A
Anonymous Posted on Jan 04, 2016
A pioneer gr-333 graphic equalizer which is labelled on back side; all input and output is written on tape only..Can i connect a cd player on this terminal?
James Kovacs
Level 2:
Champion:
  • Expert 219 Answers
  • Posted on Jul 18, 2016
James Kovacs
Expert
Level 2:
Champion:
Answers
219
Questions
0
Helped
87803
Points
305
Yes, connect to TAPE PLAY.
Then you come out of EQUALIZER OUT to your sound system.
There are other ways to do this, but it all depends on the rest of your system.
DOWNLOAD THE MANUAL FROM THE NET.
Peace-
5 Related Answers
Anonymous
  • 682 Answers
  • Posted on Dec 03, 2009
SOURCE: can I hook up a kenwood graphic equalizer
cd player out-------------equalizer in------------equalizer out------receiver line in or tape in.
Anonymous
  • 682 Answers
  • Posted on Dec 22, 2009
SOURCE: I have an ADC equalizer model # SS-100SL i'm
record out-------equalizer in-------equalizer out------tape in
adamncc1701
adam dombrosky
  • 158 Answers
  • Posted on Sep 02, 2010
SOURCE: i cant seem to hook
tape out from reciever to line in on the eq --then line out from the eq to tape in on the reciever --whenever the tape monitor will be used on the reciever the sound will then be equalized
Testimonial: "Hallalujah!!! Thank you so much, i was getting so frusturated! You're awesome! God bless you!"
Anonymous
  • 2178 Answers
  • Posted on Nov 23, 2010
SOURCE: I have technics reciever sa ax 6 (without tape
Click here.
Anonymous
  • Posted on Jan 03, 2011
SOURCE: How to connect a Technics Graphic Equalizer to a JVC stereo system?
tiene estaatica cuando pasan como 20minutos
Pioneer SX-P720 circuit diagramn and wiring diagram wanted please i really need it for pioneer GR-Z460
What do you mean by the leads are "flat type" on the Marantz? Are you referring to the speaker wire output terminals? If so, the graphic equalizer should be connected to the pre-amp input of the amplifier, not the speaker level outputs.
Como conectar un pioneer graphic equalizer gr-408 a un pioneer receiver vsx-d307
Connect equalizer to preamp outputs and inputs on receiver. If none, use tape monitor input/outputs to set up equalizer.
How to hook up a 7 band pioneer equalizer great 470 to a Kenwood kr-v6030 receiver
Connecting an Equalizer to a Receiver Before beginning, purchase RCA cables. In order to run the signal from a stereo receiver to the graphic equalizer and then on to the amplifier, two sets of RCA cables are needed. These are basic cables used to connect auxiliary components like record players and CD players. The length of the RCA cables should be about the same length as the distance between the receiver and equalizer.
1. Connect Graphic the Equalizer to the Receiver
The first step in this setup is to connect the graphic equalizer (EQ) to the receiver. Most receivers will have preamp-in and preamp-out connections. Some have tape monitor connections. It's preferable to connect the EQ to the preamp-in or preamp-out because the tape monitor won't allow for connection to the amplifier as well.
2. Connect the RCA Cables
The first set of RCA cables should connect the receiver and equalizer. Connect one pair to the preamp output channels and the other end to the left and right input channels on the EQ. These are on the back side of the equalizer. Usually, the colors will correspond to the RCA plugs. That means connect the red plug to the red jack and the white plug to the white jack. Then connect the second pair of RCA cables between the receiver and the amp. Match the colors in the same way.
3. Connect the Amp to the Receiver
Now the amp can be connected to the receiver via RCA cables in the amp inputs on the receiver. This will create a loop from the receiver through the EQ and amp and back to the receiver so that all three units are connected.
4. Test Graphic Equalizer
Turn on the receiver, amp and equalizer. Once they are powered up, try controlling the sound with the equalizer knobs. They should fine tune the music according to your preferences. It's easy to change the frequency response or tone of the music with the equalizer knobs.
How do you connect a home pioneer graphic equalizer sg-9 to a sansaui r-7 receiver?
Use the tape monitor loop. Connect from the TAPE REC output on the receiver to the INPUT on the equalizer and from the OUTPUT on the equalizer to the PLAYBACK input on the receiver. YOU can then switch the equalizer in and out using the TAPE MON switch. I think the Model Seven had two tape loops, so just keep everything on the same loop.
1helpful
How do I hook up a graphics equalizer SH-GE70 to the amp SU-A707? I've already plugged in the CD player SL-PG5 and the tape deck RS-TR474M2, but can't see how to wire in the graphic. If I could...
hi,
Try this. You need 4 RCA setreo Chord for this.
1. connect the cd player out to the LINE input of Equlizer.
2. connect the Record out of equlizer to Tape's Record input.
3. connect the Play out of the Tape to the Play in of Equlizer.
4. connect the Line out of the Equlizer to the CD input of amp.
Always Select CD in the amp. And select between tape and CD in the Equlizer.
OK
2answers
Using graphic equalizer on a Pioneer CD player
try to connect it in tape in-and confirm that you select the right input in the receiver(in our situation you will select tape as input source).
1helpful
I need to connect my turntable to my reciever via Pioneer GR-470 pre-amp
no need for phono, you can go to radio shack and get a selection switch to make things easier.
13helpful
How to connect eq to audio amp
To EQ all audio sources you'll need to have a receiver/amp with either a tape monitor loop or a pre amp-in/main-out loop. Look for a button on the front labelled 'Tape Mon' or ins and outs on the back labelled pre amp-out/main-in. If you have these you can connect the outs from the amp to the ins on your EQ and then EQ outs go back into the amps ins. If you have a tape deck as well, the EQ's 'tape mon' jacks replace the ones it takes up on the amp, so just plug your tape deck in here.
Just remember that whether you have a tape deck or not, if you hang an EQ off the 'tape mon' loop you'll have to engage the 'tape mon' button/switch for playback with EQ.
If your amp doesn't have these loops you can still use EQ but you may be restriced to one audio component source. So say you wanted to EQ the playback from your CD player, you'd just connect the CD players output into the EQs input, then connect the EQ's output into the amplifiers input (for CD player). Then everything you play through the CD player will be EQ'd.
Stereo wiring
Wire outputs from CD player into inputs of Equalizer, then connect outputs of equalizer to inputs of amp, then output of amp to speakers. Use the best wire possible for all connections, i.e. Monster cables ect.
Please post ratings for all solutions please.
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
