Question about Goldstar DH504EL Dehumidifier
I need to know how to attach a hose to the Goldstar DH305 Humidifier
  • 308 Answers
There should be a spot on the water tank, that is threaded to fit a hose, but is blocked by a piece of plastic. You must remove the plastic "plug", the connect a hose to it. Also there is a "special" part that could be used. This part can be found at http://www.appliancefactoryparts.com/search/modelinfo.php?modelsID=117164, and I am sure other places also. I hope this helps
Posted on Jul 15, 2009
Where can I get hose ,hose attachments for my Goldstar dehumidifier? Can not locate my manual or attachments.
Fortunately, it doesn't require a special hose, as a standard Garden Hose Connection is on the left side of the water collection bucket. You may have to carefully drill a 1/4 " hole in the center of the connection, once you unscrew the drain cap. The hose should be no longer than 5' , as the drainage relies entirely on gravity to drain.
When attaching the the hose, be sure that the female hose connection has a washer in it or it will leak. Hand tighten the hose connection firmly, being careful not to crack the plastic hose connection on the tank. Also, be sure that the float valve in the tank is in the DOWN. position or the unit will not run.
Hope this helped you. Please let me know.
Jul 08, 2011 | Goldstar DH304 Dehumidifier
Hello. I have the Goldstar Dehumidifier Model DH305 - This is the third summer I used it. I only use in the summer. I clean and take very good care of this machine. I went to use it this year and it came...
hi,
It has high and low fan speeds, variable humidity controls including 'Max', and automatic shut-off with indicator when the reservoir is full.
so pls recheck the automatic shut-off when the reservoir is full .
may be the automatic shut-off botten are stymed.
good luck
gorbesia
Jun 13, 2011 | Goldstar Dehumidifiers
I would like to SEE a picture of how to hook up a hose from the DH to a drain.( no manual & cant find one for this DH 304) TO lift the bucket off & drain has become to heavy for me. Thanks,...
My DH 304 is a hand-me-down so I don't have a manual but it did come with a hose attachment which is plastic tube with a threaded end to which you attach a hose. The other end of the tube goes through a hole in the back of the unit and then through a foam screen inside the unit to slip over the drain plug. Aligning the tube and the drain plug can be tricky; it is helpful to remove the bucket to see if you're getting the tube onto the drain plug. Once you have the tube attached to the drain plug, align the tube in the hole in the rear of the unit so that the tab on the tube is inserted into the slot at the hole in the back of the unit.
Aug 26, 2010 | Goldstar DH304 Dehumidifier
Won't come on
Definitely check the air filter, it has a sensor and will stop working if it's dirty. Easy to clean by running water through it.
Jun 09, 2010 | Goldstar DH304 Dehumidifier
Goldstar dehumidifier model # DH305
I had this problem on a similar model. There is a pressure switch the tank when full pushes in, sometimes mine would stick. A little graphite for key locks was my remedy. Had to clean it up some though. Good luck!
Jul 13, 2009 | Goldstar DH304 Dehumidifier
Looking for floor drain hole cover that accepts a hose
yep home depot get one with holes and a plastic tie will keep it in place
Jun 16, 2009 | Goldstar DH304 Dehumidifier
Will not run or turn on light will not turn on
Had a similar problem with Goldstar model DH305. A solution was already posted about cutting the two white wire going to humidity control, and it works until tray fills up (no control). However, if you want a complete fix which allows you to control by selecting humidity level go to the following site:
http://www.appliancefactoryparts.com/search/partinfo.php?partsID=282871&modelsID=&typeName=dehumidifier
Part number is 6877A30013L
May 27, 2009 | Goldstar DH304 Dehumidifier
Humidifier says "bucket full", not using bucket have hose attached
Offhand, two possibilities:
1. erroneous sensor reading(s) causing system to respond likewise erroneously; and/or
2. firmware/software glitch.
Initially, I would suggest a full hard reset, that is unplug from the mains for an hour or so. This would normally revert the unit back to factory default (assuming no hardware problem). Additionally, you may want to check the sensor(s) like the a bucket full sensor often would be a float switch of some kind.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 09, 2008 | Goldstar DH504EL Dehumidifier
Goldstar Dehumdifier - draining through hose not working
Check the connection where you attached the hose. It may be plugged or covered by a plastic film from when it was molded.
Jun 09, 2008 | Goldstar DH304 Dehumidifier
Goldstar DH504EL Dehumidifier Logo
394 people viewed this question
Top Goldstar Dehumidifiers Experts
Gil Shultz
Michael Youngman
Michael Youngman
Jerry Greenberg
Jerry Greenberg
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
