Question about Hitachi 53UDX10B 53" Rear Projection Television
Need a digital hd tuner for 53udx10b - Hitachi 53UDX10B 53" Rear Projection Television
    President:
  • Hitachi Master
  • 1,779 Answers
You have to use a Satellite HD box or a Cable Co. HD box. Your set did not come with a ATSC/QAM tuner for digital reception. Your have to use the RGB component inputs in the rear of the set.
Posted on Jul 15, 2009
Lite on - hd-a740gx
The LG HD-A740GX does not have a digital tuner. The analog tuner included depended on the country of sale; it has a PAL (UK) or NTSC (US) tuner. You'll need a set-top box (digital-to-analog tuner or cable or satellite box) to provide the signal for the unit to record anything.
I wish that I had better news for you.
May 07, 2012 | Televison & Video
Hi, I live in a flat in London with a shared rooftop aerial (no idea of spec). I have a Sony KDL-46X2000. The built-in freeview tuner doesn't seem to recieve any HD channels. Is the built-in tuner the...
Make sure you have a good connection from antenna to TV. Check antenna and cable and cable connection to TV. Select DIGITAL button on TV remote when wanting HD channels. Remember HD channels are always digital. Also, any given TV station may not be broadcasting in HD at a given time. They can broadcast in digital but in standard definition sometimes. Your TV has a built-in DVB-T tuner. Try executing a channel scan to pick up all available channels. On-screen menus go to Digital Setup, then Digital Tuning, you can auto-tune or manual tune channels. The TV should take a few min. to scan thru available channels and store the channels its finds. Check with anyone in your area to see if they get HD channels (it is possible to be outside of the range of some TV stations) Your TV is a 2006 model and should still be compatible with local digital TV broadcasts but keep in mind digital signals could change in the near future (DVB-T2) and you may need a tuner/converter box to make the TV compatible.
May 01, 2011 | Sony Bravia KDL-46X2000 46 in. HD-Ready...
Sceptre x23BV-naga 23" LCD HDTV needs a digital tuner replacement
just get a hd standalone tuner and hook it up to one of the inputs. way cheaper solution.
Apr 09, 2010 | Televison & Video
It is digital (HD), I don't need converter?
If your set is labeled as "HD ready" then it will accept HD signals from, for example, an external HD tuner or other source. The set can be HD Ready, as is my Samsung TV, but my set has only the older NTSC type tuner. I therefore use a digital stream HD tuner which works great to receive over the air signals. Also digital does not mean a set is HD. There are sets that are standard definition digital sets that can receive digital signals, but do not produce HD. If you are using cable, in most cases, you can continue receiving your cable as usual.
Nov 25, 2009 | Toshiba 36A40 36" TV
Can the tuner be upgraded to get digital signals?
There is no way to directly change the internal tuner to receive digital/HD signals. I would simply purchase an external tuner unit, but be sure to get one that has at least component signal outputs and is HD. You want to be able view HD & not just digital. One of the small tuner boxes would get digital, but not HD. I personally have a Digital Stream tuner with a set I own and have been very pleased with it. The tuner has many extra features and also has an NTSC output I use for recording with a regular vcr. Shop for an HD tuner unit. You will be impressed by the kind of performance you will get from this set.
Nov 09, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Toshiba Tv - Does it have a digital tuner?
That unit has a NTSC tuner. May be HD Ready but it does not have a digital tuner. Unless you live quiet close to a local Broadcaster, rabbit ears would be useless.
The only way you would be able to get HD is using a HD Set Top Box, HD Satellite System,
or HD Cable BOX, using the Componet or HDMI inputs.
Hope this helps
Skyassoc
Jun 22, 2009 | Televison & Video
Hitachi 53UDX10B HD Converter
In the USA, "HD Ready" refers to any display that is capable of accepting and displaying a high-definition signal at either 720p, 1080i or 1080p using a component video or digital input, and does not have a built-in HD-capable tuner.
With that said your unit can display HD but does not have a HD-capable turner. You will have to have a converter box to obtain this for over the air channels. If you have any other source that can give you a HD singal (cable some DVD's, blu ray)your unit can display it. Hope this info help's.
# NOTE - If this info was helpful to anyone please click on yes!
Jun 09, 2009 | Hitachi 53UDX10B 53" Rear Projection...
No digital channels
This TV is not able to understand digital channels because its tuner is not able to find that band, it works only in analog channels. To be able to get HD channels is needed a decoder box that has digital tuner build in. for a tv to understand HD Channels with analog tuner is to us to try to speak at the same time different languages.
Mar 16, 2009 | RCA HD52W56 52" Rear Projection HDTV
PROBLEM WITH GETTING LOCAL hd CHANNELS
You need to have a set top box.
By law, as of March 1, 2007, almost all televisions should include a built-in tuner (called HDTV, digital, or ATSC tuners) that can receive high-definition programs over the air by simply connecting an antenna. Your HDTV doesn't have such a tuner, you'll need to connect an external tuner (or cable or satellite box) to watch high-definition programming. External over-the-air HDTV tuners currently cost at least $150.
Nov 14, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Digital tv
Good Day, tuff65;
Today with "HD TV" get a good UHF/HD antenna. You can get at any local Best Buy, Circuit City, Radio Shack etc.
Good Luck, big IRISH. PS: Inside or outdoors.
Sep 03, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
82 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
