Question about Insignia NS-L32Q-10A 32 in. HD-Ready LCD TV
Cannot adjust color - Insignia NS-L32Q-10A 32 in. HD-Ready LCD TV
    Novelist:
  • 85 Answers
Have you turned the controls from one of the presets? Presets are Vivid, Movie, etc. Most sets have to be in Custom or Customize to adjust the controls, likely on-screen with one of contrast, brightness, color, or tint selected. If those are horizontal bars then up/down selects which and right/left select decrease/increase or red/green for tint. Start with 50% if no reset (0% for R/G) or start with the non-Vivid settings. Consult AVS forums for you model to get better settings. Rules of thumb: Brightness should be as dark as possible without losing gray scale at lowest part. Contrast should not be so high that whites bloom or make it hard to see. Color should not blow out any color nor be unnatural. Tint is best judged on flesh tones. -Ken
Posted on Jul 15, 2009
Color is over red
The color of the Television is compose three color,the Red,Green and Blue.First thing to do is try to adjust the color adjustment.Adjust and balance the color.
Aug 18, 2011 | Sony KV-XR29M50 TV
Cant adjust color...
Generally monitors do not actually have many options to adjust color balance. But you can adjust the colors through your operating system: Windows 7/Vista can be adjusted by following the instructions Here.
Mar 06, 2011 | Samsung SyncMaster 920NW Monitor
How to adjust picture color
To adjust color first of all set contrast and color controls to minimum,adjust the brightness to see clear picture than add contrast to get perfect black and white picture than add color to it for a good quality color picture.
Jan 22, 2011 | Symphonic ST419E TV
My phaser 740 has print that flakes off when you print pictures with real dark areas. I assume it needs more fuser heat or less paper speed. The problem is I can' t figure out how to adjust either of these...
Recalibrate the colors. Flaking is sometimes caused by more ink/toner than can be fused to the media. There's a limit for the total amount of ink/toner. Yours may be set too high.
You'll need a copy of the Printer's User's Guide (also Downloadable from Xerox.com)
Controlling Color Density
When colors look faded, adjust the toner color density to extend the life of the components.
Print and use the Color Reference Page 1 In the printer's front panel, scroll to Calibrate Colors,
press Menu and print the Color Reference Page. 2 Compare the Color Reference Page to the Color Density
Samples on page 39. Make a note of the value (-10 to +10) for each color that most closely matches the samples.
3 Adjust the density for each color: Enter the value noted in Step 2 in the Calibrate Colors menu, under Adjust Each Color.
? Decrease color density: Press . ? Increase color density: Press --->.
4 Reprint the Color Reference Page; check your adjustments
Dec 09, 2010 | Tektronix Phaser 740P Laser Printer
How to adjust color on sk-32h570d
This is from the MANUAL
www.westinghousedigital.com/pdf/197_User_Manual.pdf
PAGE 27
A-1 Settings
Use the Settings sub-menu options to manually adjust the display quality. Use the ◄/► keys to adjust the
option level.
Adjust the luminance level.
Adjust the brightness to darkness ratio.
Adjust the balance of the red, green, and blue colors in the display.
Adjust the color intensity.
Adjust the sharpness or softness of the display.
Adjust the brightness level of the screen backlight.
AND this is from the troubleshooting procedures in the manual
PAGE 64
Wrong, abnormal or missing colors
・ If any colors (red, green or blue) are missing, check the video cable to make sure it is securely connected. Loose or broken pins in the cable connector could cause an improper connection.
・ Press and select Picture | Settings to adjust the Hue and Saturation settings. You can also select
Picture | Advanced to adjust the Color Temperature settings.
・Connect the TV to another computer and check if the problem is with the computer screen.
Other than that there is no mention of color adjustment
May 08, 2009 | Westinghouse Electric SK-32H570D 32 in....
Can not adjust screen color -
You can adjust the colors manually on the Chroma circuit Board at the back of the CRT. Or check for any cold solder and do drysoldering. Cheers
Nov 30, 2008 | Xerox XA7-192i 19" LCD Monitor
Faces too pink in my ip6700D
Solution: Manually adjust color from the driver (Windows)
Manual Color Adjustment Follow the steps below to make fine adjustments to the color hue for the printed output. These settings will only make minor color adjustments. If more drastic color adjustment is necessary, use an image editing application.
  1. On the Windows desktop, click 'Start', point to 'Settings', then click 'Printers' (Windows XP: On the Start menu, click 'Printers and Faxes', Windows Vista Click / Select Start from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'.).
    Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
  2. Windows 2000/XP/Vista: Right-click the printer icon, then click 'Printing Preferences'. Windows 98/Me: Right-click the printer icon, then click 'Properties'.
  3. On the Main tab, select 'Manual' for 'Color Adjustment.'
  4. On the Manual Color Adjustment screen, adjust each color individually to achieve the desired effect.
    Note: This screen may vary depending on model.
Dec 24, 2007 | Canon Pixma iP6000D InkJet Photo Printer
Color printing
Nov 16, 2007 | Canon Pixma iP6000D InkJet Photo Printer
Can't adjust the color
Sounds like a technician will have to determine if the blue CRT is failing or just needs to be adjusted.
Apr 23, 2007 | Hitachi 43GX01B 43" Rear Projection...
LCD brightness question
You can adjust the brightness or color of the LCD display as needed. 1. Set the POWER switch to CAMERA position. (In the PLAYER mode, you may only setup the LCD while the tape is playing.) 2. Open the LCD screen, and the LCD switches on. 3. Press the MENU button. 4. Turn the MENU DIAL so that VIEWER is highlighted and then press the ENTER button. 5. Turn the MENU DIAL so that LCD ADJUST is highlighted. 6. Press the ENTER button to enter the sub-menu. 7. Turn the MENU DIAL so that it highlights the menu item you want to adjust (BRIGHT SELECT, BRIGHT ADJUST, COLOR ADJUST). 8. Press the ENTER button again. You may select NORMAL or SUPER in the BRIGHT SELECT feature and press the ENTER button to save the setting. Use the MENU DIAL to adjust the value of BRIGHT ADJUST and COLOR ADJUST. You can set values for BRIGHT ADJUST between 00 ~ 35 and COLOR ADJUST between 00 ~ 35. 9. Press the MENU button to finish the setting.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Insignia NS-L32Q-10A 32 in. HD-Ready LCD TV Logo
508 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
