do you still see the menu when inserting / running the DVD in your portable DVD player? if so then we have a bad video converter and if not, there is a possiblity that digital connector of the player to the ldc monitor has been disconnected or has been torn.
this specific part is available, lemme know what we are dealing with first so we can go on having this one troubleshot.
Toshiba model # SD-P1400 was working fine however when we tried to play recently the screen was...
(More)
Toshiba model # SD-P1400 was working fine however when we tried to play recently the screen was almost black
switch power on/off no good .. broken for sometime i did pushed or press very hard with the...
(More)
switch power on/off no good .. broken for sometime i did pushed or press very hard with the finger... where i will find this part? Thanks...
Model # SD-P91SKN will no longer spin the discs. When I try to play a disc, it reads "No Valid...
(More)
Model # SD-P91SKN will no longer spin the discs. When I try to play a disc, it reads "No Valid Disc." It does not even spin the disc. I have only had this 6 months.
