Question about Whirlpool Calypso GVW9959K Top Load Washer
Every wash cycle FL shows on the screen, I have to extend the spin cycle to get all of the water out.
  • 6,784 Answers
FL
Flood condition
"FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for "FL" to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display
Check the over fill switch hose for weakness or, damage if the FL code continues. if the hose is ok, replace the Over fill switch..
Posted on Jul 15, 2009
What dose a FL code mean on whirlpool cabrio platinum
I will try and help for some reason Whirlpool likes to flip letters around which differ from the service manual FL would be an LF long fill or is it a F1 the model doesn't show in the Whirlpool data base nor parts suppliers I suspect wtw6600sb1 does the machine from initial start fill correctly then wash if so we can eliminate the pressure switch and hose after wash cycle unit should drain then fill with rinse water if the inlet valve does not let water into the machine to satisfy the pressure switch the control times out and flashes a long fill code this unit has a log valve system possible you have a bad inlet valve on the bank of valve or a bad control not outputing voltage to the valve, hope this points you in the right direction
Jan 14, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
My neptune washer stop working. has power but doesnt cycle. shows a FL code. cycle i mean as spin to start washing
FL means that the door isn't locked properly. Make sure that its locked tightly and restart the cycle
Feb 16, 2011 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool calypso top load washer GVW9959k stuck on FL
FL=FLOOD CONDITION
I bet I know what the root cause of the problem is. TOO MUCH DETERGENT. Why do I yell that? OK here is what happens. Suds make the computer monitor work overtime to wash the clothes. The the computer measures the amount of water being used. The computer is also trying to correct the suds problem by adding water during hissy-cycles. (I call em hissy cyles.) Solution: Clean the soap dispencer use HE soap and use the right amount which is:
HE: (2) Tablespoons Per Wash load
HE 2X (double concentrated) : (1) Tablespoon
HE 3X (triple concentrated): (1) Teaspoon
Calypso Service Manual
May 12, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Washer won't drain..like filter is clogged
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%@#$
Mar 27, 2010 | Kenmore Elite 21082
Model 110.21062 calypso drain issues
Flood Condition:
"F21" (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Mar 27, 2010 | Kenmore Elite 45986 Front Load Washer
Clothes are still very wet when cycle completes.
clean the exhaut tube from the dryer to the ouside of your home
Feb 01, 2010 | Kenmore Washing Machines
What does FL mean on the rinse and spin extend cycle?
Flood Condition:
Oct 20, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Not draining water, not spinning, error code FL
I THINK, (Not sure, but fairly convinced) that the error FL is a warning that your FiLter is blocked. When this happens, the pump can't drain the water in the alloted time that the machine has set to do it, so at the end of the pump out, there is still water left. Bacause of this, it won't allow the spin cycle to engage. You need to find your filter and clean it out. If this fixes the problem, make a regular habit of checking and cleaning the filter every month or so (Depending on how much washing you do... You will figure out a good time scale after you have done a few checks and decided how fast the lingt and rubbish builds up in the filter).
Oct 09, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool Calypso Cycle Problem
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#%!^
Mar 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
147 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
