Carezza Espresso Machine Logo
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Michael Vincent Cruz
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
