Question about Bosch 1274DVS 3" x 21" Belt Sander
My Bosch 1274 belt sander motor runs but the cylinders that turn the belt do not go round.
    Sergeant:
  • 384 Answers
Your drive belt is broken or off the pullies.
Posted on Jul 15, 2009
Tip
Replace drive belt Bosch pbs7a
To replace drive belt on Bosch 7 PBS belt sander remove cover, 3 screws, place new drive belt over splined drive pulley. Feed belt clockwise over paper pully and Utilize welded hexigonal with suitable wrench to turn and 'pop' the belt on.
on Feb 02, 2014 | Bosch Belt Sander Drive Belt For Pbs 7a,...
NEED A AUTO REPAIR SHOP TO RESET IT ONLY THERE COMPUTER CAN DO IT OK
Nov 14, 2012 | Bosch Belt Sander Drive Belt For Pbs 7a,...
Need part for Mastercraft belt sander 54-7240-8 I need to replace the belt on the motor that drives the belt drive assembly. The motor runs ok but, the wheel that drives the sanding belt doesn't turn...
Anyone has a broken belt sander 54-7240-8 within Canada? I could use a particular part from it to fix mine. If you do, email me at mstevlik@zoznam.sk
Thanks.
Sep 27, 2011 | Tools & Hardware - Others
Skill belt sander belt stops moving
most belt sanders are simular,if you have right size belt,there should be a lever between the belt wheels,pull lever out,put belt on,then close lever,some also have adjusting knob,turn clockwise to tighting.
Sep 30, 2009 | Tools & Hardware - Others
Bosch 3 x 21 Belt Sander
Remove the dust bag and unplug sander for now. Everywhere you see an access hole (fan area, dust port, back of sander blow thru the tool to remove lodged dust that clogged the system, Also look for broken belt pieces in the back of sander. Then while running (remove belt) blow again thru all the ports to try and reomve as much contamination as possible. When finished you can feel to see if air coming from dust bag port, it not you still have a clog that might need more work. If I have clarified your request would you please rate this response accordingly and thank you.
Sep 10, 2009 | Bosch 1274DVS 3" x 21" Belt Sander
Electric Bosch hand held orbital sander belt not rotating properly
My guess is that your sander got gunk in the belt and other rotating parts and you are either burning up the belt, or (hopefully not) the motor windings. Rick
Apr 13, 2009 | Air Tools & Compressors
My Bosch 1274DVS 3" x 21" belt sander will run only sporatically
Hi
Definately sounds like bad switch or contact to the switch
Feb 26, 2009 | Bosch 1274DVS 3" x 21" Belt Sander
Toothed belt bosch 1274 dvs
If I am correct, when holding the tool in the normal operating position there should be an oblong cover on teh left hand side nea the back of the tool. It should be held on with a screw. remove this cover and you can access the belt . MAKE SURE THE TOOL IS UNPLUGGED. the belt should pull off/push on with a bit of force. Turning the pulleys as you put it on will help it go on evenly. If it is too stiff, put the belt in some boiling water for a minute or two to soften it up a bit.
Nov 03, 2008 | Bosch 1274DVS 3" x 21" Belt Sander
How many Types of Sanders?
Belt sanders: Belt sanders are useful for removing large quantities of wood stock quickly. They are generally used for rough sanding before fine finishing with a smaller sander. Palm sanders: Palm sanders are ultra-portable and useful for finishing small projects. Orbit sanders: Orbit sanders are usually more heavy-duty than palm sanders and appropriate for larger projects.
Aug 27, 2008 | Bosch 3X18 Belt Sander
Bosch 1274DVS 3" x 21" Belt Sander Logo
341 people viewed this question
Top Bosch Tools & Hardware - Others Experts
Awesome12
Are you a Bosch Tool and Hardware - Other Expert? Answer questions, earn points and help others
