Question about HP Photosmart 8450 InkJet Printer
Says photo cartridge failed. When I remove it I can't print at all.
    Sergeant:
  • 259 Answers
Inset the new carteg and check 100% working your printer
Posted on Jul 15, 2009
How to install ink cartiges
To replace the print cartridges
1. Make sure the HP All-in-One is on.
CAUTION: If the HP All-in-One is off when you open the print cartridge door to
access the print cartridges, the HP All-in-One will not release the cartridges for
changing. You might damage the HP All-in-One if the print cartridges are not
docked safely when you try to remove them.
2. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
3. Open the print cartridge door.
The print carriage moves to the far right side of the HP All-in-One.
4. Wait until the print carriage is idle and silent, and then lightly press down on a print
cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge from
the slot on the right.
1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black and photo print cartridges
5. Pull the print cartridge toward you out of its slot.
6. If you are removing the black print cartridge in order to install the photo print cartridge,store the black print cartridge in the print cartridge protector or an airtight plastic container.
7. Remove the new print cartridge from its packaging and, being careful to touch only
the black plastic, gently remove the plastic tape by using the pink pull tab.
1 Copper-colored contacts
2 Plastic tape with pink pull tab (must be removed before installing)
3 Ink nozzles under tape
CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching
these parts can result in clogs, ink failure, and bad electrical connections.
8. Slide the new print cartridge forward into the empty slot. Then gently push the upper
part of the print cartridge forward until it clicks into the socket.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black or photo print cartridge, slide it into the right slot.
Work with print cartridges 69
Maintain the HP All-in-One
9. Close the print cartridge door.
If you installed a new print cartridge, the HP All-in-One prints a print cartridge
alignment page.
10. When prompted, ensure plain white paper is loaded in the input tray, then press the
button next to OK.
NOTE: If you have colored paper loaded in the input tray when you align the print
cartridges, the alignment will fail. Load unused plain white paper into the input
tray, and then try the alignment again.
11. Place the page print side down on the scanner glass and then press the button next
to OK to scan the page.
When the On
Aug 27, 2011 | HP Photosmart C4280 Aio Printer
How to change the ink cartridge
Follow these instructions when you need to replace print cartridges.
• Everyday printing: Use a black cartridge along with a tri-color cartridge.
• Color photos: Use a photo cartridge along with a tri-color cartridge.
slot on the left.
5. Pull the print cartridge towards you out of its slot.
container.
CAUTION: Do not touch the copper-colored contacts or ink nozzles. Also, do
not re-tape the print cartridges. Doing so can result in clogs, ink failure, and bad
8. Hold the print cartridge with the HP logo on top, and insert the new print cartridge into
the empty cartridge slot. Make sure you push the print cartridge in firmly until it snaps
into place.
Jun 30, 2011 | HP PhotoSmart C4385 All-in-One Printer
HP printer all-in-one model2410xphotosnart keeps giving me the message to remove and check print cartridges which I have done and both are full. Will not stop blinking and when trying to print makes...
Welcome to Fixya
This means the the printer cannot determine which cartridge is causing the error. Make sure that you are using original HP cartridges.
Please see troubleshooting procedure below:
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts. Click here to see how.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  3. If replacing cartridges fails to correct the problem, click the link at the top of this page to contact HP.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Apr 03, 2011 | HP Office Equipment & Supplies
How do i remove the ink cartridge ?
Turn on the unit, then open the print-carriage access door by lifting
the handle until the door locks into place.
The print carriage moves to the center of the unit.
You may want to use a photo print cartridge for
superior print quality when printing photos. With the
color and photo print cartridges installed, you have
a six-ink system. See how to print the best quality
photos on page 22 for more information.
52 maintain your hp psc
hp psc 2200 series
2 After the carriage stops moving, lift the latch to release the print
cartridge, then pull it toward you out of its slot.
3 If you are removing the black print cartridge in order to install the
photo print cartridge, store it in the print cartridge protector.
4 Remove the new print cartridge from its packaging and, being careful
to touch only the black plastic, gently remove the plastic tape.
Caution! Do not touch the copper contacts or ink nozzles.
5 Push the new print cartridge into the appropriate slot until it clicks into
place.
The tri-color print cartridge goes on the left and the black or photo
print cartridge goes on the right.
manual:
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c01176633/c01176633.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 26, 2010 | HP PSC 2210 All-In-One InkJet Printer
How do I install ink cartridge for hp photosmart C4280
slot on the left.
alignment page.
button next to OK.
When the On
Please Don't forget to rate this solution. Thanks.
Feb 17, 2009 | HP Photosmart C4280 Aio Printer
Changing cartridge on printer
The Basics manual from HP:
http://h10032.www1.hp.com/ctg/Manual/c00694908.pdf
Check out page 17 of the Basics manual for detailed instruction on replacing the cartridges.
