Re: vacuum is hard to push when running,easy when off
Hello, I see your question is from July. I just joined Fixya this month so wasn't here to answer. If you're still looking for an answer: It sounds like the belt is broken or stretched out so much it isn't spinning. I would suggest replacing the belt and also check the roller brushes for wear and replace if necessary. Here is a link to an online guide with illustrations to change belt and or brushes. Hope this helps.
It's an issue that the front roller isn't engaged. there's usually a belt connected to the roller on one side of it. That belt is connected to the same motor that develops the suction. You have to find that area and either pull the belt over the motor and/or the brush. Close it back up and turn it on again.
Move the carpet height control switch to a higher position if the vacuum is difficult to push. If the setting is too low for the carpet being cleaned, the brushes press against the floor preventing the vacuum from moving easily.Set to a medium-high height setting then check.Slide the "Self-Propel" button to the "ON" position if the cleaner does not self-propel.
The self-propel feature operates only when the cleaner switch
and the self propel button are both
ON.
Try this settings and check.This should help.Thanks.Helpmech.
When a Hoover Windtunnel becomes hard to push, this usually indicates that self-propelled has stopped working.
When this stops working, it can be caused by several things. The first, most common problem is that the belts have either broken, or stretched to a point where they no longer engage the self-propelled mechanism. In order to verify this, simply make sure that the machine is set to the Carpet setting, turn the machine on, and turn it over on it's side with the handle release pedal reclined (make sure it's not in the upright position). Is the brush at the bottom of the vacuum spinning? If no, this definitely indicates that your belts have gone bad and need to be replaced. There are two belts on your machine, one controls the brush, the other controls the self-propelled mechanism. We've shot a helpful video that walks you through step by step on how to replace the belts.
This is by far the most common problem that we see on your particular model:
The other problem if the belts are installed properly that would cause
the self-propelled wouldn't work would be the self-propelled actuator
arm. There is a cable that starts at the handle of the vacuum, and
runs all the way down to the floor head of the vacuum that controls the
transmission. As you pull backwards on the handle of the vacuum, the
cable pulls this actuator arm backwards, which then turns the wheels
backwards, and when you push forward it turns the wheels forward.
The
problem with the way it's designed however, is that if you pick up the
vacuum cleaner by the handle of the machine rather then using the
carrying handle on the back of the vacuum, it causes too much tension on
the actuator arm, and will cause the cable to rip right out of the arm.
This
is a VERY common problem on this model. To check and see if this part
is broken on your vacuum, step on the handle release pedal so that the
handle is in the vacuuming position, push the pedal a second time so the
machine lays flat on the floor.
Now if you look right behind
the height adjustment switch, and the rug / floor switch where the floor
part meets the upright part, you should see a cable that connects into
the actuator arm. Pull up and down on the handle and look for
movement. Is the cable loose with only a nut attached to it, or is it
resting in the actuator arm?
If this didn't help you,
and the problem is still happening, please just use the add a comment
form here on Fixya and let me know that you're still having problems.
I'd be honored to go through and do some more advanced diagnosing with
you.
I hope this we helpful to you. If you did find this
helpful, please be so kind and leave feedback for me. This is why
repair professionals like myself continue to come back and give free
repair advice, to get the recognition of a job well done.
This is a typical problem you are describing. I would recommend you change the belts, this will resolve the "hard to push" and most likely resove your issues. based on the s/n given you maching was made on sept 2004.
You will need to look @ your owners manual to see where the self propell belt is located i am sure yours is broke and need to replace,- it will not be hard to replace-Lance
There are few things that may have gone wrong: First thing to check is if when pushing pedal it moves gears located on the rear axle (you will have to take cover shell off to see that) If that works fine then primary belt may be broken (see it here). Then just replace entire set to make sure that belt type matches gears Last - the most expensive problem - the main transmission belt within transmission is broken (then I would recommend replacing entire transmission)
