SOURCE: Right rear brake light still out after replacement with new bulb.
You must replace the relay, yes, underneath the steering column. It's 47.00 at the dealer. I had the same problem. Should be fine after that!
SOURCE: All head lights failed. Display reads: left front
they could fail in pairs, check bulbs ,remove and install new ones also check fuses after installing new bulbs if they dont work because they sometimes pop the fuse when they blow out , also theres a left and right lamp fuse so check both fuses , but only if lamps dont work after you install them. hope this helps, good luck.
SOURCE: 1997 cavalier turn signals
Your left turn signal relay might be out, if i remember correctly, it's located in the fuse box, and is as easy as changing a fuse. If it isnt in the fuse box under your dash then check under the hood, possibly near the battery.
SOURCE: plip battery spent message will
hi this is the battery in your key remote, it is saying it needs to be replaced soon or it will not work so just replace the battery in the fob, be sure to do this in 60 seconds or you will need to re-program the fob, just in case you do not get the battery in, in time, here is how to re-program it as follows
Turn the ignition switch to the ON position using the first key.
Press the LOCK button for 10 seconds.
Remove the key and wait for 10 seconds.
Check the Plip key operation.
Repeat for second Plip key if required.
Turn the ignition OFF
hope this helps please comment and rate thanks
The sequence of switch closures received by the BCM
The status of the engine run flag
The chart indicates the power modes detected and transmitted by the BCM:
