Question about Starbucks Saeco Italia Digital Barista Coffee Machine
Saeco itallia malfunctions
My Italia did not finish its cycle when making a cup of espresso. The dispenser was at the top of the stroke with the puck still in the compression area. This made it where it not only didn't work but the dispenser could not be removed. I took the dispenser unit apart so I could get it disengaged from the main body of the espresso maker.
Now the shaft that drives the dispenser mechanism is not in a position so that I can put the dispenser back in. I have tripped all the sensors and made the machine go through a coffee making cycle. When it is done the shaft is still not in the right position to receive the dispenser. Strangely it is not in a postion to receive the dispenser at all, it is a hair past the postion when the dispenser is at the top of its stroke (a hair past full compression of the coffee puck). Any help would be appreciated.
Steve Brant
  • Starbucks Expert
  • 223 Answers
Check this document out to make sure the gear is in the right location. The machine in the document is a different type however the way the gear lines up is the same.
Saeco Parts and information
Posted on Nov 17, 2007
Starbucks Saeco Italia Digital Barista Fully Automatic Coffee Machine will not prime!
Here is what is said in the manual:
"Direct the steam arm on the drip tray.
Open the steam/hot water knob until a
steady stream of water is dispensed. Close
the knob. Insert the filter holder into the
brew head to pre-heat the filter holder.
The machine is now ready to dispense
Apr 26, 2017 | Starbucks Saeco Italia Digital Barista...
Saeco Italia espresso machine. problems with water light on even though water tank is full. Not sure how to get water flow and/or prime the pump.
To prime the pump run the hot water cycle for a few seconds, also when inserting the tank on the machine make sure it slides down the back making contact that will help the reed sensor, find the magnet in the float.
Sep 18, 2010 | Starbucks Saeco Italia Digital Barista...
I have a saeco italia and coffee is too weak - i have cleaned the grinder, and have adjusted the setting in more ways than one can count. No puck is formed once dispensed. I have also de-scaled the...
Hi If you don't get the grinder back together correct and have the dials set in the bean hopper before attaching you will not get the correct grind and dosage for strong coffee. Dull burrs will usually give finer grinds but they will clog up quickly.
Feb 05, 2010 | Saeco Vienna Espresso Machine
SUP021 YR keeps getting clogged
go to espressotec logo there you find how you can clean grinder.if still you dont have coffee try explain better whats hapend with machine when you want make espresso,good luck
Sep 04, 2009 | Starbucks Saeco Italia Digital Barista...
Saeco italia
Put a container under the steam pipe, open the steam knob and make a cup of water (Tea).
Hope this will help you.
Best regards
Oct 19, 2008 | Saeco Vienna Espresso Machine
Saeco Italia water lite and green lights flashing
Try to open the steam knob and make a cup of water (tea), see if you can get a full cup or just a half.
How old are your machine?
How often do you descale the machine?
Best regards
Sep 05, 2008 | Starbucks Saeco Italia Digital Barista...
Saeco Italia Sup021 YR flashing red malfunction light
I found a link in the forum where there are some informations.
Aug 22, 2008 | Starbucks Saeco Italia Digital Barista...
Cannot properly align Saeco Italia Coffee Dispenser
new to you what make that turn is 2 plastic gear inside maybe gear are loose and jump maybe that why it doent aling to check that out you need to open like everything a big job but if you whant a saeco coffee and belive me it worth it cheers
Jan 22, 2008 | Coffee Makers & Espresso Machines
Starbucks Saeco Italia Digital Barista Coffee Machine Logo
106 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
