Question about Philips 50P8341 50" Rear Projection Television
My Philips 50P8341 video inpust not working - all three out. Do hav audio.
  • Philips Master
  • 8,617 Answers
If youre getting audio the inputs are working, it seems more like the vertical IC has failed causing the Tubes to shutdown for protection. Try replaceing the vertical output IC
Posted on Jul 15, 2009
I need to change the flyback of my TV Philips of rear projection model 50P8341. I do not Know how to remove the damage flyback. First, I tried to remove the anodes that are connected to each of the three...
Leave the CRT's alone!!!!! You will ruin them. The red wires come out of the Fly-back. Pull the rubber caps up and then with a twisting motion pull each red wire out 1 at a time.
Apr 27, 2011 | Philips 50P8341 50" Rear Projection...
Philips 50p8341 tv has bowed picture in the lower left corner and the top center. I cleaned the projectors because the picture was real cloudy and it looked a lot better, came home from work and discovered...
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 19, 2010 | Philips 50P8341 50" Rear Projection...
Replacement Lamps/Bulbs for Philips 50P8341 Rear Projection TV
These are both CRT type TV's(3 picture tubes drive the image) with different screen sizes and the CRT's are not interchangeable
Oct 24, 2009 | Philips 50P8341 50" Rear Projection...
How do I replace the Vertical Output IC
Replace the Small Signal Board Part #313912725871
This is a common problem withis TV.
Jul 30, 2009 | Philips 50P8341 50" Rear Projection...
Hooking up from hd receiver to hdtv ready projection tv. what cables do I use? vga or rca component red, blue, green and sync white/black? My hd receiver has output of :hdmi, rca component, s-video ,...
This particular television puts you in a tough bind - you can use Component cables in AV1, but you won't be able to get HD. Or you can use the Component cables in the right-most component slot, but since your HD Receiver probably doesn't have V/H Sync connectors, you may get a rolling picture. Try the component cables in the right-most slot (I'm assuming, perhaps incorrectly, that your actual model # is not really a 50P8341, which has no V/H Sync slot).
-Tha Mp3 Doctor
Mar 07, 2009 | Philips 50P8341 50" Rear Projection...
My Phillips 50P8341 50 inch has color adjustment problems, any suggestions?
http://www.usersmanualguide.com/philips/tv__projection_tv/50p8341
go to this link and download Owner's / User's manual
Dec 13, 2008 | Philips 50P8341 50" Rear Projection...
Philips 50p8341 chassis PTV915
Well the manual seems ok ,but you need check the board as there burn out in it which causing this problem check the IC S and the tracks on the board ,even bad connectors can cause this problem...
Good luck...
Sep 09, 2008 | Philips 50P8341 50" Rear Projection...
Turns on but no picture or sound.
please check the connection wire/cable that gives power to your tv. if no fuses are blown. it may be a capacitor problem.
Mar 30, 2008 | Philips 50P8341 50" Rear Projection...
Philips 50P8341 50" Rear Projection Television Logo
62 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
