Question about Maytag SAV2655A Top Load Washer
Maytag SAV 2655 AWW prblems?
I just bought a 2004 Maytag washer m# SAV 2655 AWW and wonder if there have been problems assocated or recalls? Thanks in advance. BillKuhlke
Re: Maytag SAV 2655 AWW prblems?
Take a look at for this model
seems almost everyone's had problems with it
Posted on Dec 03, 2007
Forget the "quiet pack"... when its spinning sounds can hear it no matter where you are in the house....
Posted on Jan 03, 2010
0 characters
3 Points
I have a Maytag Neptune MAH 6700 AWW. It is shutting off and giving error code tE. Customer service does not recognize the error code. Can you help?
This is a problem with the signal from the water heating element "Thermistor" a Thermistor is a solid state sensor that senses temperature, in this case water temp. The Thermistor is part of the washers water heating assembly and not sold separately from it. There is a factory repair bulletin associated with the problem and the new part has improved reliability. I can't understand what the Maytag folks you called would tell you it is not listed, it is a common fault in the Neptune. Please rate my help. Thanks
Jan 23, 2012 | Maytag Neptune MAH5500B Front Load Washer
Have a maytag model PAV2300 Aww it grinds i have
gringing noise is never a good sign check the main bearing these are notorious for having bearings go and if it is bearing find a new machine its not worth fixing it is costs more then the machine is worth to replace
May 03, 2010 | Maytag PAV2300 Top Load Washer
Maytag super capacity washer #SAV 4655 AWW Makes a verry loud squeel in spin cycle only. Does not leak any water or oil.
This can be a symptom of drum bearing wear. A quick check for wear is to see if the inner drum moves up and down relative to the fixed outer drum. It should only move a minute amount. If it moves more than a milli metre or two, it is probably worn bearings. You can obtain bearing kits for most makes. If it is making unusual noises while washing too, check there is not a wire or similar object trapped half way into one of the drum holes. A high pitched whine is sometimes caused by the motor bearings (but most brush/commutator motors whine a bit anyway on higher speeds, it is normal). Oil sparingly so as not to contaminate the carbon brushes.
Aug 28, 2009 | Washing Machines
Maytag SAV 3652 AWW Washer: During spin cycle, burning smell occurred while making unusual noise. (For months, major squeaking during agitation).
Bad water pump. Replace water pump.tip machine back,Look under machine, remove belt, turn pump by hand, if not spinning freely replace pump.
Mar 23, 2009 | Maytag PAV2300 Top Load Washer
Maytag SAV washer leaking all over floor
I have the exact same washer with the exact same problem. I have a home warranty that covers appliances so when they sent out the Sears technician, he took a list of parts and replaced about 9 things for a grand total of $450. If I didn't have a home warranty that only charged me $55 to do it, I would have just bought another non-Maytag washer.
Jan 23, 2008 | Maytag Legacy Top Load Washer
Noisy spin cycle
Hey ****, what you are hearing is the spin bearing. Maytag redesigned the bearing kit on this washer, there must of been a lot of leaks causing the bearing to go bad. They put out a service flash...TDL-0060-B. New seal and bearing kit, part number12002470. You may want to contact Maytag on this for it could be covered. I know you have 5 years warranty on the transmission and If they change that, they have to use a new seal and bearing. back.
Oct 06, 2006 | Maytag SAV5710 Top Load Washer
Maytag SAV2655A Top Load Washer Logo
634 people viewed this question
Top Maytag Washing Machines Experts
Richard Roth
Richard Roth
Al Clark
Todd Marr
Todd Marr
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