Caution If the HP All-in-One is off when you open the print cartridge door
to access the print cartridges, the HP All-in-One will not release the
cartridges for changing. You might damage the HP All-in-One if the print
cartridges are not docked safely when you try to remove them.
print cartridge to release it.
slot on the left.
from the slot on the right.
cartridge, store the black print cartridge in the print cartridge protector or an
If you are removing the print cartridge because it is low or out of ink, recycle the
print cartridge.
only the black plastic, gently remove the plastic tape by using the pink pull tab.
Caution Do not touch the copper-colored contacts or ink nozzles.
Touching these parts can result in clogs, ink failure, and bad electrical
connections.
8. Slide the new print cartridge forward into the empty slot. Then gently push on the
upper part of the print cartridge forward until it clicks into the socket.
alignment sheet.
Note If you have colored paper loaded in the input tray when you align
the print cartridges, the alignment will fail. Load unused plain white paper
into the input tray, and then try the alignment again.
If the alignment fails again, you might have a defective sensor or print
cartridge. Contact HP Support. Go to www.hp.com/support. If prompted,
choose your country/region, and then click Contact HP for information on
calling for technical support.
Jan 03, 2009 | Office Equipment & Supplies
Changing ink cartridge on the HP Photosmart C3180 all in one
slot on the left.
print cartridge.
connections.
alignment sheet.
Nov 25, 2008 | HP Photosmart C3180 All-In-One InkJet...
HP PSC 1300 All in one Printer
  1. Turn on the HP PSC and lower the print-carriage access door.
    The print carriage will move into the access area. Figure 1: Opening the print-carriage access door
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot.
      NOTE: The black cartridge is on the right side of the print carriage.
    Figure 2: Removing the print cartridge
      NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab.
      CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles.
    Figure 3: Removing the plastic tape
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place.
      CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle.
    Figure 4: Inserting the print cartridge
  5. Close the print-carriage access door.
Using a photo print cartridgegtabtop.gif To use the photo print cartridge, remove the black print cartridge and insert the photo print cartridge in its place.
The photo print cartridge can be purchased separately and will optimize the quality of printed photos.
With the tri-color print cartridge and photo print cartridge installed, you have a six-ink system, which provides enhanced quality photos. For printing regular text documents, use the black print cartridge.
Use a print cartridge protector to keep either print cartridge secure when it is not being used. Figure 5: Storing the print cartridge
c00034854.jpg 1 - Inserting the print cartridge
2 - Removing the print cartridge
Aligning the print cartridgesgtabtop.gif After installing or replacing a print cartridge, the HP PSC will automatically print a cartridge alignment page.
  1. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  2. Press Scan .
    The HP PSC will align the print cartridges. During the alignment the button LED will blink until the alignment is complete.
Aug 04, 2008 | HP PSC 1350 All-In-One Thermal Printer
How do I install an ink cartridge? HP photosmart c5280 All in one
To replace the print cartridges Perform the following steps to replace the print cartridges:
  1. Make sure the HP All-in-One is on. CAUTION: If the HP All-in-One is off when you open the print cartridge door to access the print cartridges, the HP All-in-One will not release the cartridges for changing. The HP All-in-One can get damaged if the print cartridges are not docked safely when trying to remove them.
  2. Open the print cartridge door. The print carriage moves to the far right side of the HP All-in-One. Figure 1: Opening the print cartridge door c00956268.gif
  3. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it. If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. Figure 2: Removing the print cartridge from the slot c00956269.gif 1 - Tri-color print cartridge slot 2 - Black and photo print cartridges slot
  4. Pull the print cartridge toward you out of its slot.
    NOTE: Remove the black print cartridge to install the photo or gray photo print cartridge, and store the black print cartridge in the print cartridge protector or an airtight plastic container.
  5. Remove the new print cartridge from its packaging, and carefully remove the black plastic tape by using the pink pull tab Figure 3: Removing the new print cartridge from its packaging c00956270.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Also, do not re-tape the print cartridges. Doing so can result in clogs, ink failure, and bad electrical connections. Figure 4: Do not touch the copper-colored contacts c00956271.gif
  6. Hold the print cartridge with the HP logo on top, and insert the new print cartridge into the empty cartridge slot. Make sure to push the print cartridge firmly until it snaps into place. If installing the tri-color print cartridge, slide it into the left slot. If installing a black, photo, or gray photo print cartridge, slide it into the right slot. Figure 5: Installing the print cartridge c00956272.gif
  7. Close the print cartridge door. Figure 6: Closing the print cartridge door. c00956273.gif HP All-in-One prints a print cartridge alignment page if a new print cartridge is installed.
  8. When prompted, ensure plain white paper is loaded in the input tray, and then press OK .
  9. The HP All-in-One prints a test page, aligns the print head, and calibrates the printer. Recycle or discard the page. A success or failure message appears.
    NOTE: If colored paper is loaded in the input tray when aligning the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.If the alignment fails again, you might have a defective sensor or print cartridge. Contact HP Support at www.hp.com/support If prompted, choose your country/region, and then click Contact HP technical support.
  10. Press OK to continue.
May 15, 2008 | HP Office Equipment & Supplies
HP Photosmart 8450 InkJet Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
