Question about OKI C5400tn Laser Printer
Printer for Envelopments Metallic Card Stock
I am looking for a printer that will print well on Envelopments paper and card stock, including their metallic paper and card stock line. Can anyone please recommend a printer that will work for my stationery business? Thank you so much!
I recently purchased an OKI specifically for my stationery business as well (using metallic cardstock) and the company told me that no OKI printers work on metallic paper... I am STILL on the search for an invitation printer! Its frustrating to say the least....
Posted on Mar 16, 2011
I have an HP Photosmart A646 printer that I bought in the hopes of printing to 5x7 card stock. We have pre-printed card stock that we use for gift certificates and we need to be able to feed the card stock...
Thanks for visiting FixYa!
Depending on the program you are using to print your gift certificates, try this-
1) Open the program and open the file you use for your gift certificate.
2) Click on 'Layout' then 'Page Set Up' (probably found in the top menu bar by the right side of, FILE.)
3) Select 'Landscape' and then select, 'Custom'.
4) Enter 5x7 for height and width.
5) Enter the information you need in the data field, (ie, name address, etc.)
6) Select, Print.
7) When the 'Print Manager' box opens, click on, 'Properties'.
8) Click on, 'Type' and choose, "Envelope'.
9) Click on, 'Size' and choose 5x7. - and click, OK.
Your printer should have a slide where the paper is inserted. Place one of the 5x7 cards in the slot just as you would an envelope and slide the slider until it is 'close' to the card but not directly against the card.
Click, 'Print'. The printer should recognize the card (due to its thickness) as an envelope and print it.
Mar 19, 2011 | Office Equipment & Supplies
Printer streaks on card stock
adjust your thickness guage as card stock is 3 or 4 times thicker than a 20lb plain paper stock. Here is link to a helpful media guide for HP printers.
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/bpl05339/bpl05339.pdf
Jan 30, 2010 | HP Color LaserJet 2600n Printer
Will this printer print on heavy card stock and
Yes the 2600 will print on heavy card stock and vellum paper. I had one and did some landscape proposals on this printer and also printed on card stock as well.
Oct 17, 2009 | HP Color LaserJet 2600n Printer
The printer will not pull card stock paper through. It will print on regular printer paper but will not pull the card stock paper for business cards through. What could be causing this?
Usually the stock is too thick to process properly.
Go to a lighter stock or buy a more robust printer if you are going to do a lot of that type of work
Aug 08, 2009 | Brother MFC 210C All-In-One InkJet Printer
Paper jams with thicker stock paper
Your pickup tires on the printer may be worn, how many prints have you made on this printer. it may be time for a maint. kit.
May 31, 2009 | Brother MFC 210C All-In-One InkJet Printer
Printer will not pick up card stock - aaaghh!
Try cleaning the rubber roller tha picks up the paper with some alcohol and a rag.
Apr 24, 2009 | Lexmark C510 Laser Printer
Brother laser printer wont print on cardstock My brother printer won't feed teh card stock paper. It used to work but now it won't feed it, normal paper works fine. Even if i nudge the card stock paper,...
If there printer is not able to print on card stock then check the recommend
card stock paper thickness, if the printer works with normal paper but not card stock then there is problem in the card stock and by using this paper may also damage the rollers on the printer and make the printer useless ...
Good luck...
Feb 09, 2009 | Brother MFC-5840CN All-In-One InkJet...
I have a Dell 946 printer and Im trying to print Avery 8871 business card sheets. When I press print the printer will not feed the sheet through and it says there is no paper. I tried to adjust the...
I looked up the user guide at Dell's website and looked up printing cards.
  • The print side of the cards faces down.
  • The cards are centered on the paper exit tray.
  • You select Automatic, Normal, or Photo print quality.
  • Apparently you need to feed the card stock one page at a time into the printer on TOP of the paper exit try (The card stock will feed in from above the normal paper load try [remove paper from the paper tray] and once printed come back to the same spot.
    Jan 26, 2009 | Computers & Internet
    HP C4280 incorrect paper feed
    Check your printer's capability.
    Buy the card stock they recommend.
    If all else fails, print on plain and take card stock to a copy shop and have them do it for you.
    Walking there beats going nuts over stupid software or hardware problems
    Dec 16, 2008 | HP PhotoSmart C4280 Laser Printer
    Blinking yellow light
    I m not sure what the specification of the paper type you are using however if you are using card stock than you should use manual feed Tray and in the printer driver properties you should select paper type as Card-Stock to make sure there is no print quality issue.
    Nov 30, 2008 | HP Color LaserJet 2550n printer + HP Color...
    OKI C5400tn Laser Printer Logo
    403 people viewed this question
    Top OKI Office Equipment & Supplies Experts
    WTF Chuck.....
    WTF Chuck.....
    mukhtar21 shaikh
    mukhtar21 shaikh
    SiNnA
    SiNnA
    Level 1 Expert
    Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
