Question about Mitsubishi VS-50607 50" Rear Projection Television
VS 50607 50 inch
The TV presents the code 2-3. The tv will not turn on now. Is this a fix I can do or does it require shop time?
  • 1,153 Answers
Deflection Protect is the problem. You can check C411 and C412 on main board to see if bad. More info
Posted on Dec 25, 2007
Color distortion, hazy snowy screen with thin red lines, suddenly happened had perfect pic 24 hours ago
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board is dead.The tv convergence board require replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Feb 01, 2011 | Mitsubishi VS-50705 50" Rear Projection...
Mitsubishi vs-50605 TV can't turn on
You need to try self test, this is when you press the Menu and Device/Input button on panel at same time for 5 seconds then release and you should see a 2 digit sequence. Blinks then short pause then more blinks, count them and then you will come up with the error code. If you have an error of 2-3 or 2-4 you need to replace C411 it's a 2200uf @ 35v and C412 10uf @ 50v both on main board!
Jan 11, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi parental lock removal/v-lock redo
Color Televisions
CS-20EX1, CS-20301, CS-26EX1, CS-26201, CS-26301, CS-2725R, CS-27EX1,
CS-27MX1, CS-27TX1, CS-27200, CS-27201, CS-27301, CK-27304, CK-27306,
CS-27401, CS-27403, CS-3135R, CK-3136R, CS-31AX1, CS-31FX1, CS-31MX1,
CK-31MX2, CS-31301, CK-31302, CS-3525R, CK-3526R, CK-3527R, CS-3535R,
CK-3536R, CS-35X7, CS-35AX1, CS-35FX1, CK-35FX2, CS-35MX1, CK-35MX2,
CK-35MX3, CS-35201, CS-35201A, CS-35203, CS-35205A, CS-35301, CS-35401,
CK-35402, CS-40FX1
Projection Televisions
VS-40VA2, VS-4517S, VS-45VA1, VS-45VA2, VS-4561, VS-4562, VS-5016R,
VS-5017S, VS-50VA1, VS-50VA2, VS-50VF1, VS-50VF2, VS-50VX2, VS-50VX3,
VS-5061, VS-5062, VS-6017R, VS-6026R, VS-60VA2, VS-60VF1, VS-60VF2,
VS-60VX2, VS-60VX3, VS-6061, VS-7017R
This system locks only the entire TV. The TV will display a screen that
will indicate "Parental Lock ... Now the lock is on" and request the
personal four digit code when the TV is powered on.
IMPORTANT> You must use the original remote control that came with the
TV to release the Parental Lock, you cannot use a remote
that came with a VCR, Audio System or from any other
1. Depending on which remote came with your TV, press the button at
the top labeled TV,OR set the TV/VCR switch in the upper left
corner of the remote to the TV position. .
2. Press the button on the remote labeled POWER.
The TV will turn on and display an information
screen that indicates "Parental Lock ... Now the
lock is on" and ask for the four digit personal code.
3. Press the #9 and the QV buttons at the same time.
The TV will turn on.
4. Press the button labeled MENU.
The "TV Main Menu" will be displayed.
5. Press the ADJUST UP or DOWN button to move the arrow next to the
"Advanced Features" selection and then press ENTER.
The "Advanced Features" menu will appear and
indicate that the lock is ON.
6. Press the ADJUST button to move the arrow next to the "Parental
Lock" option, and then press ENTER.
The screen will change to indicate "Parental Lock
... Now the lock is on" and ask for the four digit
personal code.
7. Press the #9 and QV buttons at the same time.
The screen will return to the "Advanced Features"
menu and indicate that the lock is off.
8. Press the MENU button twice to return to normal viewing.
The original lock code has now been erased and the lock canceled.
on May 16, 2010 | Audio Players & Recorders
I have a mitsubishi VS-50801 rear projection TV that has a very distorted and glichy picture
Ur tv convergence are dead.Ur tv convergence board require changing the 2 STK convergence ICS,and some or all it resistors.The shop will cost u $300-$350 for parts and labors.
May 19, 2010 | Mitsubishi VS-50805 50" Rear Projection...
Mitsubishi VS-60705, Turns on/Turns off.
Unfortunately you will need an experienced TV tech.
This unit will need 2 ICs STK392-110 for 1 has shorted and caused damage to the 2nd as a result blowing 1 or 2 pico fuses in the power supply.
It is an involved job and may be somewhat costly depending on the pricing in your area.
Hope this helps Normal 0 false false false MicrosoftInternetExplorer4
Jul 07, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Hi there, with my toshiba 27A33 television ,the picture comes in on both sides about 2 inchs
First thing to check: could it be aspect ratio - source material is old standard 4x3 format, TV is widescreen 16x9, so it only fills center? If so, the images will look properly proportioned - circles round (not ellipses), people neither unduly fat nor skinny.
Second: if the shapes are wrong, it could be settings on source device (check DVD menu, cable/satellite set-up) and/or TV (choices like letterbox, pan and scan, stretch to fill screen, etc.)
Third: if CRT TV, could be defect in horizontal sweep circuitry, requiring repair shop; decide whether the cost is worth it, vs new TV.
Jun 25, 2009 | Toshiba 27A33 27" TV
I turn on the TV and after about a second it turns back off
22 error is the code for short protect which could be the two STK392-110 Convergence ICs as thats the number one component to short out . It could also be leaking coolant check the boards for any sign of a sticky residulr that would indicate that the CRTs are leaaking coolant on the boards.
Apr 27, 2009 | Mitsubishi VS-70707 70" Rear Projection...
Resetting V-Chip pin code
I don't know the sharp(mfg) code to activate my universal remote
May 12, 2008 | Sharp 27U-S60 27" TV
Mitsubishi VS-60607 60inch projection TV, cannot turn on
i have the same and i am having issues with the screen going dark when its suppposed to be a white screen and the picture is darker than it should be during normal watching of tv. also there is a line at the top(letterbox style) of about 1- 1 1/2 inches......anyone know how to fix this
Feb 22, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Timer light flashes 3 times
the code means that your tv power supply is not functioning your tv needs to be repaired call the tech.good luck
Apr 26, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-50607 50" Rear Projection Television Logo
95 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
