Question about Sony STR-DG820 Receiver
I have a str dg820 only about 2 months old. Recently went to power up and I get PROTECTOR message and it shuts down. I checked all speaker connections and they appear to be fine. It worked well for two months..
    Novelist:
  • 133 Answers
Try disconnecting everything (all inputs, outputs and speakers, make sure there is no cable plugged into your unit except the power cord), turn it on, if it still shows the protect message, you have an internal short or a burnt out component inside the unit, possibly a desoldered contact on one of the connectors which generates internal noise of such intensity that it sends the unit into the protect mode.
If, after trying the above mentioned, there's no message, some other possibilities are:
- a bad speaker or speaker cable
- a bad signal interconnection cable
- a fault in any of the other units connected to your reciever/amplifier
Hope you cand find something out...
Good luck
3rq8 (Triarcuate)
Posted on Jul 15, 2009
Protector
Look for any bulging on metal capacitors. As they age they can fail, but won't show it until power is stopped for a time. Then when you try to power up the system the fault shows itself Replace all that look that way
Jan 14, 2014 | Sony Str Da777es 600 Watt Receiver
My sony receiver STR-DE135 is showing a protector message
Check for shorted speaker cables, or even a bad speaker. I'd start by disconnecting all speakers, see if the indicator goes out. If so, try one speaker at a time until you find which channel is bad, and then examine the cables carefully for things like a stray wire strand. Less likely, but possible is a shorted speaker. If you disconnect them all, and still have the protector circuit on, it's an internal issue, and you're going to need a technician.
May 30, 2011 | Sony STR-DE135 Receiver
My STR-DE925 reciever isn't giving me any sound. When i turn it on everything works like normal, kicks on, and there is a click; but after a few seconds the display switches from whatever input it was on...
check speaker connections.sounds like the system is trying to stop some thing more serious happening by shutting itself down.a pain yes but saves blowing something up.if no luck,then definately send in for repair
Oct 17, 2010 | Sony STR-DE925
I get a message "protector check code 11" and then it powers off
Page 59 of the manual (avaliable at retrevo.com after you register)...
"PROTECTOR/CHECK CODE 11
Irregular current is output from the speakers. Turn off the receiver , check the speaker conenction and turn on power again"
What this means is it senses a short circuit in one or more of the speaker paths. Disconnect all speakers, see if it works with none; then start connecting speakers again until you find the problem.
Feb 13, 2010 | Sony STR-DA5000ES Receiver
Message "PROTECTOR"
Disconnect all speakers at the receiver and power it back on. If it stays on, check all speaker wires and speakers for shorts. If it cuts out, it needs service. If you need detailed troubleshooting help on this after testing receiver without speakers connected and it passes, post a comment and I can walk you thru it. Hope this helps.
Oct 24, 2009 | Sony STR-DE625
Amp lights up (display) and then fails to switch
You need to replace the power amp transistor or mosfet. Bring to electronic technician for repair.
Jul 24, 2009 | Sony STR-DE998 7.1 Channels Receiver
MySony str-da5000es is showing error code 11 and shut off by itself after few seconds.check and disconnect all speakers, unplugged power from wall and still showing error 11. am missing something in here...
error code 11 (protector) - According to the manual, 11/PROTECTOR means, "Irregular current is output from the speakers. Turn of the receiver, check the speaker connection and turn on the power again." Most likely, a strand of speaker wire is shorted to the chassis at one of the speaker terminals.
Hope this helps !
Jun 17, 2009 | Sony STR-DA5000ES Receiver
Help
check/replace your speaker wires. If a wire came loose, it will go into "protect" mode and shut down, to protect from a short circuit.
Jun 16, 2008 | Sony STR-DE525
Open Questions:
See all Sony STR-DG820 Receiver Questions
Sony STR-DG820 Receiver Logo
518 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
