Question about Palm Zire 31 Handheld
My Handheld wont reset or turn on
My Zire Handheld wont turn on or reset?
  • nora_gu18 Jul 15, 2009
    It turned on again.... but now when i unplug it. it just loses its data.
    Sergeant:
  • 277 Answers
YYOU NEED TO SERVICE IT
Posted on Jul 15, 2009
How do i perform a hard reset on my palm pda
  1. Step 1 Straighten a paper clip into a single line.
  2. Step 2 Locate the "Reset" button by spotting a small hole on the backside of the Palm Zire 31.
  3. Step 3 Push the power button on the Palm Zire 31 with your finger and hold it down steadily.
  4. Step 4 Push the paper clip into the "Reset" button's hole while holding down the power button.
  5. Step 5 Release the power button once the screen displays the "Palm Powered" logo.
  6. Step 6 Push the navigational key in the "Up" direction to complete the Palm Zire 31 hard reset.
May 26, 2010 | Palm Zire 31 Handheld
My Plam Zire 21 handheld has worked fine; suddenly it will not turn on, or at least the screen remains dark. I have tried re-charging the battery, and resetting the device, but to no avail. Any other...
It is possible that the battery has lost it's skill. If you can plug it in, either by usb to a computer or through the power supply, and the screen shows it is a goner.
The link below is for the palm zire m150 if your interested in replacing the battery yourself. The zire 21 is similar to that model so it's pretty much universal.
http://www.directfix.com/mm5/merchant.mvc?Screen=CTGY&Store_Code=GHT&Category_Code=_ZIRETAKE
Apr 06, 2010 | Palm Zire 21 Handheld
How do i fix a zire 21 palm it wont turn on, charge,work nothing
Hello.
From Palm support:
1. Press either the Date Book or Address Book button to see if
you can turn on your handheld that way.
2. Perform a soft reset: Use the tip of an unfolded paper clip
(or similar object without a sharp tip) to gently press the
reset button inside the hole on the back panel of your
handheld.
3. Make sure the power adapter is plugged securely into a
working electric outlet and is firmly connected to the
handheld. (If no outlet is available, your handheld can also
be charged through the USB cable, but this takes much
longer.)
Note: Your handheld does not have an indicator light to indicate that your handheld is being charged.
4. Charge for another three full hours.
5. If your handheld now turns on, check the charging-battery icon to ensure that your handheld is being charged. Example:
a. Connect the handheld to an outlet and turn it on.
b. Tap Home .
c. Look for the lightning bolt on the battery icon at the top of the screen.
d. If you do not see the lightning bolt, repeat steps 3 and 4.
Hope this helps.
Nov 03, 2009 | Palm Zire 21 P80730US Handheld
Palm Zire 71 handheld does not come on, did a hard reset, nothing
Confirm that both the cradle and the PDA ports are clean and free of dust or dirty.
Also, check your AC wall adapter to confirm that is working. The output should be +5.0 volts DC. Any repair shop has a multimeter need it to check it in no time.
If everything appears is OK, then confirm the PDA is properly placed in the cradle, and that the PDA is not loose on the cradle, indicating that the port contacts are not touching.
Best regards,
Mar 24, 2009 | Palm Zire 71 Handheld
Hotsync
do you want to completely delete all the data on your palm zire if so try a hard reset (deletes everything!)
To do a hard reset:
Press and hold the power button on the front panel of the handheld.
1.
While holding the power button, use the tip of an unfolded paper clip (or
2.
similar object without a sharp tip) to gently press and release the reset button.
Wait for the Palm PoweredTM logo to appear; then release the power button.
3.
When a message appears on the handheld screen, warning that you are about
4.
to erase all the data stored on your handheld, press any other button to perform a soft reset.
Mar 16, 2009 | Palm Zire 21 Handheld
Palm Zire 71
The top plastic digitizer is defective.
It needs to be replaced.
There are several sources on-line to buy such digitizer part.
Best regards,
Jul 14, 2008 | Palm Zire 71 Handheld
AHHHH!!!!
Just had the same thing- I blew out the plug port and re-plugged it in, charged for an hour, and now it turns on.
Jul 12, 2007 | Palm Zire 72 Handheld
Zire 71 won't turn on, battery full after reset.
You can try to leave it for a few hours then charge it again. Or you can replace the batteries. I also have the same problem but after the reset, everything worked fine
Jan 06, 2007 | Palm Zire 71 Handheld
Palm Zire 31 Handheld Logo
124 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Don Eagan
 steve
steve
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
