Question about RCA P52937 52" Rear Projection Television
I have no front control panel working and changes channels
I have no front control panel working except the power switch and the channels keep changing on its own from 77 to 98 to some other channel constantly and my remote does not work. Thankyou
    President:
  • RCA Master
  • 1,779 Answers
The front controls are called Tac Switches. They have a tendency of becoming corroded and sending erroneous commands to the micro. You can disconnect the lead coming from the control panel to the chassis and see if it quits. If it does, that answers your question. If you decide to replace them all, try Encompassparts.com
Posted on Jul 15, 2009
I have a Panasonic TH-42PX50u that suddenly is stuck on one channel and no volume control either. Same whether using remote or on TV. Only turns on and off no other control.
Try changing the input device to something you are sure, works such as a DVD player. Look for any loose contacts in RC jacks/sockets/Cable. Look for jammed buttons on remote and/or on control panel. Try removing the batteries from remote and operating from the control panel of TV. If these are ok, Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Aug 06, 2012 | Panasonic TH-42PX50U 42 in. Plasma HDTV
35GT740 television
Have you tried to unplug the TV set for a half hour or so? If not see if that helps reset the set. If that does not work, make sure that none of the front panel channels buttons on the front of the TV set is not pushed in and stuck. Or if all this is checked and the TV set still scrolls, there is a problem in the remote sensor, or the front panel board will need to be replaced. Good Luck
Sep 10, 2007 | RCA 24V511T 24" TV
Cant get cable tv
Hello
First connect the cable to its cable input socket at rear.
Turn the tV On and enter its Menu option window. Press UP or DN button on the remote control to select 'Cable'. Selecte EZ scan [channel search]. The TV must scan for all available channels, and will stop after all the channels has been stored in its memory. You have to wait till the search function stops; no other functions with remote cannot be done, and the set will not respond any external command, either by remote control or by its front panel control, except the mains power ON/OFF switch will work. OK.
Nov 21, 2011 | Zenith Z50P3 50 in. Plasma TV
My aiwa tv-- A219 is showing message AGING 19DCH in red color and nothing else except dispaly button is working.pls help me
my aiwa tv-- A219 is showing message AGING 2F01H in red color and nothing else except dispaly button is working.pls help me
Nov 11, 2010 | Aiwa F2000 20" TV
I have no control over the channel selection; the channel keeps changing and I'm powerless to stop it. The issue is not with the remote; the same thing happens if I attempt to tune to a channel manually on...
The problem is likely with your front panel control buttons - the CH up button (tact switch) is stuck on (shorted or changed value). In order to temporarily correct the problem remove the Ch up switch that is located on the front panel control board - it would have to be unsoldered- and then when one is available replace the "tact" switch.
Sep 27, 2009 | GE 31GT740 31" TV
Power button changes channels and volume does not work
bad solder connections. front control panel.
Nov 23, 2008 | Philips 27PT543S 27" TV
Toshiba 35a44 problem
check the following power supply components
power transistor of the supply
zener diodes
rectifier diodes
Oct 15, 2008 | Toshiba 35A44 35" TV
Channel keeps changing
it seems to be continusly scanning channels and never ends
Jun 28, 2008 | RCA F32649 32" TV
Front controls mixed up & remote doesn't work
the channel down button is stuck on, you need to replace this switch internaly to the set.
Nov 14, 2006 | Sony KV-36FS100 36" TV
Channels keep changing
ok, let's try the simplest things first.... unplug the tv from the wall, and remove the batteries from the remote. wait about 5 or 10 minutes. reinstall the batteries and plug the tv back in. try it again. actually since you said you tried another remote, you can skip removing the batteries from the remote. if it still does it, try unplugging the tv overnight. if it still doesn't work right then, you have a processor problem, and need to have it looked at by a service tech.
Jul 07, 2006 | Toshiba 36A40 36" TV
RCA P52937 52" Rear Projection Television Logo
188 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
