Trio 1 - MACHSPEED -STEALTHG210.1 10.1" Stealth G2 Android 4.1 Tablet Logo
S
Sandy Hovland Posted on Jan 03, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have a Trio Stealth -10 wont connect to the WiFi
Raymond Perry
Level 2:
New Friend:
  • Expert 45 Answers
  • Posted on Jan 04, 2016
Raymond Perry
Expert
Level 2:
New Friend:
Answers
45
Questions
0
Helped
12998
Points
128
Is wifi turned on on the tablet? If not, go to Settings>Wifi and turn it on. The device should then automatically scan for networks.
If you are able to connect to your network but then cannot actually get to the Internet you may just need to restart your router. You might get something like "Obtaining IP address" for a long time and then get "Limited" connection. Correcting this may be just a matter of unplugging it for about a minute then plug it back in. Wait 4-5 minutes for the router to boot up completely then try connecting again. Some routers are sensitive to new devices. When I had AT&T Uverse router I would have to restart it every time I tried to add a new wifi device.
Hope this helps.
How do I connect to the internet
tap setting slide wi-fi to on position the device will autoscan for wifi select your wifi and enter your wifi password
I have a trio stealth i need a password for wifi
You must have a wireless router, connected to the internet. then you have to setup the router and the wireless connection. Don't forget to setup a password protected connection with WEP2, or else someone else can use your connection and consume your data plan.
My trio stealth-10 tablet is frozen
Press the volume up and power button for about 10-15 seconds to reboot.
I have a wifi password an i can't figure out how
From the main menu select settings and then wi-fi settings. This will prompt you to connect to network and if it finds your wi-fi router it will ask for the password.
http://www.brandsmartusa.com/pdfs/manuals/20179969.pdf
Why won't my tablet connect to my wifi ....
Once you identify your wireless network (SSID) you must put in a "password" or network key.
I can not connect to internet with my stealthg2 eventhough wifi strength strong
check to see if it's doing MAC filtering(turned on) if so you need to add your mac address for the device
Wifi connection/ IP address unavailable
I would guess your wifi broke.. but you can always ... try wifi elsewhere to verify... if it works then you need to manually connect to your wifi... I would attempt to get your Ip off the working one and copy the same IP and DNS for your wifi... since it's a tablet I would just reset it to factory settings if it just is stuck... you can back up your files VIA google or BUMP app
5helpful
2answers
Trio stealth g2 tring to turn on wifi can't and won't allow acess to wifi settings
G0 into settings..then go to wireless network . you should see wi-fi slide the bar to ON. make sure the airplane mode is in OFF
then at the top on right..you should see SCAN.. RUN THIS AND FIND YOUR NETWORK..HIT ADD AND GO FROM THERE
Top Trio Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Trio Tablet and eReader Expert? Answer questions, earn points and help others
