Question about Dymo LabelManager 300 Desktop Labelmaker Printer
Using Dymo LabelManager 300, when I press the print button, the screen comes up with a series of exclamation marks( !!!!!!!!!!!!!!!!!!!!!!!!!!! ) and it won't print.
We no longer have the manual, can you please help us.
  • 126 Answers
I would suggest reinstalling the driver.
First disconnect the label writer, then go to :
https://global.dymo.com/enUS/RNW/RNW.html?pg=std_adp.php&p_faqid=101
Scroll down and you will see your model number and download the drivers. Then run the installation again and it should prompt you to connect the label writer, which should fix the problem
If not also try reinstalling the "Label Software Application" listed on the same page as well.
Posted on Jul 15, 2009
2 Suggested Answers
SOURCE: Not printing at all. Screen appears as series of exclamation marks
This is probably due to a broken nylon pinion gear, the one which meshes with the capstan drive motor. Due to poor design, the gear is only marginally heavy enough to stand the strain of being press-fit onto the shaft that runs through it. The failure mode is that the gear splits along one of the seams between the teeth and then simply spins on the shaft. This appears to be a common problem with the LabelManager 300, which is really too bad because the printer is otherwise an excellent machine. Anyway--
Replacement parts are not available, and the design is a ***** to repair but it can be done. The short story on the repair trick is to:  1. unscrew the two fasteners (one near the print head accessed from the front and one accessed from the rear once the back is off the unit) that hold in the motor and gear assembly, 2. pull off the motor worm gear 3. unclip and push motor back
4. remove the mating gear/shaft assembly by extracting the shaft running through (broken) mating pinion gear and associated 2nd stage worm gear 5. clean gears and shaft with pure iso alchohol 6. drill out split pinion gear with #47 (.078") bit 7. superglue pinion gear back onto shaft, centered on spline (i.e. where it was before). Use pliers or clamp to hold gear snugly against shaft for 12 sec or so while glue sets 8. press fit 2nd stage worm gear back on the other end of the shaft (again, centered on spline where it was in the original assembly) 9. modify motor assembly plastic baseplate by cutting narrow "V" **** in plastic "tunnel" that shaft previously went through, so that shaft can be pressed into place without disassembly/reassembly of gears. This is the trick... 10. when shaft assembly is back in place, reassemble worm gear onto motor shaft and press motor back into position. Worm gear should now mate with pinion gear on shaft assembly and the motor shaft should be readily turnable with fingers. 11. reassemble motor/gear assembly onto label printer metal baseplate and test.
Be certain, for Step 7, that the gear and shaft mating surfaces are grease-free and use a good-quality superglue. Epoxy does not work for this repair!!
Have fun and good luck. crd
Posted on Aug 07, 2008
How do change the font size?
There should be a button with the "A"s of different size that is just under the word "DYMO" beneath the screen. Pressing that button will toggle between various font sizes.
May 05, 2011 | Dymo LabelMANAGER 350 Thermal Printer
My dymo labelmanager 9000 will not print labels, a comment comes up saying label with arrows pointing to the left each time i press the print button. i have tried pressing the bottom feed button...
The fix for this involves opening the unit up. The problem is the infra red LED sensor on the label exit has slightly miss-aligned giving the error. If you unscrew the two sensor boards, re-align and screw them back all will be well.
Hope this helps.
Jan 10, 2011 | Dymo LabelMANAGER 9000 Printer
Cannot get dymo to print vertically
On mine you use the FORMAT button
Then theUP arrow until you see STYLE
Then press OK
Now press the UP arrow until you see VERTICAL
Now press OK
Sep 15, 2009 | Dymo LabelMANAGER 450 Printer
Dymo labelmanager 300 does not print....just makes rapid ticking noises....help!
I posted this to another of the same question: I know this is way late, but... I just opened one up that ia doing the same thing. What I found is this: In the sequence of the drive train, there is a spiral gear on the motor's drive shaft. That gear interfaces with a gear on an intermediary shaft. (Call this the "driven gear".) The driven gear is a compression fit to splines on the intermediary shaft. The problem is that this driven gear has split. It no longer grips the intermediate shaft. The clicking comes from the spiral gear attemting to span the gap caused by the split and jumping the gap when it resynchronizes. I know this is not actually a solution. I am in turn looking for a replacement for the driven gear, or a way to repair it. If anyone knows a source or way, I'd appreciate knowing it.
Jun 08, 2009 | Dymo LabelManager 300 Desktop Labelmaker...
Dymo LabelMANAGER 100+
how do you change the font size to larger print
Sep 17, 2008 | Dymo LabelMANAGER 100+ Printer
Fonts too small
Your instruction manual will tell you. However, there's a "Code" button that has to be pressed at the same time as the "Font" button. (Code button color should match the color of the Font button.) Keep pressing as it cycles through the font sizes (you'll see the arrow move on the screen). When you get to the font size you want, release the buttons and you're good to go!
Jun 25, 2008 | Dymo LabelMANAGER 350 Thermal Printer
I had the same problem with my label marker. Changing the batteries fixed the problem
Jan 08, 2008 | Dymo LabelManager 300 Desktop Labelmaker...
330 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Ed Mac
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
