Question about Acer Aspire 5100 Notebook
The mainboard and the touchpad is frozen, doesn´t work with external also.
Touchpad problem
I am going to assume the touchpad doesn't work, since you didn't elaborate much in your description. If it isn't doing anything, you need to reinstall the drivers for the touchpad. If you have an external mouse laying around, use it to go to the acer site and redownload the touchpad software and follow the instructions to install it. The next time you boot your computer, it will work.
Jul 03, 2012 | Acer Aspire Computers & Internet
Cursor/touchpad is not working on my compaq
First option try to connect external USB type mouse, if it's working. second option need your touch pad check-up software driver in the device manager area. need update. or try to restore your operating system (OS). back to the time that working properly your touchpad advice.
Let me know if not yet working your touchpad. try that solutions first.
Oct 18, 2011 | Computers & Internet
Built in mouse has not worked properly from day 1. Now my external mouse won't work either. I tried a different external moue, but it doesn't work either.
Unplug everything except the power cord, including the following:
Speakers
Printers
Scanners
USB devices
Personal Digital Assistants (PDAs)
USB flash drive or other external storage devices
External Monitor
External Keyboard
External Mouse
If your computer is attached to a docking station, undock it.
Make sure the touchpad or your finger has no dirt, grease, liquids or food on it (the touchpad has to make a good contact with your finger to work correctly).
Turn the computer back on and retest the touchpad.
When the touchpad still does not work correctly proceed to step 5.
When the touchpad does work correctly, attach one external device at a time and test the touchpad to see which one may have caused the issue.
Make sure the latest driver for the touchpad is installed (you may need to use a external USB or Bluetooth mouse), for more information refer to:
"How to Use the Drivers and Downloads Website"
May 26, 2011 | Dell Inspiron 1525 Laptop
My friends HP G60t PC Notebook has a frozen cursor. The keyboard works, but not the touchpad. Thoughts?
try to reinstall the latest touchpad driver using an external mouse through safe mode. hope this helps.
Apr 16, 2011 | Computers & Internet
I have a probleme with my asus eee 900 ;the touchpapd is not working any more can i get omme hlp have this problem for a month now
There are many reasons that your touchpad doesn't work.
First check if you have in the BIOS, the Multi pointing devices Enabled. Then go to the device manager and check it any pointing device is installed but first disconnect any other external component form your Notebook like external mouse, keyboad and other pointing devices.
The Device manager will tell you that is the status of the pointing device connected. If no pointing device appear in device manager, it means that your touchpad doesn't communicate with the mainboard even if is connected.
Scan for new hardware in the menu of device manager. If the device manager find a pointing device, restart the comuter and try if the touchpad works.
Nov 02, 2010 | ASUS Eee PC 900 Notebook
The touchpad mouse on my toshiba salellite does not function even though it shows it working properly when you go into the touchpad icon. I have an external wireless mouse (usb) hooked up that works fine...
The touchpad is most probably defective. If you have dropped your laptop the touchpad cable could have get out from its connector on the mainboard. You can get a new touchpad/palmrest on ebay. You have to remove your touchpad/palmrest as shown in the link below, steps 17 to 19 :
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm
Identify the part number of your touchpad/palmrest. Search on ebay.com : Toshiba Satelitte A105 palmrest. Buy the one with the same part numer as yours.
...or have your laptop repaired by a professional.
Oct 09, 2009 | Toshiba Satellite A105 Notebook
My touchpad doesn´t work
You reinstall the touchpad. It's in your Device Drivers and Utilities(or the equivalent). You need to use a mouse in order install it.
Jun 05, 2009 | Computers & Internet
Toshiba notebook equium A210 (not listed here) touchpad frozen. cursor not moving? help please?
try re-starting the computer; if that does not work install an external moue and try navigating withthat. If that works it is that the touchpad has been damaged; or the drivers arecorrupt
May 13, 2008 | Toshiba Satellite A135-S4527 Notebook
Frozen mouse
well the touchpad can be frozen for many resons, primary reasons could be.
1. the compter is hung in other words it needs to reeboot.
2. the touchpad has spoiled, if your laptop is under warranty please visit the nearest toshiba service center.
3.Yes, an external mouse would work but please check if you have a ps/2 port for regular mouses or otherwise please buy a wireless mouse they arent expensive now a days but very convineint.
Best of luck :-)
Have a nice day !!
Apr 19, 2008 | Canon BJC 1000N InkJet Printer
Frozen touchpad
try reinstalling the drivers acer europe will have them
Apr 13, 2008 | Acer TravelMate 240 Notebook
Acer Aspire 5100 Notebook Logo
37 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
