Question about Mitsubishi WD-52525 52" Rear Projection HDTV
The indicator light telling me I will soon need a lamp is on again. This is my third lamp in four years. Is this normal. I also see numerous wave-like lines on the screen which are more apparent at various times. Could this also be a lamp problem?
  • 64 Answers
Generally early lamp failures are caused by poor air cooling. Check AND CLEAN (!) any filters and assure that any fans are working correctly and not overloaded with dirt. Also, is the unit in an area of dirt contamination and/or higher temps? Also, power outages will definitely shorted lamp life due to insufficient cooling when the lamp is suddenly switched off.
Posted on Aug 01, 2009
Trooper starts from cold no problem when engine warm engine management light comes on and is difficult to start engine turns for a long tme before fires up
no year, no engine stated, i4 or v6?
the cause is many hard starts
the lamp glowing means get car serviced
or scan it yourself and read the service book on that error or errors, and do the tests stated there.
as far as poor started
THIS is called misfire.
and has 50 causes
#1 is never getting a full tuneup this decade.
ill not list the nifty fifty,
in a shop , they use tools
to conduct tests (engine/spark/fueling)
saving the 50 guesses.
hot starts fail or weak
engine not really hot 180f + themostat bad.
or ECT reads 140 when its 180f actual,ECT bad.
causes flooding that. and hard hot starts.
scan the ECT when hot. first.
Feb 18, 2017 | Isuzu Trooper Cars & Trucks
How do I get the service engine soon light to go out
The "Service Engine Soon" comes on when the ECM receives information from the engines sensors that exceeds normal acceptable operating parameters. The ECM will store a code (or codes) indicating which system(s) are out of tolerance and light the "Service Engine Soon" lamp. The technician will read the codes, diagnose and repair the condition(s), and reset the "Service Engine Soon" lamp. The lamp does NOT go out on its own (in most cases), once repairs are made. There is a scan tool that is used to clear the stored codes that allows the lamp to go out. It is therefore possible that you may already have fixed the condition that set your light to on. Or not. The whole purpose of the lamp was to help avoid the kind of "hit and miss" repair methodology that you have employed so far. Many feel the need to try this as they fear the costs of a professional mechanic reading the codes and the cost of repairs. Fortunately, there are less costly options available. Many of the large auto parts chains will read the "Service Engine Soon" codes for you at no cost. They will tell you what codes are present and you can decide if you (or someone you know) can perform repairs or if you need a pro to check things out. They do NOT, normally, perform resets of the lamp as this has potential liability issues for them. If you need the lamp reset after repairs are made, you have two options; pay the pro, or buy a scan tool that has the ability to reset the light. Not all do. The cheaper units are only code READERS. Be careful when you buy. But if you watch for sales, you can usually get a low-cost scan tools that can read and reset codes for around $40.00. Good luck.
Sep 16, 2014 | 2001 Pontiac Grand Prix
Tv won't come on
Unless the arc tube is bulged--or cloudy--you cannot really tell by looking. This does sound like a bad lamp, probably # CL-110.
Apr 03, 2014 | JVC Televison & Video
Fog lamps on 2004 Tahoe won't come on.
You need to check the bulbs.These are known to go out a lot.Also you can check that you have power to the lights with a test light.Sounds like a bulb or wiring problem.I have had a few of these that are broken off because they are so close to the ground.Depending on if your four wheeling or in snow country.Hope this helps.Good luck.
Feb 16, 2012 | Chevrolet Tahoe Cars & Trucks
Have had to replace lamp twice in the last two years on my Sony KDS-R60XBR1 HDTV. Yesterday I ended up with the four blinking red lights showing on the Power/Standby indicator nothing by the lamp...
hi,
fist of all try to reset ur tv. to reset do the following.
Turn on the TV. While holding down the up arrow button on the remote control, press the POWER (on off switch) button on the TV. (The TV will turn itself off, then back on again.)
Release the up arrow button.
Dec 31, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
Hi,we have a galant 2.0 litre,year 2000,on dash,in front of steering wheel,is a small picture of a motor,can you please tell me what this is,it came on and we lost all power,motor did not stop,we turned...
this is your check engine or service engine soon light or mil {malfunction indicator lamp} your ecm has detected a fault in the systems it monitors and should have a diagnostic trouble code stored you will need to hook to a scanner /code reader and read codes this will tell reason light came on and loss of power if you have a auto zone nearby they provide this service free of charge
Aug 07, 2010 | 2000 Mitsubishi Galant
The wrench light is on on my 2008 ford focus what does this mean?
I assume you have no owners manual or never read it.
The wrench is a MIL Lamp--- a Malfunction Indicator Lamp
It tells you that something like a sensor or other issues,is out of range,as far as the PCM (Computer) sees it. When ever you get a check light,mil light,trac,abs ,etc,you go to a repair shop fairly soon,like a couple of days or so, and have the issues checked out. This will happen a couple times a year ,on most of todays vehicles,so get used to it,and expect to pay a diagnostic fee, plus repair
May 26, 2010 | 2008 Ford Focus
How to reset the brake lamp warning indicator and chime
The light will go off as soon as the light or the circuit to the light is repaired, if it is still on and the brake lights work correctly, meaning bright normal not dim looking then the monitor for the lamp out warning is defective, they are very pricey would take the bulbs out if i where you.
Dec 04, 2008 | 1995 Pontiac Bonneville
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
57 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
