did you mean FI light?? start with the switchs side stand, neutral and clutch. if any are not working the bike won't start. hope this helps
Mark
C.C. Motorsports
Go to http://www.carlsalter.com/motorcycle-manuals.asp , there are some repair manuals for older versions of yours (free) that might help, but I honestly think this is one of those modern bike computer problems.
does it have a fuel pump ?...it could be just priming itself..when the pump is already full you cant really hear the noise that much. Does the noise go away after riding for awhile and then restart it?
Sounds like bent shifting fork which is expensive. If you are not the 1st owner then you don't know how previous owner treated bike. Often sportbikes are rode hard and banged into 2nd gear which can eventually cause tranny problems like bent shifter fork. First look down by the shifter pedal and inspect that it is fastened securely to the shift rod coming out of the engine/trans case. There is a single bolt that holds the shift lever on a splined shaft and can come loose and cause problems.
If that is ok then find a local mechanic you trust....Good Luck !
The bike died, like the key was shut off. No electrical what so ever.
