Question about Graco Pack 'n Play
Can not get the sides to hook - Graco Pack 'n Play
  • 130 Answers
PULL MIDDLE UP QUICKLY
Posted on Jul 15, 2009
Hi my mini convertible roof it not working . hooks will not lift
If the hooks unlock on one side and not the other the cable that pulls the hooks is broken on one side. This requires the front section of the convertible top to be replaced. Unfortunately there is no way to fix the cable that connects to the hooks.
Sep 12, 2014 | 2004 Mini Cooper
I just bought a used kenmore elite side by side refrigerator and hooked up the water line to the back of the fridge. My question is where does the long water line the goes to the fridge and comes back...
Where you hook the house water line is to the water inlet valve which is a one in two out solonoid controlled valve. One side goes to the water dispenser in the door and the other hooks to the ice maker connection.
So I suspect the long water line you are talking about has had the lines switched at the valve and needs reversed. The long line probably goes up the back of the unit and connects to the ice maker. The one for the water dispenser should hook to the water chiller resevoir and then to the water dispenser.
Sep 14, 2011 | Kenmore Side by Side Refrigerator
There's no place on modem to hook router
Look for Ethernet jacks. You want to hook both your computer and your daughter's laptop to the router to out ports i.e. usually on the front side. The back side of router would hook using probably another Ethernet jack to your modem.
Jul 02, 2010 | Belkin (F5D7230-4) Router (587009)
1973 Ford Mustang Coil Hook-up
The wire that comes from your distributor hooks up to the Negative side of the coil. The other wire should be a switched positive that hooks up to the Positive side of the coil. It should be hot only when the key is ON or Start.
Jul 02, 2010 | Ford Mustang Cars & Trucks
Hooking up five hoses to my hayward pump/filter
Your system has a suction side and a discharge side. Skimmer and bottom drain hook to the suction side. Returns (discharge) return via chlorinator or other sanitary system and heater if appropriate, to ports in the side of the pool.
May 31, 2010 | Hayward SAND FILTER, PRO SERIES
Hooking up water to ice cube maker
On page 4 step 3 of the manual on link below tells you how to hook up the water supply for your fridge.
http://shop.amana.com/assets/pdfs/literature/004251.pdf
Mar 13, 2010 | Amana 22.6 cu. ft. Side-By-Side...
How do you oil a bernina 1008??
Probably the most important is the inside of the hook ring. Remove the bobbin case and open the hook retainer by pressing the catch on the left-hand-side. The hook can then be removed by just gripping the shaft on which the bobbin was mounted and removing the complete hook. NEVER OIL BEFORE CLEANING. This is the single biggest problem I come across - continually oiling any kind of machine without first removing the old, contaminated lubricant will attract grime. So ... get yourself a few cotton buds and carefully clean around the inside of the hook ring (the circular aperture where the hook was), paying particular attention to the small groove running round the outside. Rotate the handwheel to bring the hook driver round halfway to allow the whole hook ring to be cleaned. Use the opportunity to remove any clogged lint and grime that may have built-up on the underside of the stitch table. WHen you're satisfied it's all clean, then run a very light bead of oil around the groove in the hook ring, turn the hand-wheel fully to bringthe hook driver back to the left-hand-side and oil the other side of the hook ring. Before replacing the hook, take a good look at the groove that runs around the back side of the hook near the edge and thoroughly clean that too, before smearing a drop of oil around that edge with a finger. Replace the hook, making sure its properly seated in the hook ring and click the black plastic cover back into place before replacing the bobbin case. Your machine should now sound a great deal quieter, if you haven't done this for a while !! Good Luck !
Nov 01, 2009 | Bernina 1008
I own a amana side by side refrigerator...I have not hooked the water line up for 10 years...now I need to bring it back into service but notice the hook up appeared to have a treaded female junction more...
Yes there is an adapter. If you purchase the ice maker line kit from Lowes or HD (the stainless steel braided line) they often come with the adapter.
I recommend the steel braided hose as they are flexible, and burst resistant. It will be a simple brass fitting with male end to go to the fridge, and the hose hooks up to the adapter
Sep 26, 2009 | Amana SXD524VW Side by Side Refrigerator
Hose from door dispensor hook to refrigerater
it should hook up to a water line with a coupling at the bottom of the freezer door. take the kickploate off and then look underneith the refrigeraqtor and there should be a clear plastic tube there3 to hook up to.
Aug 04, 2008 | Maytag MZD2669KE Side by Side Refrigerator
Cradle slamming and strip un-hooked
This is the encoder strip please get it fixed in service center or if the printer is in warranty get it replaced.
May 17, 2008 | HP PhotoSmart 7550 InkJet Printer
Graco Pack 'n Play Logo
162 people viewed this question
Top Graco Toys Experts
Shehu Pro
Shehu Pro
ray gallant
thegtw
Are you a Graco Toy Expert? Answer questions, earn points and help others
