Question about Krups XP2070 10 cup Coffee Maker/15 bar Pump Espresso
No power, nothing on clock, no lightsm dead! - Krups XP2070 10 cup Coffee Maker/15 bar Pump Espresso
  • 25 Answers
  If measuring for resistance across the power cord reveals open circuit, it's most likely the transformer inside has gone defective.  (I would expect under 100 ohms).  It may have a micro thermal fuse hidden under the paper wrapping that can be replaced.  The standard shop repair (If it's the transformer) is to just replace the transformer.
Posted on Jul 15, 2009
    Problem Solver:
  • 12 Answers
I replaced the entire power board given that I saw signs of water damage and it appeared difficult to just replace the transformer. The power board kit also includes the display module which is a nice spare to have.
Posted on Dec 18, 2009
  • Ale Apr 20, 2011
    Do you know which cluster I connect the flow meter? J3 or J6 , thks
Will not start
Main fuse...........
Apr 19, 2016 | 2001 Hyundai Tiburon
My Bose radio/cd player (02273c03437299a) seems dead! It's plugged in... No clock, no radio, etc..... What now? A 9 volt battery does nothing.
Various problems may cause no power condition: Dead AC transformer; defective power regulation circuitry; dead microprocessor or display electronics; liquid damage; cracked circuit board; open current limiting resistors .. and more. If needing professional service, Ship radio and contact info to:
CET Services
117 Windsor Ave
Hurley, WI 54534
Their Certified Tech Repairs These Units, average
cost between $100 to 145 plus return shipping to repair all problems,
replace all defect parts, clean inside and out, and adjustments.
Jan 12, 2016 | Bose Audio Players & Recorders
I have a 2002 KIA Spectra that will not start. I turn the key and nothing happens. No lights, dash lights, nothing!!! I had the battery checked and charged at AutoZone and put it back in. Still nothing....
you always have to reset when you take the battery out or it goes stone dead. loosing power sounds like a battery going dead due to no charging. charge it up and drive it bck to auto zone for an alternator check.
Jan 22, 2015 | Kia Cars & Trucks
Why wont my 2001 isuzu rodeo will not start and the clock is not on inside the car?
no power,
you meant , will not crank?
if yes, then does jumper cable cranks work? off running donor car?
clock, all clock is dead, but i bet you forgot to notice, lots of others things are dead. sure.
you key on, and the cluster lights up.
and the head lights work.
and you crank and it does what.>?
nothing/
clicks
or cranks.
or even starts.
in that order.
Jul 10, 2014 | Isuzu Rodeo Cars & Trucks
Replaced battery, no power to radio now, help!
Most radios have a fuse in main fuse panel and a fuse on the rear of the unit. It is a common problem for the one on the radio itself
Jun 28, 2013 | 2002 Saturn L-Series
AEG RIP? No power to oven?
If you have replaced an oven element the oven will not work again until you have reset the clock.
Sep 14, 2017 | AEG Ovens
My oven is dead - no display, no nothing. Circuit breakers are fine. Turned them off overnight, still nothing on oven this morning. This happened about a year ago but oven came on again ten minutes...
What you need to check is for power at the clock.TURN OFF BREAKER gain access to clock and use volt meter. One the clock will be wires maked L1 & N on those 2 wires when breaker is turned back on their should be 120 vac. IF 120 vac at those 2 wires,replace the clock, if not 120 vac into clock check for burnt/broken wires
Aug 20, 2011 | Jenn-Air Electric Single Oven
Hi i have a blanco electric oven model no bms 901 sse and the timer shows A and no time . And the oven does not work can u please help me
I had a similar problem with the same model of Blanco Oven but in my case the clock was completely dead apart from the letter A which was lit (and this proved there was power to the oven).
The oven would not work because the clock module (electronics control unit) was dead.
I rang a Blanco parts supplier, who advised the clock module was no longer available (Blanco advised the same). Another supplier said they could supply the clock module for A$425 which is an absolute ripp off (a reasonable price would be A$50 as it only has a couple of components).
As the clock module is not essential (it only provides the time, alarms, and fancy features most people don't need) I decided to by-pass it by shorting out the two (brown) wires on the LHS (which connect to the relay on the clock module). In effect it behaves as if the relay is always ON, supplying power to the stove.
The oven now gets power and works fine and it cost me virtually nothing to repair. I strongly recommend this solution to anyone experiencing problems with the clock module.
Some basic understanding of electrical/electronics systems is all that is needed to implement this repair.
Aug 10, 2011 | Ovens
Turn key to start and nothing
Not if you left your headlights on all night and completely drained the battery. if it is dead, try to jump it, if you get some sort of power with the jumpers attached, go buy a new battery.
May 29, 2009 | 2001 Toyota Tacoma
Krups XP2070 10 cup Coffee Maker/15 bar Pump Espresso Logo
601 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
