Question about Dishwashers
I just bought a kenmore elite model # 13193 hooked it up ran it and it stopped mid cycle the detergent was released but not dissolved and the clean light keeps flashing. Ive reset it and turn up the water heater temp but still does the same thing.
  • 297 Answers
You need to hand prime all new installs with a gallon of water first,Put it in then run cycle.
Posted on Jul 15, 2009
The detergent dispenser lid does not open during the wash cycle for my Kenmore Elite 13783. I tried cleaning the dispenser and using new detergent, but that does not help. The lid opens freely when I push...
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem
Detergent Cup does not Open
heatman101
Feb 06, 2011 | Kenmore 13783 / 13785 Stainless Steel...
How to fix suds lock on Kenmore
The Sd code on most Kenmore Elite HE washers indicates a suds lock (usually caused by excessive suds do to overuse of detergent). Check for the presence of excessive suds in the washer. If you see a lot of foam, the code is likely caused by this problem. You will likely be able to drain the washer and spin out the clothes once the suds dissipate. Run an empty cycle with 1 cup of liquid chlorine bleach through the washer to help rinse out suds residue. If you see foam emerging during the empty cycle, you may need to repeat this process. You can also use Washer Magic or AFFRESH to help clean suds residue out of the washer. These products are available at your local Sears store or the grocery store. Make sure that you are using HE (High Efficiency) detergent in the appropriate quantity. You may need as little as a tablespoon of detergent in a high efficiency washer due to the low water level. You may need even less for a while since the clothes will likely have detergent still dissolved in the fibers that will emerge during subsequent wash cycles.
There are many different models of Kenmore Elite HE washers. If you do not see any apparent problem with excessive suds or need more help, resubmit your question with additional details and the full model number of your Kenmore Elite HE washer.
Jan 11, 2011 | Kenmore Washing Machines
Kenmore Elite dishwasher will not dissolve soap or wash well.
Temperature should be 140F. and the units heater should energize during fill to achieve this.
May 19, 2010 | Kenmore 24 in. 15173 Stainless Steel...
Kenmore Elite Oasis - stopped mid-wash!
run it through a diagnostic test cycle; with unit plugged in, but not in operation, press and hold the rinse button for 4 sec, then release for 4 sec, press for 4 sec, release for 4 sec, press for 4 sec,then all the lights on the main control panel will come on indicating enterance into diag mode, let this test cycle through until you get an error code, then correspond that error code with the one in your owners manual and correct as needed, or if there is no error code, check the drain pump by removing the back panel of the unit while there is no power to the unit and disconnecting the hoses from the drain pump and checking for any blockage... if that checks out ok, you may have a software problem and should test these as needed per the service manual that you can order at sears for your unit.
Aug 06, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
F35 & SuD error codes on Kenmore Elite Washer
F35 has to do with the pressure switch which is located under the top panel on the back right. It will have a little black hose hooked to it. This happens when SUDS or detergent somehow gets up into it and usually locks unit out. Only solution is to replace pressure switch. You can find the tech sheet behind the bottom front panel usually tape to the back side of that panel or taped to the bottom right side inside unit. Hope this helps
Jun 09, 2009 | Kenmore Elite 45986 Front Load Washer
Code F20 is appearing on me washing machine
http://www.fixya.com/support/r3608632-f20_error_code
May 27, 2009 | Kenmore HE2 Plus Front Load Washer
My dryer stops in mid cycle and gives me an error code of E1
It is a bad thermistor on the blower housing
http://forum.appliancepartspros.com/dryer-repair/1379-kenmore-elite-e1-sensor.html
Apr 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore elite quiet pak 4 ''suds'' error
I also gots suds error and then "F"?
my clothes were soaked....i can't get the machine to drain now????
Nov 17, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Oasis HE/ Error Code F1
repl/ main control board reason for error code F 1 ,,,nothing else
Nov 08, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Model 16253 - Stops mid cycle
Sounds to me that the heater is not working, if you have just bought it, it must still be under Guarantee so go back to the supplier.
Nov 18, 2007 | Kenmore 16253 Stainless Steel Dishwasher
Dishwashers Logo
372 people viewed this question
Top Dishwashers Experts
Owen Barnes
