Question about Sharp R-930AK Convection/Microwave Oven
Sharp930 ak You must press on the door open button slightly to get it to operate,otherwise the carrousel operates without any warming
    President:
  • Sharp Master
  • 1,922 Answers
You need to have the door re-aligned or the safety interlock switches are out of adjustment
Posted on Jul 27, 2009
GE Profile microwave oven PEB7226SFSS quit warming food but appeared to be on/operate with light on/timer counting down. Installed door switches-now the microwave "works" only when the door is open
Sounds like on reassembly you reversed wires to door switch.
switch might have letters C NO NC (common, normally open, normally closed) one wire goes to C common, the other to NC normally closed. Try reversing the wires.
If you use meter measuring continuity meter on C and NO should be high resistance until you press switch.
meter C to NC measures low resistance until you press switch then measures high or infinity (open)
Sep 28, 2016 | GE Microwave Ovens
I have a Sharp Microwave Carousel R-420B. I put a bowl of soup in , closed the door, pressed Minute Plus, and hit Stop with approx 20 seconds to go... pressed the door release but nothing happened... door...
Usually, the door lever or hinges is the cause of this type of problem.
But in this case, I don't think the door lever or hinge is the cause of your problem.
I think the door is jammed and only needs some force before is can open or unjam.
Use your hands or a flat Philips screw driver to forcefully open the door. Don't apply too much force. Just apply a reason amount of force that could open the oven door.
Before you attempt to forcefully open the microwave door, leave it for about 45mins to 1hr, after that forcefully open the door.
If the above doesn't help to open the door, please let me know so that I can direct you further.
I wish you good luck.
Regards.
Mine does this occasionally, and it's because the door hinges have got a bit out of line, allowing the door to drop slightly, so the catch mechanism won't quite disengage.
Look along the bottom edge of the door and see if it has dropped lower than the front panel next to it. Try applying a bit of upward pressure on the bottom edge with your fingers, while pulling towards you at the same time, and with your other hand press the release button.
If that gets it open, remove last night's failed meal, open the door fully and carefully force it up a bit at a time, to bend the hinges back to level - keep pushing the door back so it nearly closes, and look at the bottom edge to check on progress. When the bottom of the door looks level with the panel , try closing it fully and see if the release button will open it again.
Jun 03, 2011 | Sharp R420L Microwave Oven
I have a microwave hood combo - kenmore. the power goes out when i open the door or closes it, then it comes back on -
Hi and welcome to FixYa, I am Kelly.
You have a bad door interlock switch or bent switch actuation arm. Should someone open the door while the microwave is operating without pressing pause/stop when the unit has this symptom will cause the internal fuse to blow and it will not operate until the fuse is replaced. The switches are inexpensive but takes someone with some reasonable mechanical skills and knowledge of using a meter to isolate which of the 3 door interlock switches is causing the problem.
Thanks for choosing FixYa,
Kelly
Mar 02, 2011 | Kenmore Microwave Ovens
I need to know how to operate my Kenwood KGTS23 Microwave. I put it on, operate it on how I understood it, but it doesn't warm my food (it remains cold) Please where can I get a user guide/manual for...
Use a microwave safe dish and put in some water. Now open door and keep the dish on the glass plate. Close the door, select the power to be medium or high. Or choose a fast cook. Press 0 and the start button as the microwave should start up. If there is no heat after the cycle then it is possible that the magnetron, the capacitor or the fuse is open.
Jan 08, 2011 | Microwave Ovens
I have a Tappan Model 56-9338-10/04 Microwave. The microwave stays on when you open the door! Can someone help?
  • Don't operate an oven if the door does not close firmly or is bent, warped, or otherwise damaged.
  • Never operate an oven if you have reason to believe it will continue to operate with the door open.
  • As an added safety precaution, don't stand directly against an oven (and don't allow children to do this) for long periods of time while it is operating.
Nov 28, 2009 | Microwave Ovens
Ge profile microwave oven runs when door is open
Good way to cook yourself! It has to be a stuck door interlock switch--the case needs to be removed to get at the switch. It could be either the mechanism that operates the switch or the switch itself is bad. The switch normally makes a click when the button is pressed. Unplug the unit when the case is removed.
Jul 16, 2009 | Microwave Ovens
Microwave will not heat food. punch in heating time, press start and nothing happens
HI. your control board has failed. you will need to replace the control board asap if possible.
May 30, 2009 | Panasonic Microwave Ovens
My microwave is not working and the repair in scheduled for April 3rd. This is not acceptable. Please helop me to find how I get in touch with the department that handles scheduling. My panasonic...
This is a very serious problem safety first! A microwave oven is safe
As long as the door is closed but is deadly if allowed to operate with it open.
There are safety switches built into the oven that disengage the high powered
Microwaves when the door is opened. They are not operating properly or
The oven would shut off when the door was opened. Microwaves can cause
Severe burns, cataracts, pacemaker malfunctions and cancer. Also microwaves
Can damage the electronics that control the keypad , you microwave oven
Is not just malfunctioning it is a severe health risk and sould not be used.
Unplug it and it must be repaired or replaced if it is still under wannty
And you pay very little are nothing let them fix it otherwise replace it.
Feb 25, 2009 | Panasonic NN-S541 Microwave Oven
Door latch and Screen
This is because of the broken latch. There are switches inside the oven that are operated by the door latches to make sure you're not trying to use the oven with the door open. With the new door, your oven should be back to normal.
Feb 06, 2009 | Whirlpool Microwave Ovens
Sharp R-930AK Convection/Microwave Oven Logo
48 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
