Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Where does the engine oil drain from on a 96 fatboy?
    Sergeant:
  • 277 Answers
THE ENGINE OIL PRESERVE THE ENGINE NOT TO GET DAMAGED OR PREVENT IT FROM FRICTION TO OCCUR
Posted on Jul 15, 2009
Why did my engine oil level rise on 1996 fatboy 1340 after fresh oil change
if you have an oil cooler or remote oil filter, possibly you didn't drain ALL of the old oil before you refilled with new oil
Jun 06, 2014 | 1993 Harley Davidson FLSTF Fat boy
Where's the oil drain plug for 2010 low fatboy harley
Which of the three drain plugs. Primary is on primary case below derby cover; transmission is on right side middle bottom of transmission, engine is at bottom of right rear frame down tube intermediately forward of rear tire. ALL are 5/8 inch hex plugs with 1/4 inch Allen socket in the middle of the plug.
Apr 13, 2014 | 2005 Harley Davidson FLSTC - FLSTCI...
We're is the drain plug for draining the engine oil on a2010 fatboy lo
the drain plug will be situated underneath the engine in between the two cylinders. Before changing the oil if possible run the engine for a few minutes to warm the oil then remove the sump or drain plug, and dont forget to change the oil filter as well.
Nov 14, 2012 | Motorcycles
Oil leaking from from harley davidson v twin engine
Hi Anonymous, call, take a ride or trailer your bike over to your local dealers service/parts department, I'm sure they will be happy to take your Harley Davidson for a test ride if necessary/possible and offer professional advice and assistance concerning your issue. Good luck have a nice day.
Nov 04, 2012 | Harley Davidson Motorcycles
What is drain plug between rear shock absorbors for on 06 fatboy
Hi Chanceycoalm, you drained the transmission, replace oil with 20-24 oz. HD Transmission Lubricant. The engine oil drain plug is on the bottom of the frame tube right hand side all the way in the rear. Have nice day.
Jul 17, 2012 | 2006 Harley Davidson FLSTF Fat Boy
Drained the oil on 2003 Fatboy for oil change. Refiled oil tank and could only put 1.5 quarts back in tank before it ran out filler spout. What would cause the tank to not drain completely? Bike was o
Hi Vander, the Harley Bible says, engine should be at normal operating tempurature, let idle on jiffy stand for two minutes. Shut off engine and hold bike straight up, correct engine oil level will be at the top full mark. Do not overfill oil tank as this will cause engine breathing issues. Drain the oil when it's hot. Good luck
Mar 10, 2012 | 2003 Harley Davidson FLSTFI Fat Boy
Where is the oil drain plug on a 2001 harley fatboy???
on the oil tank there should be a drain hose that goes down and hitches to the frame on the bottom of the frame there should be a drain bolt. That is your engine oil drain plug and should be on the right side
Mar 28, 2010 | 2001 Harley Davidson FLSTF - FLSTFI Fat...
Need to find engine oil drain plug on 93 fatboy 1340
The engine oil drain plug is on the right side of the bike. Actually, it's a hose with a plug in it. Look just behind the chrome transmission clutch release cover on the right side of the bike. You'll see a large diameter hose that should be held to the frame by a clip with a metal plug in it. Just loosen the hose clamp and drain the oil from the tank. Remove the oil tank dip stick for faster drainage.
Jan 08, 2010 | 1993 Harley Davidson FLSTF Fat boy
2001 fatboy service
Fatboy, drains from the oil tank bottom right side rubber tube goes down to frame, bolt in frame is plug. Have to get to it from underneath. This is only engine oil. After oil change three quarts, if change filter 3.5 quarts.
Hope this helps.
JP
May 30, 2009 | 2001 Harley Davidson FLSTF - FLSTFI Fat...
2002 FLSTF Fatboy needs oil change
I have a 05 Fatboy and the drain plug is hidden inside the frame rail on the right side by the swing arm it's a 5/8s plug.
Feb 22, 2009 | 2003 Harley Davidson FLSTF Fat boy
Lands Phones Logo
118 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
WTF Chuck.....
WTF Chuck.....
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
