Ask The SnowMan Your Sledding Questions Answered: Off ...
www.off-road.com/.../ask-the-snowman-your-sledding-questions-answer...
Mar 1, 2009 - Its a 96 polaris indy xlt 600 triple not the special edition though. ... THEM SITTING ON THE HEADS BUT ONLY 2 CYLINDERS ARE RUNNING WHEN ... Q: I have a arctic cat ext580 the compression in both cylinders is about 70psi .... i have a93 polaris 600 xlt and I just got home and the antifreeze is ...
93 XLT Carb settings? - Snowmobile Forum: Your #1 Snowmobile Forum
www.snowmobileforum.com/polaris.../41045-93-xlt-carb-settings.html
Nov 27, 2009 - I bought a new to me 95 polaris sport last year. it had not run in twoyears. ... It's all in the tuning, clutching, jetting and gears.. i have a 93 xlt 580 and i ... he is loading up with fuel and just cutting the spark out of a cylinder.. i had ...
XLT w/ Triple Pipes Question?
May 8, 2013
93 XLT Ran Great, Shut Down, Now Backfires
Feb 13, 2012
Dead cylinder
Dec 11, 2011
1998 ski doo f3 700 wont run right
Feb 22, 2011
More results from www.snowmobileforum.com
Polaris Indy 600 XLT HELP! - Snowmobile Fanatics
SOURCE: Check engine light comes on. p0171 and p0351 codes found
From Lusty Kid:
I know the economy is bad, but change all of the plugs. Check your PCV Valve hose, 150 rottens them out allowing air to be sucked in, thus all kinds of codes.
Depending on mileage. Dismount the EGR valve and clean passages. If you are really good dismount the throtle position sensor body and clean out passages with Choke Cleaner., dismount where the EGR valves connects to the engine, clean out passages. Also check the hose thats behind this mounting to ensure is not clogged. If clogged clean it out. If not replace it. Is about 1.5 ft. long, connects to the PCV Valve Hose.
When is the last time you change your harness. Can't remember??? Replace it. Good Luck
SOURCE: 1998 Cavalier No Spark in cylinders 1 & 4
ignition mod. grounds,pcm or timing belt could all be it but, I would have to look at timing first.
SOURCE: Misfire of cylinder 2 & 5 on 04 Buick LaSabre Custom
Ok this may be something smal that may be simple to fixs; your plugs are in the wrong cylinder?
Check Your gap size .060 (In thousandths of an inch)
Im not sure of the size of engine please look below for your make?
Fig. 3.8L VIN 1 Engine Firing order: 1-6-5-4-3-2 Distributorless ignition system
Fig. 3.8L VIN K Engine Firing order: 1-6-5-4-3-2 Distributorless ignition system
Fig. 3.8L (VIN 1 and L) Engines Firing order: 1-6-5-4-3-2 Distributorless ignition system
Fig. 3.8L (VIN K) Engine Firing order: 1-6-5-4-3-2 Distributorless ignition system
I hope that this help!
