Question about Frigidaire ATF6000ES Front Load Washer
Frigidair Affinity quit spinning
I did one load of laundry this morning and it was fine. Second load- it appears that it won't drain or spin. I thought maybe the load was uneven so i took the clothes out and tried to drain the washer on the "spin only" cycle. It spun a couple times, added more water and stopped. The motor sounds fine- but its not moving and there is standing water in the machine. This washer is 13 months old. The warranty expired last month.
  • 2 more comments
  • EmmaJane Nov 17, 2007
    I think you're right about it being an issue with draining. I unplugged the machine, waited a while, and then restarted a "spin only" cyle. The machine seems to be draining very slowly. I took off the outlet pipe and checked for blockages but it seems clean. Could it be blocked somewhere internally? Also, it spun for a very very long time...much longer than normal. When i took out the clothes and loaded another load in, the machine sounded like it was draining before water ever started going into the machine. Any suggestions? Could some piece of clothing have somehow gotten into the machine?
  • EmmaJane Nov 18, 2007
    Thank you for your suggestions. First thing this morning we are going to check to see if the pump is blocked in any way. The washer seems to be draining very slowly, almost trickling through the outlet pipe and I don't remember it being like that previously. I have tried taking off the outlet pipe and it appears to be clear so maybe the blockage is internal. If that doesn't work, then we will check the belt but it seems to spin fine again. The error code that flashed was E21. That code refers to drainage, correct?
    There appeared to be a little blockage in the outlet pipe and some junk in the hose that leads into the pump so I cleaned that out and restarted the washer on the quick cycle which is 33 minutes.
    The washer did fine until 17 minutes. Then it quit spinning and just sat but it sounded like it was supposed to be agitating. It stayed like that until 15 minutes and then the error code e20 appeared again. After canceling out the cycle, I ran it on "spin only" and it worked like it should- added some water, went into the spin cycle and finished. I'm not sure what this means. Do you have any ideas or is it time to call in a repairman?
  • EmmaJane Nov 20, 2007
    Thank you. You were in the money with the fluff and other stuff blockage. The lint/coin trap was full! Your advice saved us a lot of money. We were going to have a repairman come out today but the washer runs great again. Thanks again for your help!
    Sergeant:
    Champion:
  • 298 Answers
You said the motor sounds fine but it isnt moving
do you see anything that resembles a belt anywhere
the pump may be belt driven in which case you will
either get a part# for the belt or get the old belt and
match it up
Posted on Nov 17, 2007
  • 4,102 Answers
It osund like the machine isnt draining the water witch could be one of two things it could be that the outlet pipe is blocked between the machine and where it goes into the outlet in the wall this will need chcking and making sure there is no blockage the other problem is the pump has gone and this will cause the washing machine to cut off or there could be a build up of limescale witch could cause the machine to cut off as a safety precaution hope this helps you if you want to do it yourself you can check all pipes and remove these and replace as this is easy enough to do but to replace the pump this is an expensuve option and can be difficult to replace hope this is some help to you you could try leaving machine unplugeed for a couple of hours and this will reset the timer then try the mnachine if it is a intermitant problem then it could be that you need to replace the timer
  • 1 more comment
  • paul proctor Nov 17, 2007
    is it a belt drive at the back if you feel confident in taking the back off have a look and see if the belt is lose these become streched and can be replaced but if it is blocked some times you can get a bit of a sock go through and block the pipe i have had thsi happen check the belt first and see if it is tight does it punp any water out or none at all as does it sound like it is draining or not if you have anymore problems post back and i will have another look for you hope this is some help to you...................
  • paul proctor Nov 19, 2007
    if the machine sounded like it was trying to turn the drum ie when you said it sounded like it should be agitating the wash then this could be a problem with the belt slipping if the belt slips it will come up with an error problem do you know when it drains the water does it spin to get the water out of clothes or not the first error coed is to do with drainage so check that it is not blocked anywhere in the pipes but if like you said that the machine sounded like it should be agitating the wash then it could be one of two things it could be either the belt has become strtched or brittle and is slipping during wash or spin cycle or it could be that the bearing on the drum is on its way out and needs replacing this you cant do yourself as they need a puller to get old bearing off but first i would check for blockages as if the water stands in the machine after the drain cycle it will cut off so if you are sure of no blockages and still plays up then i would call someone out to check the belt and bearing foy sorry couldnt be anymore help good luck
    it could still be something blocked i have contacted a few friends who know about this and they said it could be a build up of fluff off the clothes they said it could even be if you put something in with a string in it like tracksuit bottoms with the string that you tie up even this can work it way into drainage and block the pipe along with a build up of fluff off clothes make sure their is no blockage before you call someone out as you dont want to be charged with unblocking a pipe as their getting money for nothig just make sure you check properly for blockages before you think about calling someone out you could even look in local phone book and some people will come out and give you a free estimate therfore they tell you what problem is and you can decide wether you let them do it or as they have told you what is wrong maybe you could even do it yourself hope this is some help good luck
My Frigidaire Affinity front loading washing machine model #ATF6000FS1 won't spin when loaded.What's the problem?
sounds like you have something in your pump stopping the water draining it will not spin with water try unblocking the punp
Sep 27, 2012 | Frigidaire Affinity Washing Machines
My frigidaire affinity pauses during the cycle and won't drain
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 13, 2011 | Washing Machines
When doing a load of laundry the washer will stop at the rinse cycle and not drain or spin out the excess water
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Jan 03, 2011 | Frigidaire Affinity ATF6000F Front Load...
My laundry not spin
heatman101
Oct 12, 2010 | Frigidaire Affinity ATF7000E Front Load...
Washer won't spin
Check to see if the strainer before the pump is partially clogged.
Sep 11, 2009 | Frigidaire Affinity ATF7000E Front Load...
Spin/rinse cycle
find tech sheet at bottom of washer and follow instructions for checking motor controller (at bottom rear)
Apr 13, 2008 | Frigidaire Affinity ATF7000E Front Load...
E70
All w/machines have a maximum load capacity. Look for yours in the users'manual. Overloading could give you problems, bearings, etc. Your machine cld even have a half load switch.
Mar 26, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
62 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
